Took advantage of near-perfect planetary seeing last night. On the Moon, I did a SxSxS with the C-80, FC-76, & TS-50, mainly comparing color correction, but noting contrast & resolution, too. The Lunar Limb had the lest amount of blue / violet haze and/or yellow-green rind in the FC; the TS was very close to the same view, with the C-80 noticeable, but not bad for a moderately fast achromatic. All 3 fracs at 100x.
Saturn... Bright White disk & rings in the FC, flat white rings & slightly yellowish disk in the C-80, both at 100x. At 200x, the FC pulled ahead, with a paper white disk & rings, plus 2 belts; the C-80 cleanly resolved 1 belt on a pale yellow-gold disk. At 300x, the FC stayed sharp & white; the C-80 was past its max -- darker yellow disk & rings that would not resolve a clean limb.
Jupiter was lower, so the C-80 maxed at 260x, but the FC was sharp at 300x, with a white disk, and 6 light-gray to black belts. Surprisingly, the GRS Notch was bolder in the C-80 @ 200x than in the FC at the same magnification. Dropping the FC down to 160x put a faint hint of red-pink in the GRS -- no such hints in the C-80. At ~ 260x, both fracs displayed the Galileans as perfect Airy Disks -- beautiful. If I only had the C-80, I'd use 180x / 200x for sketching on similar nights, and zoom up to ~ 260 to confirm the smaller barges & ovals. The largest & darkest barge was easy in both at just 80x.
In terms of accessories, I got the overall best views on Jupiter in the C-80 with my old Brandons, followed by the Radians. The FC was about as good with the AT Paradigms as it was with the Radians.
Edited by Bomber Bob, 06 October 2022 - 11:51 AM.
