What did you observe with your classic telescope today ?
10875 replies to this topic
#10701 deSitter
deSitter
    Still in Old School
Posted 21 February 2024 - 04:57 PM
pellet guns are very effective wink.gif Just teasing.  However, if you talk to light company they made put a shade on the light to direct all the light downward. They can also provide a light that is not as bright.  just call your energy company and see what they offer.
If you mention astronomy they will ignore you - but if you say it's bugging everyone and keeping them and their dogs up, they will lessen the brightness.
-drl
  • steve t and rcwolpert like this
#10702 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 21 February 2024 - 07:37 PM
My sky is so bright it’s nearly impossible to find anything using just the finder and setting circles. A GoTo mount is necessary to locate anything other than the moon and planets.
On my best nites mag 5. I can almost hold all the stars in Urasa major.
#10703 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 21 February 2024 - 10:42 PM
Short session, but schweet.  Swapped 2 of my Taks for 2 Mizars - 130SL & GT-80S.  Put the 130 on Jupiter, and the GT on The Moon, until Jupiter got really low & watery; then, put both scopes in RFT mode, until those pesky Gulf clouds pushed in from the south.  Missed out on the Galilean action, but the GRS was near the meridian, and the NEB had lots of details at 225x (Paradigm 3.2mm).  No sketching - working against the clock.
  • Jacques, steve t, rcwolpert and 3 others like this
#10704 Bungee
Bungee
  • Loc: South Central Missouri
Posted 21 February 2024 - 10:56 PM
Well, here's the first report on my new to me Mayflower 815. Seeing was not the best tonight, big bright Moon, scattered clouds and a mild breeze, but I've been itching to try it out.
I installed a 1.25 vb and started at 32mm on the Moon, slowly working my way up. With each step I was amazed at the clarity and contrast, so I pushed it as high as I could go. Ending up at 303x (6mm w/ 2x barlow) I still had excellent detail with very little color. Jupiter was good up to 114x being only a little fuzzy, the moons were pinpoint.  Again, not great seeing, so I'll take that as a win. I hit a few other targets for fun with no disappointment at all.
The mount is buttery smooth, the focuser is slow and cooperative, and CA is not an issue. I think I'm gonna get my money's worth outta this one. whee.gif
  • Jacques, photiost, steve t and 5 others like this
#10705 jragsdale
jragsdale
  • Loc: Idaho
Posted 21 February 2024 - 11:34 PM
Had my Goto 452 (60/1200) between 150x and 400x (SVBony 3-8mm zoom) on Jupiter and the moon. Seemed like 5mm (240x) was the sweet spot on Jupiter to pick out maximum contrast and not battling floaters and reflections as much. And the moon actually liked a little less, I settled at 6mm(200x), mainly because seeing wasn't as good at lower altitudes.
  • Jacques, photiost, steve t and 6 others like this
#10706 CHASLX200
CHASLX200
Posted 22 February 2024 - 06:49 AM
200x is easy for a good 60mm.
#10707 fullthrottle_man
fullthrottle_man
Posted 22 February 2024 - 07:30 AM
Brought the DX8 out for a bit last night again. Skies were perfectly clear and seeing was just a bit above average. I set it up and did the PA, then off to the races! First stop, M42. Using my phone, I got a few decent pictures of it to stack some time later. Then over to Jupiter for some visual and eyepiece comparisons. Then when I was getting set up on M31 for a few pictures, the declination lock lever decided to jump ship. Again. That ended the evening much earlier than I planned, but at least I got some time at the eyepiece.
Edited by fullthrottle_man, 22 February 2024 - 07:31 AM.
  • Jacques, photiost, steve t and 2 others like this
#10708 BigC
BigC
  • Loc: SE Indiana
Posted 22 February 2024 - 08:18 AM
orange tube c8  lunar
old favorites
The first several times I looked at second photo the craters were plateaus. It's an annoying issue I often have with Moon photos.
  • steve t likes this
#10709 Bomber Bob
Bomber Bob
Posted 22 February 2024 - 10:23 AM
After so many nights using low-CA triplets, I thought the GT-80's fast F7 achromatic would bug me.  Nope.  Up to about 150x, there's no yellowing of the lunar features; all that's visible is a thin violet arc at the limb - size & intensity vary with eyepiece type.  At 224x (Vixen LV 2.5mm), the surface is light gold, but the GT retains 80mm resolution, comparable to the C80.  It's closer to white with the Paradigm 3.2mm at 175x.
I sure would like to know which company made the glass for Mizar!  Ditto for their 1980s reflectors & CATs (like the famous Altair 150).
  • Jacques, deSitter, photiost and 3 others like this
#10710 Bomber Bob
Bomber Bob
Posted 23 February 2024 - 09:29 PM
8 / 10 seeing, calm air, but transparency was down from previous nights.   Watched Europa's Peek-A-Boo! double eclipse in the TS-65S at 200x:  Tiny disk emerged from behind Jupiter; then, after a few minutes, disappeared again in its shadow.
After that, I went double-star sleuthing -- mainly for those with an orange to red star.  There's a dim & tight pair (for a 65mm scope) SE of Rigel.  Star A is the brighter - a pretty yellow-white; while B is a much dimmer red star.  At 312x (Paradigm 3.2mm), big & almost intersecting Airy disks.  Pesky Moon really diminished the Orion star fields, but the Pleiades in this triplet are such tiny sharp bright blue-white crystals.
#10711 jragsdale
jragsdale
  • Loc: Idaho
Posted 24 February 2024 - 12:05 AM
Tonight I got out the 1969 Jaegers 6" f/15 along with a C14 for some Jupiter viewing. I had them set up side by side with an APM 9mm XWA in the Jaegers (254X) and a Paradigm ED 12mm in the C14 (326X). Seeing was poor, with heavy jet stream influence. The Jaegers showed a crisp disc, with a very faint violet halo that wasn't distracting at all, with good contrast between the cloud bands and the GRS. Seeing affect was more large structure so fine detail was more preserved. C14 view was brighter and less contrasty, seeing was more localized so the disc looked like it was underwater, hard to get a crisp focus. Because of the conditions tonight, I declared the Jaegers the winner. It was just more pleasing to view, where in the C14 you could tell the seeing was bad and it wasn't "nice" to look at.
  • Jacques, deSitter, highfnum and 16 others like this
#10712 CHASLX200
CHASLX200
Posted 24 February 2024 - 06:23 AM
At least the 6" J looks like a real scope.  A C14 in any cold weather here or any SCT  is just not gonna get right with any falling temps. You see a heated up mush on Jupiter. I have had 4 months of mush seeing and cold temps with one or two near 8 nites and that is all. Can't wait till Sept when i am back to 8+ nites before sunup on Jupiter. Scopes are gonna be packed up and or sold until then  Time to do some changing up and go big Mak.
#10713 photiost
photiost
  • Loc: Montreal, Canada
Posted 24 February 2024 - 07:48 AM
Tonight I got out the 1969 Jaegers 6" f/15 .....
 Beautiful instrument !!
  • jragsdale likes this
#10714 highfnum
highfnum
  • Loc: NE USA
Posted 24 February 2024 - 08:31 AM
jaeger 80mm
Moon  (just in case you don't know)
  • deSitter, steve t, Bomber Bob and 4 others like this
#10715 highfnum
highfnum
  • Loc: NE USA
Posted 24 February 2024 - 08:34 AM
that  6 inch jaeger f15 is lot bigger than my 6 inch jaeger f10!
#10716 CHASLX200
CHASLX200
Posted 24 February 2024 - 08:55 AM
Needs a bigger boat to hold it as well vs a F/10.
#10717 CHASLX200
CHASLX200
jaeger 80mm
Looks good. Wished i knew how to take a pic.
#10718 deSitter
deSitter
    Still in Old School
Posted 24 February 2024 - 09:34 AM
jaeger 80mm
Look where Grimaldi is now compared to the last Moon shot (I think with the 1" speculum). Nice!
-drl
#10719 starman876
starman876
    Nihon Seiko
  • Loc: VA
there are adapters that will hold your cell phone to the focuser and you will be able to take pictures.
https://focus.picfai...-spotting-scope
https://www.youtube....h?v=cO_X42NOZ-o
Edited by starman876, 24 February 2024 - 09:36 AM.
#10720 CHASLX200
CHASLX200
Posted 24 February 2024 - 09:39 AM
I have a dumb phone.  But my point and shoot is not worth a hoot to sticking it up the eyepiece.  Has to be a easy way other than the afocal way with 35mm film.
#10721 starman876
starman876
    Nihon Seiko
  • Loc: VA
Well I hope you have some great nights with temps just right.  A big Mak needs to be acclimated before you can use it.
  • Bomber Bob likes this
#10722 CHASLX200
CHASLX200
Posted 24 February 2024 - 09:44 AM
I know since i got rid of a Q7 fast.  Just won't use it below 75f.
#10723 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 24 February 2024 - 09:45 AM
there are adapters for SLR's also.    I have not used one in a while
Edited by starman876, 24 February 2024 - 10:25 AM.
#10724 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 24 February 2024 - 09:51 AM
I love to see big iron pointing to the sky side by side like that!
I get exactly those same kinds of nights with the C14 and the 6"f9 on planets here (of course, we're at about the same latitude). Jupiter is bigger and brighter in the C14, but details only come through in tiny specks, and I have to try to connect them together in my mind within a swimming mess. In the 6", the structure is all there, but the finest details are lacking. On Saturn, the C14 picks up more moons, but the planet looks under water, while the 6" shows Cassini and banding.
But then I turn to deep sky faint fuzzies, and the C14 does what bigger aperture does best -- makes things clearly visible that the 6" barely hints at.
Chip W.
  • Bomber Bob and CharLakeAstro like this
#10725 CHASLX200
CHASLX200
Posted 24 February 2024 - 10:24 AM
Chip W.
A freaky sharp C14 in warm weather on a dead still nite must be fun.
  • CharLakeAstro likes this
