What did you observe with your classic telescope today ?
#11651
Posted 14 January 2025 - 02:48 PM
Venus was first and was brilliant. Saturn was good tonight. During intervals of steady seeing, I could see the rings in front of the planet, and the dark stripe of the ring's shadow. The planet showed one band.
Jupiter was the star of the show tonight. The GRS was right in the middle and was obvious. I could also see the white area surrounding it. Numerous bands were visible, and came and went eith the seeing. Callisto was passing above Jupiter. It was very close to Jupiters pole, but didn't make contact.
The clouds arrived and I packed it in.
- Jacques, Adam S, highfnum and 4 others like this
#11653
Posted 14 January 2025 - 08:34 PM
what scope is that?
It's a vintage ATM, Goto 4 inch f/15 lens.
Robert
- highfnum likes this
#11654
Posted 14 January 2025 - 08:41 PM
Robert
On a Cave mount!
- clamchip likes this
#11655
Posted 15 January 2025 - 06:22 AM
I used to droll at old Goto ads
how good is objective?
Edited by highfnum, 15 January 2025 - 06:22 AM.
#11656
Posted 15 January 2025 - 11:11 AM
The objective is excellent.
Like all Goto's I've looked thru when you first put your eye to the eyepiece you say hmm...and I think this
is because the lens is uncoated. But then, hold on tight because you are going to be blown away!
Robert
- Bomber Bob likes this
#11657
Posted 15 January 2025 - 11:31 AM
En Re occultation of Mars by the moon Yes Started out with binoculars but soon realized I needed a grab and go 80 mm brought out the everyday fluorite grab and go Vixen 80mm FL watched the whole show....in the cold New England evening I wore the flannel pajamas under the sweat pants 3 shirts and the leather jacket and wool hat toasty warm helped the 67 year old bones enjoy the show...
With 8 mm lens saw the whole moon and Mars when they were close together then poof Mars was eaten by Luna
Pretty cool for a Monday in January in my view..............
Hurry Springtime
Barry
I had a ringside seat from the picture-window in my living room supplemented with occasional, quick trips out on my balcony, (it was ~18°F). Instruments of choice, 1965 Japanese Mayflower 60mm F12 refractor, modern 8x42 roof-prism binoculars, iPhone 13.
Edited by Terra Nova, 15 January 2025 - 11:37 AM.
- Jacques, Adam S, Erik Bakker and 18 others like this
#11658
Posted 15 January 2025 - 12:24 PM
Spectacular……..Looks like you had “box seats” at the event.
Edited by sonny.barile, 15 January 2025 - 12:25 PM.
- steve t, Terra Nova, Defenderslideguitar and 1 other like this
#11659
Posted 15 January 2025 - 05:48 PM
Glad you had a ringside seat, Terra! We were clouded over then. Love the images! Tonight of course it's clear, but I'm not complaining. Okay, clear as in the sky has a bit of a milky cast to the blue, indicating some very very thin cloud. But I'll take it.
- Bomber Bob and aznuge like this
#11660
Posted 16 January 2025 - 09:13 PM
Went out for a brief session to look at Mars in my Meade 226, I used my 40mm MA as a finder then switched to my Vixen 5mm ortho, I then tried my Celestron 4mm ortho, but wound up backing off to my 6mm. A fun session.
- Jacques, deSitter, photiost and 3 others like this
#11661
Posted 16 January 2025 - 10:24 PM
At f/15, 7mm maxes out useful magnification (0.5mm exit pupil). The 6mm is already pushing it and the 4mm is too dim, and getting fuzzy. I remember learning this lesson with my first telescope. It had 5 eyepieces but the shortest was not useful and the next shortest was rarely useful and inferior to the next longest, 9mm. A better spread of eyepieces would have been 6mm, 9mm, 12mn, 20mm, and 30mm. I never understood why those scopes came with such a lineup. Probably marketing value of magnification.
-drl
#11662
Posted 17 January 2025 - 07:38 AM
-drl
This one is a f/11.67 (60/700), agree that with a 4mm it’s too dim, but the 5mm was acceptable with no image breakdown at a .42mm EP.
#11663
Posted 17 January 2025 - 11:42 AM
Do classic eyepieces count? I viewed some very good sunspot activity through my .965 solar wedge with a zoom eyepiece then bumped it up a notch with a Takahashi 7mm ortho. Still early and lots of turbulence, should be much better later. Unfortunately, I left all my good classic refractors back home in Washington. I won't do that again, making do with a cheap Celestron 60mm alt/az.
- deSitter, Bomber Bob, Defenderslideguitar and 1 other like this
#11664
Posted 17 January 2025 - 05:17 PM
I have been going down the Herschel-400 list with a Unitron 142 (75 mm F/16 doublet), and gathered a handful early last evening, from a county-park parking lot near Frazier Park, California. This site is about 5400 feet above sea level, and it was a bit chilly -- the temperature got down to 2 C. Fortunately, I was born and raised in Vermont, so those conditions merely made me nostalgic for springtime. The light dome of greater Los Angeles made the southern sky brighter than I would have liked, but the sky was quite transparent, so I was able to work fourteen objects in Gemini, Monoceros, Canis Major and Puppis, using a magnification of 48 (modern 25 mm Plossl eyepiece). There were no other observers present. My only company was resident wildlife, including the well-known Felis concolor mutabilis, a mountain lion variant common in dark conditions, that magically transforms into a jack rabbit when illuminated by flashlight.
I won't provide a detailed log, but most of the open clusters showed merely as a diffuse blur. Some had the granular appearance of incipient resolution, and a few were well resolved. The one diffuse nebula on the night's list, NGC 2185 in Monoceros, showed faintly around embedded stars.
I started this project with the 142 on its original equatorial mounting, modified by the addition of an electric sidereal drive from Astronomy Shoppe, which is very pretty and works very well. Lately I bought a PiFinder and switched to a more modern altazimuth mounting to try it out. PiFinder takes images of the sky and uses software to figure out where it -- and, after alignment, the telescope -- is pointing, and tells you in real time how far and in what direction to slew the telescope to find what you are looking for, but it only works with an altazimuth mounting. The system was good enough to put objects well within the rather narrow field of the eyepiece: My Unitron does not have an drawtube adapter for 1.25-inch eyepieces, so the field of view is restricted to what will pass through a 24.5 mm circle, which is a bit over a degree.
This combination of old and new technology works well: I was able to find objects in about a minute, before the cold made my fingers too numb to feel the controls. I have 45 H-400 targets left, and there is little doubt that the 142 can do it -- I have already logged the two H-400 objects I consider most difficult with it, those being low-surface-brightness galaxy NGC 6118 in Serpens and highly-obscured open cluster NGC 6540 in Sagittarius. What remains are all pretty much wintertime objects, so I shall likely again face the prospect of frostbite and transmogrifying mountain lions at this site. Until then I wish you clear sky, warm hands, and strictly vegetarian wildlife.
- Jacques, Paul Schroeder, davidmcgo and 10 others like this
#11665
Posted 18 January 2025 - 10:49 AM
That is one beautiful refractor and tripod. The tripod is homemade? Whoever made it has wonderful woodworking talent.
#11666
Posted 18 January 2025 - 05:31 PM
First up was Jupiter. The GRS was just coming around. When the seeing steadied, the detail visible was impressive. Lots of detail, and I even got to see two white ovals. I stayed on Jupiter as the GRS crossed the meridian and drifted towards the limb. A shadow transit followed the GRS along the SEB.
Mars was nice tonight. The polar ice cap and dark markings were easy to see.
I started hunting down double stars, but had to pack it in because the corrector started fogging up despite a 12" dew shield.
- Jacques, mdowns and Bomber Bob like this
#11667
Posted 19 January 2025 - 09:51 AM
My '86 C8 had its best night so far on Thursday: views of Jupiter at 400x (LV-5) got the closest to my Meade 826 yet. I had my 1975 TS-50 / 700 out as well as a "seeing checker" -- overall, a 7+ with moisture > (cold front pushing in) but very steady air. 5 sharp & easily visible belts in the TS at 140x (spectros PL-5).
Both my 8" scopes can deliver colorful belts with white zones. The big difference is resolution. For me, that's how much fine detail I can see in each belt, and along its margins. The C8 is a compromise, but... it's so much easier to set up, and rides so well on my Mizar AR-1. I'm retired, but after a day of working in the yard, convenience is important, too. Glad I took a chance this Old Scope.
Mars was low, but I took a quick look. I could see several dark features at 200x that fuzzed away at higher powers. Gotta be -- what's the word? -- patient.
- Jacques, photiost, steve t and 4 others like this
#11668
Posted 19 January 2025 - 09:53 AM
Sea of clouds for 3 weeks.
#11669
Posted 19 January 2025 - 12:58 PM
- Jacques, deSitter, photiost and 7 others like this
#11672
Posted 21 January 2025 - 05:11 PM
I observed that it was to dam cold for me to go out and observe with any telescope! Brrrr
That’s why you have the SeeStar!
- Terra Nova and Bomber Bob like this
#11673
Posted 21 January 2025 - 05:14 PM
Well... it's been 25F / WC 15F pretty much all day at The Swamp with about 1" snow on the ground -- much worse for our Gulf Coast kin...
To paraphrase Aunt Pitty-Pat, "Blizzards! In Biloxi. How did this happen?!" Daughter says they've had 7+ inches so far with snow still falling...
We've learned: Shut Down Everything. For our own safety! Shoot. After 2 LONG Winters in Grand Forks ND, I could pop out to the dumpster in running shorts & flip-flops on a day like this... but, that was 4 Decades ago. So, no matter how clear it is Weds night, I'll be hunkered in the house.
- photiost, The_Vagabond, Terra Nova and 2 others like this
#11674
Posted 21 January 2025 - 05:27 PM
It may have been a crisp 5°F with plenty of snow on the ground here in Ashtabula, but when it clears, duty calls. And by duty I mean my daily sunspot count.
After I do my sunspot sketch I try to use my old Samsung Galaxy phone to get an afocal shot through the eyepiece and then process it in Gimp.
It's a crude method, admittedly, but it works.
Oh, the telescope I normally use for my white light sunspot work is a Selsi/Towa 60/700, with a 12mm Kellner. This is in addition to my smaller Bushnell 50mm SkyRover that is used as a backup. Most of my solar work is done with vintage equipment. I also use 40mm Galileascope clone, the StarScout, for an additional sunspot project.
Edited by The_Vagabond, 21 January 2025 - 06:15 PM.
- deSitter, photiost, steve t and 6 others like this
