Did I put my SBIG together correctly?
9 replies to this topic
#1 gillmj24
gillmj24
Posted 17 February 2016 - 07:05 PM
Apologies if this is the wrong forum. We really need a CCD subcategory under "equipment," but i digress. This didn't really belong in the beginner forum since this isn't beginner equipment (I'm in way over my head, I know...)
I have had an STT 8300 with self guiding filter wheel for quite some time and haven't used it yet other than to test dark frames.
I picked up an AO8 on CN a few weeks ago and ordered the requisite plate to convert it to the T version. There was an order mixup so the plate didn't arrive till last night.
The AO8 came with a square plate which had a rhreaded opening, but no caps. Boight used, but the shipping foam was on both sides of the optical lens.  The self guiding filter wheel has a circular piece with 4 screws. My 2" adapter nosepiece is threaded into the circular piece.
I found the instructions quite lacking. There is no update to the instructions that I could find for the AO8T.
Here's what I came up with on my own (picture essay)
Edited by gillmj24, 17 February 2016 - 07:07 PM.
#2 gillmj24
gillmj24
Posted 17 February 2016 - 07:08 PM
Pic 1.
Starting with stt fwg 8300 and nosepiece. Remove the 2" threaded part and the 4 screws attaching the circular piece to the filter wheel...
#3 gillmj24
gillmj24
Posted 17 February 2016 - 07:09 PM
Pic 2
2" piece and 4 screws removed. Remove circular piece. (Annulus, really)
#4 gillmj24
gillmj24
Posted 17 February 2016 - 07:12 PM
Pic 3
Attach the new to me 8T cover plate with the 4 screws that were just removed from the filter wheel. I temporarily put the 2" nose piece back to protect the filters.
#5 gillmj24
gillmj24
Posted 17 February 2016 - 07:17 PM
Pic 4
Remove the nose piece and fasten the ao8 to the ao8t cover plate with the 4 screws. Note if you are upgrading like I am, you will remove the standard cover plate first, of course.
See how the T cover plate has a semicircle at the top, this fits where the original annulus piece went.
Edited by gillmj24, 17 February 2016 - 07:18 PM.
#6 gillmj24
gillmj24
Posted 17 February 2016 - 07:19 PM
Pic 4 is also after I removed the square block that was held in by 4 very short hex screws.
#7 gillmj24
gillmj24
Posted 17 February 2016 - 07:22 PM
Pic 5
I pit the stubby hex screws back here without the square block, then reattached the 2" nosepiece.
#8 gillmj24
gillmj24
Posted 17 February 2016 - 07:24 PM
Pic 6 wired up. Is this the right sequence?
#9 gillmj24
gillmj24
Posted 17 February 2016 - 07:25 PM
Pic 7
The leftovers
#10 ToolMayNARD
ToolMayNARD
Posted 18 February 2016 - 12:32 PM
Same setup here, it's all right!  :waytogo:
