Thanks A. Viegas(4/19). But I may be amiss, I thought Sam said the only one that has access to the Chip was the uncooled camera?
Sorry, but maybe I dont understand exactly what you are trying to do... but from what i can see there are four ways to attach the camera to a scope...
1. you can screw in a 1.25" barrel to the existing black ring you see in the photo
2. you can screw ina c-mount adapter into the black ring
3. you can remove the black ring and screw the camera directly into a filter wheel which as I said I think is about the same thread size as what you could screw a typical SCT 2" reducer into. This means you can screw this also into a 2" holder or hyperstar lens too
4. you can remove the screws from the protective AR window and remove the ring and the glass protection for the sensor, exposing it...
I could be wrong but all the ASI cameras seem to have this same basic form factor... and I think the threads are all the same in terms of attachments... hence if you can look at an existing 174MM cool you can see if that camera can be adapted to whatever imaging reducer/flattener you need to attach.
Al
Edited by A. Viegas, 20 April 2016 - 08:16 PM.
