I just invented the EPA (Elementary Polar Alignment) toolkit : It's a piece of transparent plastic with two small holes in it and a whiteboard marker as seen in the pictures.
With a permanent marker pen I prepared the plastic sheet with positions of some stars near NCP, and also two crossing lines that connect a few of them and NCP. This was done with a picture I took from that area, combined with a screen dump from Stellarium with the J.now equatorial grid (not j.2000). This piece of art is scaled to match what I see with my (Android) camera tethering app, dslrdashboard, since I use no pc in the field.
This is how I use it :
- First a rough traditional alignment with the mount's PA scope.
- Slew the scope (I do that manually to save time and battery), and rotate the imaging camera, to roughly align the Live View image with the EPA star pattern.
Then set the RA setting circle to "0".
- Open the camera shutter (10-30 sec) while rotating in RA at least 180 degrees, and check for a nice star trail of Polaris.
Return the RA axis to "0".
Wait for more sky darkness, then take a picture of the faint stars (this time without trailing).
- Open the first picture, align the best fitting EPA circle as close as possible to the Polaris circular trail.
Then put a small whiteboard pen dot in the center hole. This is the Center Of Rotation (COR) and it is just a temporary mark.
See pic #1.
- Open the second picture and align the EPA lines and star marks with actual stars in the picture.
Then copy the COR mark (on top of the temporary one). See pic #2.
The crossing lines is NCP, so we need to move COR the distance and direction we have to NCP. This is done in the next steps.
- Moving COR to NCP equals moving the stars the same distance but in opposite direction.
Rotate the EPA 180 degrees and align the last dot made on Polaris (or any star), then put a final dot in the hole at the crossing lines. See pic #3-4. This is where you should put that star.
So, during Live View, move the chosen star with the AZ & ALT bolts to that last dot.
If your Live View window and the "open image" window have identical physical dimensions, you are lucky. That is not so with Dslrdashboard, so I have to adjust the star moving distance to 80 % of the original distance.
This procedure can be done differently, but if done as described here you do not need to hold any plastic sheet on the display when you adjust the ALT & AZ bolts. Both hands are free to do the adjustments.
And how does it work then ? I have only tested a couple of times, but it much improved both accuracy and time needed (after doing a little practicing). Field rotation is almost gone. I used to do the SynScan PA utility with random results and now I just nail the PA (almost), then do a 1-star align and that's it.
This is done with a 700mm FL APO and a aps-c dslr (Nikon D7000). I was lucky with the imaging scale but I guess this can be done with a guidescope camera connected to a pc as well. And how long will it take before someone implements this in software... ? I would love an Android version.
Ragnar
