Problem with Helical Focuser on TeleVue Ranger
refractor
11 replies to this topic
#1 ljohnson
ljohnson
Posted 25 April 2016 - 06:17 PM
I recently picked up a brass TeleVue Ranger on a beautiful wood alt-az mount for $100--a good deal, I believe. Everything is in very good condition, except the helical focuser seems to be stuck in the fully extended position. When I try to turn it, it will not budge. I pushed as hard as I dared, but I did not want to damage anything. Does anyone know how to disassemble and fix that helical focuser?
  • Charlespl likes this
#2 jeff gill
jeff gill
Posted 25 April 2016 - 06:38 PM
That's a steal of a deal.  Is it fully extended?  Or fully retracted?  Ive had helical focusers jam when ran all the way out or all the way in, but i wouldn't expect that of a televue focuser, unless it had been left that way for a long time.
#3 sydney
sydney
  • Loc: Upstate NY
Posted 26 April 2016 - 06:34 PM
I don't remember the specifics, but taking it apart is easy.  Start with the small hex screws (2) on the black ring that's attached on the end of the knurled knob.  I believe that ring then unscrews.  Work your way in from there.  Here are some pics of the parts when I took mine apart to re-grease.
  • Piero DP likes this
#4 ljohnson
ljohnson
Posted 27 April 2016 - 09:30 AM
Jeff--You were right. The helical focuser had been fully extended and had been left that way for years--the previous owner did not even know that the brass collar was a helical focuser.
Sydney--I removed the draw tube assembly, loosened the two set screws in the black ring, and unscrewed the black ring as you suggested. The brass collar was still stuck fast. I called TeleVue tech support to make sure I knew which way I should turn the collar. I then padded the draw tube and clamped it in a metal lathe, padded the brass collar, and forced the brass collar loose with large pliers. Now I just need to remove the original grease, add new grease, and reassemble everything.
Thanks for the help!
  • LTZ, Peter Besenbruch and Piero DP like this
#5 KerryR
KerryR
  • Loc: West Michigan
Posted 28 April 2016 - 08:45 PM
Good job! That'll be a great scope... even more so at $100-- a real steal!
Enjoy!
  • Ravenous likes this
#6 DeSoto Kid
DeSoto Kid
  • Loc: DeSoto, Texas
Posted 30 April 2016 - 09:54 PM
Did TeleVue recommend a grease for your Ranger helical ?
Wayne R.
DeSoto, Texas
#7 beanerds
beanerds
  • Loc: Darwin Australia
Posted 01 May 2016 - 05:41 AM
Good news , I echo the  ' $100 , a steal of a deal ' ) , I hade a Pronto years ago ( same optics ) and it was a jem of a scope .
I still kick myself for selling it ....
Brian.
#8 Kutno
Kutno
Posted 01 May 2016 - 07:37 PM
Wayne R.
DeSoto, Texas
A while back, when I had a similar question, the gentleman on the phone indicated regular automotive grease.
#9 LTZ
LTZ
  • Loc: Arizona
Posted 16 November 2016 - 02:21 AM
I'm experiencing the identical issue with a recently acquired brass Ranger.  I have removed the grub screws and metal ring, but I'm stuck on how to leverage the brass focus ring loose without damaging it.  Does loosening the brass collar / focus ring follow the left loosey righty tighty rule, like the ring or is it opposite?  I don't want to make it worse guessing the wrong way!!  Thanks!!
Edited by LTZ, 16 November 2016 - 02:23 AM.
#10 gillmj24
gillmj24
  • Loc: PA
Posted 26 April 2018 - 08:22 PM
Me three
#11 gillmj24
gillmj24
  • Loc: PA
Posted 24 May 2018 - 10:47 PM
Took it apart and was able to work the helical free. Still stiff with the old grease but was usable and good to kbow a regrease (and some brass polish) will make it like new.
#12 Neal Smith
Neal Smith
Posted 06 November 2019 - 06:10 PM
Anyone know of a Crayford type retrofit for these little Rangers?
Also tagged with one or more of these keywords: refractor
