A Tri-Bahtinov mask for SCT collimation and focusing
astrophotography imaging SCT
587 replies to this topic
#476 Endymion
Endymion
  • Loc: Orange County, CA
Posted 24 August 2021 - 01:05 PM
I just purchased a tribahtinov mask (BuckeyeStarGazer's) for my C11 and gave it a try last night.  Image below seems to look good to me; can someone with experience tell me how good the collimation looks?
John
TriBahtinov C11HD
#477 cytan299
cytan299
Posted 24 August 2021 - 05:29 PM
John
Looks great!
I'd suggest checking by removing the mask and going in and out of focus to see how the Airy disk behaves. You should see something like this:
https://www.youtube....h?v=Ie9j0Z9MNC8
This was as good as I could collimate my ETX125 using the TriBahtinov.
cytan
Edited by cytan299, 24 August 2021 - 05:32 PM.
  • calypsob and Psittacula like this
#478 Endymion
Endymion
Posted 24 August 2021 - 06:29 PM
Thanks cytan!
#479 Brain&Force
Brain&Force
Posted 08 September 2021 - 04:14 PM
I decided to try a custom design for a Tri-Bahtinov mask for my C5. Unfortunately, when I made the mask, I made the slot angles larger than I wanted (30 degree deviation rather than 15). However, the results were pretty good! I've taken to calling this mask the "Cheese Grater" since I'm currently in Wisconsin.
Here is the mask:
The diffraction spikes when defocused (note the splitting of alternating spikes, as well as the offset of the single spikes from the center). The resulting pattern has 3-fold symmetry.
When in focus, the spikes align and you get a perfect 12-fold diffraction pattern:
  • George N, R Botero, Voilam and 1 other like this
#480 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 12 September 2021 - 02:43 PM
Anyone have a working .stl for an 11" edgeHD?  the one I found early in the thread doesn't load with Cura.  And every "generator" link I click on says the page is not there any more.  Thanks
#481 cytan299
cytan299
Posted 12 September 2021 - 05:39 PM
Doesn't this link work?
https://satakagi.git...i-Bahtinov.html
cytan
  • Psittacula likes this
#482 teashea
teashea
  • Loc: Lincoln, Nebraska, USA
Posted 12 September 2021 - 07:31 PM
  I made a Tri-Bahtinov mask that I think would be useful for both SCT collimation and focusing. My mask is shown here:
The diffraction pattern that I see when I first point at Polaris is shown below:
It is clear that 2 orientations are in focus while the third (indicated with red arrows) is not.
After collimation (still not quite perfect), I get all three orientations in focus
I built this mask because my judgement with the Airy disk method is not as objective as I would like it. I think by using my favorite tool, a Bahtinov mask, modified for collimation would make collimation much less subjective.
My full design and writeup can be found here:
https://github.com/c...299/tribahtinov
I hope this is useful for the community.
cytan
nice
#483 Psittacula
Psittacula
  • Loc: Tokyo
Posted 13 September 2021 - 06:46 PM
cytan
I'm not familiar with Cura, but it looks like these can be used to load SVG.
https://github.com/G...GToolpathReader
https://all3dp.com/2...printable-stls/
#484 ontherivet
ontherivet
  • Loc: Boulder, CO
Posted 17 September 2021 - 10:38 AM
Anyone know if the grabber software is available anywhere at this point?
Don
  • Whichwayisnorth likes this
#485 Psittacula
Psittacula
  • Loc: Tokyo
Posted 19 September 2021 - 04:26 AM
Is there anyone who can write an "engraving generator"? that would be great..
I'm not sure what the effect of the engraved transparent mask is, but I've added the hairline option to the following generators
https://satakagi.git...ahtinovWebApps/
You may be able to create the desired pattern by combining the regular one with this hairline option.
Satoru
Edited by Psittacula, 19 September 2021 - 04:31 AM.
  • JayScope, cytan299 and Bingoin like this
#486 Whichwayisnorth
Whichwayisnorth
Posted 24 September 2021 - 10:16 PM
cytan
Yes sorry that does work but looking for a ready to download/print .stl for my 3d printer.  Asking if people have one they could share.  Thanks
#487 Psittacula
Psittacula
  • Loc: Tokyo
Posted 26 September 2021 - 06:39 AM
I think you can convert from svg to stl. The following content may be helpful.
satoru
#488 Psittacula
Psittacula
  • Loc: Tokyo
Posted 27 September 2021 - 04:26 AM
satoru
The tri-bahtinov mask generator will generate outline data, i.e. data for a laser cutter or cutting machine. However, the stl files required for 3D printers etc., require filled data, i.e. polygon data.
Using inkscape, you can polygonize the outline data. This is a bit of a complicated process, but it is easy to do.
I have placed a brief description and instructional video here.
https://satakagi.git...WebApps/#tomake
  • cytan299 likes this
#489 Borodog
Borodog
Posted 28 September 2021 - 02:03 PM
Forgive me if this has been covered somewhere in this very long thread already, but can someone comment on the accuracy of collimation using the tri-Bahtinov mask? As in, has anyone collimated using the mask and then double checked with a tool like MetaGuide?
#490 MarMax
MarMax
  • Loc: SoCal
Posted 28 September 2021 - 05:28 PM
I can provide what I've experienced so far with the C11 in my 3/5 conditions (seeing and transparency). I've not actually had a 4/5 night yet where I tested the Tri-B mask. I have a Buckeyestargazer Tri-B mask and find that with Polaris it can be a bit hard to see the spikes. Both visually and in attempts to video with the 464 camera. It's still a work in progress.
I've found the mask to be very helpful to get to the 90% point but that last little bit is tough to discern when things are wobbling all over the place. I think the Duncan mask is a little bit better from the 90-95% point in 3/5 conditions. This is about where I'm at now.
I've not tried MetaGuide as you have because there is no DirectShow driver yet for the NCII 464. But taking video of Polaris in-focus seems to be the next step IMO to improve from the 90-95% point. MetaGuide live stacking should be the ultimate tool if it works.
The other thing I need to try with the Tri-B mask is a brighter star. In theory the Tri-B mask should work to get to 98% collimation. And I wonder what you'd get with a Tri-B mask and Metaguide. I don't think you can solve the "too tight" collimation screw problem using the Tri-B mask but you should be able to get best collimation. IMO you need a MetaGuide or other video of the in-focus star to see if you are deforming the secondary.
#491 Borodog
Borodog
Posted 28 September 2021 - 06:52 PM
I've tried MetaGuide repeatedly. I know it's probably just the seeing, but so far I am not having much luck. I know my collimation is close but no cigar, but I haven't been able to get much out of MG. It's been frustrating. Hence the want to move to something else, like the TBM.
#492 archer1960
archer1960
  • Loc: Southern New England
Posted 29 September 2021 - 06:37 AM
Try using a star that is more directly overhead than polaris. It probably won't wobble as much due to the seeing.
#493 GDN
GDN
  • Loc: Northern Michigan
Posted 14 October 2021 - 09:48 AM
A couple of questions:
1)  Has anyone tried to make a mask for focusing a Meade 16-inch SCT?
2)  Is there a commercially made Bahtinov mask for a Meade 16-inch SCT?
3)  Where and / or who(m) can print a mask this size?  And how thick?
#494 Psittacula
Psittacula
  • Loc: Tokyo
Posted 15 October 2021 - 11:02 AM
It looks like buckeyestargazer is accepting orders.
https://buckeyestarg...TriBahtinov.php
  • nighthoek likes this
#495 fractal
fractal
Posted 08 November 2021 - 11:08 AM
Hello to all!
I’m amateur astronomer writing from the middle of the italian adriatic coast.
I’m using fairpoint bahtinov mask since his invention on my Meade LXD75 SC8”.
For collimation, I still using a hartmann mask with three triangular holes.
I’ve readed all the replies to this post and other post talking of this.
I’ve made my own mask but the hand cutting was to bad that the spikes are not clear and in fact is inusable.
I would send it to a laser cutting store but before make this investments some questions rises to me:
1. In the original bahtinov mask the angled slits have 20° instead of 10° of the tribahtinov. Which angle is better?
2. Trasparent is better than opaque?
3. If yes, which material is better between acrylic (plexiglass) and polycarbonate (lexan) and how much thick the sheet (my fairpoint astro opaque bahtinov mask is 2mm thickness)?
4. Engraving is better than cutting (like WO models)? I’ve noticed that some WO mask are made of combination of two technics.
I still don’t understand the relation between the widht of stem and slit and how this can influence the final image looking through the telescope.
If the stem can be the minimum, like with engraving instead of laser cutting, many narrow slits is better than few broad slits?
Thank’s in advance for any replies.
Alex
#496 cytan299
cytan299
Posted 09 November 2021 - 09:00 AM
Hello to all!
Alex
IMO, the angle is really not that critical. The more slits you have, the sharper the diffraction spikes. The width of the stem is really for strength, so choose a width that you're comfortable with. Obviously, the more slits, the more fragile the mask is going to be as well. So, it is a balance.
My original masks were made from acrylic which is quite fragile because of the slits. Now I use 3 mm thick MDF with the laser cutting service from Ponoko. MDF is a lot stronger than acrylic.
I don't really understand why transparent masks would actually work well. Light is going through a transparent material that has no guarantee flatness is, IMO, not a good idea. So I'd use a non-transparent material and use real slits.
As usual YMMV
cytan
Edited by cytan299, 09 November 2021 - 09:08 AM.
  • fractal and Psittacula like this
#497 fractal
fractal
Posted 10 November 2021 - 03:55 AM
Hi Cytan, thank’s for your kindly answer, I will follow your suggestion.
#498 Dennis_Oz
Dennis_Oz
  • Loc: Brisbane, Australia
Posted 20 November 2021 - 04:28 AM
Here is my 1st light with the Farpoint Tri-Bahtinov Mask for Celestron 9.25 SCT.
I used this on my new C9.25 EdgeHD with a TeleVue x2.0 PowerMate and ASI 174 MM camera at an efl of 4700mm at F20.
The seeing was around 4-5/10.
Cheers
Dennis
#499 Borodog
Borodog
Posted 20 November 2021 - 04:36 PM
Sorry if this question has already been asked somewhere, but is there a reason the tri-Bahtinov  mask would not also work for collimating a Dobsonian? It also has 3 collimation screws, no?
#500 cytan299
cytan299
Posted 21 November 2021 - 08:50 AM
I would think the Tri-Bahtinov will work in a Dobsonian as well because it works on a Newtonian:
https://www.cloudyni...sing/?p=8026516
Please post if it works or doesn’t.
cytan
  • Psittacula and Borodog like this
Also tagged with one or more of these keywords: astrophotography, imaging, SCT
