Revolution Imager R2
903 replies to this topic
#1 CA Curtis 17
CA Curtis 17
    OPT/Amazon Affiliate
  • Vendor Affiliate
  • Loc: California
Posted 16 May 2016 - 11:03 PM
Just received the Revolution Imager R2 from Orange County Telescope.  This is the replacement for the now out of stock original Revolution Imager which included an entry level video camera and all necessary accessories in one complete package.  The R2 comes with the same complete set of accessories in a very nice protective case with strap:
1/3" analog video camera
7" LCD monitor with remote control and stand
12V Li ion battery
0.5X reducer
UV/IR filter
1.25" adapter
UTC camera remote control
power and video cables
carrying case
I haven't been able to get outside with it yet, but am impressed with how well everything was packed and protected inside the hard cover case.  It came with a printed set of instructions for setting it up and a short 3 step guide to setting up the camera menu to start.  Pictures of the everything are shown here.  As you can see, everything is neatly packaged in the carrying case.  The camera has a Sony ICX811 CCD and you can plainly see that it is a smaller version of the original.  I'm betting it will still give amazing results either with the in camera stacking (up to 6 frames) or with a computer and stacking software like Sharpcap.  You can get more details on the RevolutionImager.com web site.
Seeing this in person I can say this is a very nice all-in-one easy to set up package for anyone wanting to start out in deep sky video.  It also looks like a great outreach setup.
Just as soon as I can, I will give the camera a go and let post some images.
Best Regards,
Curtis
Edit:  Sorry, but I just noticed another thread on this new camera.  I didn't mean to steal the topic.  I guess I was just so excited to share that I didn't check the other postings first.
Edited by CA Curtis 17, 17 May 2016 - 12:05 AM.
  • shortonjr likes this
#2 Astrojedi
Astrojedi
  • Loc: SoCal
Posted 17 May 2016 - 12:10 AM
Looking forward to seeing some results.
#3 nytecam
nytecam
  • In Memoriam
  • Loc: London UK
Posted 17 May 2016 - 09:28 AM
Looks good Curtis - await some results ;-)
As an aside is there a post somewhere listing EAA cameras / variants and their origins / websites.  I'm confused with all the camera names as to who makes what  ;-)
Nyte
  • Bestred1 likes this
#4 StarMike8SE
StarMike8SE
  • Loc: Florida
Posted 17 May 2016 - 10:26 AM
I'm glad they found an alternative to the original camera.  Cant wait to see some images
#5 OleCuss
OleCuss
Posted 17 May 2016 - 11:03 AM
Nyte
I don't think we'll ever have a comprehensive list.
AVS seems to use a LN300 case and then sources the sensor and designs the electronics for most of the cameras.  I think some of the boards are printed/made elsewhere and components placed/soldered to them and final assembly is AVS.  I think that is the closest I know of for analog video cameras being made by the seller.  The DSO-1 is (I think) a modified LN300 and is an exception to the typical mode of manufacture - and is much cheaper.
Touptek, Tucsen, and Mintron have made a bunch of the cameras sold under various names - some with slight modifications, some with significant modifications, and some with no modification other than putting the seller's name on them.  Nothing at all wrong with doing this, BTW - and I think we'll see more of it in the futre.
I'm really not sure where ZWO fits into all this.  I've wondered if there were some connection between Touptek, Tucsen, and ZWO - either cooperative or adversarial but I really don't know where it all comes down.
The upshot, however, is that I don't think we'll ever have that entire list.
The thing I think, however, is that we should insist on knowing what sensor is being used, frame rate(s) used in the camera, potential integration times, whether 3D-DNR is used and mandatory, etc.  Get the specifications - if they won't give them then there is likely something you should know and which they don't want to tell you.  I think they will all give you the specs.
Edited by OleCuss, 17 May 2016 - 11:03 AM.
#6 docent
docent
Posted 17 May 2016 - 12:58 PM
Curtis -
What kind of telescope are you using for your R2 imager?  Do you need a focal reducer?
Mike - Ca
#7 Relativist
Relativist
  • Loc: OC, CA, USA
Posted 17 May 2016 - 01:28 PM
The package comes with a focal reducer.
#8 Boomer23059
Boomer23059
  • Loc: Powhatan, VA
Posted 17 May 2016 - 01:53 PM
I've got the R2 with the "Revo-Evo" kit that mounts the monitor into my Nexstar Evolution 9.25 and uses a USB to 12v cable to powers the monitor and camera from the Evolution battery.  It's great!
I had a brief viewing of Jupiter with the 0.5 focal reducer.  I got an image on the screen about the size of a pencil eraser, but the bands and colors of Jupiter were very clear.  Clouds rolled in before I could try it without the focal reducer.  Looking forward to viewing Mars after the rain passes.
  • StarMike8SE likes this
#9 TheRock
TheRock
  • Loc: Bergen County, NJ
Posted 17 May 2016 - 02:17 PM
Is it me, or is this new camera being promoted differently.... more planetary perhaps?
#10 OC Telescope
OC Telescope
    Vendor (OC Telescope)
Posted 17 May 2016 - 03:13 PM
Not at all!
Truly amazing deep sky capabilities in seconds from a light polluted back yard.
#11 wrpspeed16
wrpspeed16
  • Loc: Davenport,Iowa,USA
Posted 17 May 2016 - 03:58 PM
it does have a zoom which wouldmake it easier for planetary I think.
#12 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 17 May 2016 - 05:15 PM
Don't use a focal reducer for planetary work, there you want more focal length not less.
Add a 2x to 3x Barlow when you are viewing the planets. This works better than using the built in zoom feature.
The only time a focal reducer makes sense for solar system work is when you want to get the whole lunar or solar disk in the fov and even then you really need to watch the faster f ratio which makes things really difficult particularly with white light solar filters (many cameras can't get a fast enough shutter/frame rate to prevent the image from being blown out at faster f ratios). In this type of situation you may need to add a neutral density filter (or polarizing filter or even a light pollution filter) to reduce the brightness.
Edited by mclewis1, 17 May 2016 - 06:09 PM.
  • Ptarmigan, Gary Z, claws and 1 other like this
#13 CA Curtis 17
CA Curtis 17
  • Vendor Affiliate
  • Loc: California
Posted 17 May 2016 - 05:29 PM
Mike-CA     As the other Curtis said, the R2 comes with a 0.5X focal reducer.  I also have other reducers I will eventually try with the camera.  I think I will try the camera first with my C9.25" SCT, but eventually a 6" SCT, 80mm Refractor and C14" SCT in Hyperstar.  But it will take some time to try it with all of those combinations since I work for a living, have to deal with the moon and cloudy skies and just have other things to do besides this.
I will post here, and on my web site, CaliforniaSkys, as images become available.
My focus will be on deep sky objects, but eventually I will look at some planets with it as well.
Curtis
#14 CA Curtis 17
CA Curtis 17
  • Vendor Affiliate
  • Loc: California
Posted 17 May 2016 - 11:58 PM
Even though the moon is large and high up in the sky, I just had to give the R2 a quick run through.  I used it on my C9.25" SCT with the included 0.5X reducer and UV-IR filter.  I used Sharpcap to capture a few photos of the moon (because it was still early and I thought it was a good place to get started), M5 and M3.  The moon was captured at 1/10,000 sec with AGC Max at 12dB.  M5 and M3 were stacks of 600 and 300 frames, respectively, using 256X (5sec) & 36dB AGC.  I did not use DNR and left all the other settings as they came.  I had trouble getting Sharpcap to recognize enough alignment stars at first and had to raise the exposure to 256X which is the max.  Could be something I was missing or the brightness of the sky background making it harder to distinguish stars.  Will find out when I get a dark night to play with the camera.
I know that M3 and M5 are not especially difficult targets, but given the brightness of the moon and my newness to the camera I thought I should give these a try.
Best Regards,
Curtis
  • Relativist, mclewis1, Dragon Man and 13 others like this
#15 Censustaker
Censustaker
  • Loc: Utah
Posted 18 May 2016 - 12:55 AM
I think those are pretty great, Curtis. I've personally noticed that the stars on the R2 appear to be a little tighter in my opinion.
#16 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 18 May 2016 - 06:05 AM
Using a focal reducer gives sharper more 'pinpoint' stars, using an IR/UV filter tightens them up even more, and so does a natively fast scope.
Add the 3 together and BINGO! nice sharp stars  :)
#17 StarMike8SE
StarMike8SE
  • Loc: Florida
Posted 18 May 2016 - 06:57 AM
Great pics!   I would like to see how it does on galaxies
#18 CA Curtis 17
CA Curtis 17
  • Vendor Affiliate
  • Loc: California
Posted 18 May 2016 - 08:58 AM
Thanks Jon and Mike.
I too want to see how this does on galaxies and nebulae, but I have little time on weeknights and I needed to try out the new camera with some relatively easy objects. Weather forecast for this weekend, cloudy with a chance of rain.  With such a bright moon it's pretty tough to see what the camera can do on deep sky objects anyway.  If I can I'll change out to a barlow and see if I can capture some pics of Jupiter before the clouds come.  But my real interest is in DSOs, so maybe the following week.
Curtis
Edited by CA Curtis 17, 18 May 2016 - 09:08 AM.
#19 Dragon Man
Dragon Man
Posted 18 May 2016 - 09:19 AM
Really good results Curtis   :)
Your background sky is nice and smooth too. It also helps make the stars look cleaner.  :waytogo:
#20 Relativist
Relativist
  • Loc: OC, CA, USA
Posted 18 May 2016 - 09:30 AM
Curtis
I'll be getting the R2 model this weekend as well, although I would prefer the R2-D2 series... If only the weather would cooperate here in California!
  • StarMike8SE, Censustaker and Spacefreak1974 like this
#21 mclewis1
mclewis1
    Thread Killer
Posted 18 May 2016 - 10:19 AM
R2-D2 series? ....  :ohgeeze:
:lol:
  • Howie1 and Censustaker like this
#22 Censustaker
Censustaker
  • Loc: Utah
Posted 18 May 2016 - 11:14 AM
Apart from that - i've noticed the stars appear tighter on the R2 i have vs the existing model.
#23 Dragon Man
Dragon Man
Posted 18 May 2016 - 12:44 PM
They should be identical to the last model John. Same sensor with the same pixels size.  :waytogo:  11811
#24 CA Curtis 17
CA Curtis 17
  • Vendor Affiliate
  • Loc: California
Posted 18 May 2016 - 01:01 PM
I had the same reaction as Ken about the star size.
Curtis
#25 mclewis1
mclewis1
    Thread Killer
Posted 18 May 2016 - 01:25 PM
Very different DSP, which can have a big effect on star images.
  • Relativist likes this
