24mm TeleVue Panoptic...
181 replies to this topic
#1 Scanning4Comets
Scanning4Comets
    Markus, a.k.a. Scanning4Comets
Posted 26 May 2016 - 08:37 PM
Highly regarded in the astro-community. This eyepiece is quite "Legendary".
Going to give this a quick run tonight....
Edited by Cygnus2112, 27 May 2016 - 02:28 AM.
#2 Scanning4Comets
Scanning4Comets
Posted 27 May 2016 - 02:13 AM
Gave the 24mm Pan a quick go tonight.
Scope: 10" Skywatcher Dob. The mirror is really good for what it is. No coma correction was used. Here is a "brief" evaluation in less than ideal skies.
Sky transparency was poor. It was a great night for planets, but not for deep sky. I was able to try out the 24mm Pan in some sucker holes and also when the sky cleared out a bit above, but more nights will be needed with better transparency. I was going back and forth from my scope with the 24mm Pan, (and other eyepieces), to a friends 10" Teeter with Zambuto Optics on the planets. Mars was incredible tonight!
What I did note tonight was this:
Eye relief: Kind of tight, but not bad at all. Forget about using glasses if you need to when observing, as the field gets cut off when doing so. Otherwise, without glasses, I found the eye relief just right.
Sharpness: Excellent sharpness considering I don't use a coma corrector. It reminds me a lot of the 22mm LVW in the sharpness department. I tested it briefly on some stray star clusters.
Focus Point: In able to reach focus, I had to add more parfocal rings than my XW's. Focus point was probably just under 1/2" more than what I normally use.
Field Stop Sharpness: Razor sharp.
Weight: Light compared to my XW's
Barlow Factor: Vignetting with 2 inch, 1.85x barlow, but central area really sharp. I wouldn't use a barlow with this anyways as it will get me too close to a 14mm eyepiece, and I have a 14mm Delos for that.
Using with Filters:  It worked fine when I used my 2" Lumicon O-III and 2" Orion Ultrablock filters on it on The Lagoon Nebula....but again, need a better night with better transparency.
Edge Of Field Brightening: I could see some, but need to see if I can see it on a better night.
So far, so good. Skies were not optimal at all, so I will have to get back to it again when the skies are better for a full evaluation.
Edited by Cygnus2112, 27 May 2016 - 02:27 AM.
#3 MarkGregory
MarkGregory
  • Loc: Advance, North Carolina
Posted 27 May 2016 - 03:30 AM
Just ordered one to use with my Astro-Tech 111 and Tele Vue TV-85. You are correct, this is a legendary ocular. I have an engineer friend who has been attending the southern star party in Florida for years with his magnificant Tek telescope.  I asked him which eyepiece is his favorite....the Panoptic 24.
Edited by MarkGregory, 27 May 2016 - 03:31 AM.
#4 Scanning4Comets
Scanning4Comets
Posted 27 May 2016 - 04:09 AM
Now I am wondering......Which ocular has the better transmission? 24mm Panoptic? or 22mm Vixen LVW?
Hmmmmmm.......
:question:
#5 JoeBlow
JoeBlow
  • Loc: Australia
Posted 27 May 2016 - 04:35 AM
Hey Cygnus,
Nice initial report and looking forward to more. The transmission difference between the Pan and LVW will be very interesting to know. Can you please also compare the difference in tfov between the two eyepieces.
Joe
#6 Scanning4Comets
Scanning4Comets
Posted 27 May 2016 - 06:44 AM
http://www.cloudynig...m-lvw-with-f47/
http://www.iceinspac...ead.php?t=10352
#7 fishmike
fishmike
  • Loc: Watchung Reservation, NJ
Posted 27 May 2016 - 11:43 AM
fantastic EP. When I bought my Nextstar Evo I slipped this one in. Never looked back. A true workhorse. I later picked up a 31mmT5 and wondered if I would even need to 24. Lets just say it is still my starting EP for every session, and often it continues to be the workhorse. Its small size also makes it a great fit for the 2.5x powermate. That combo has delivered probably my planetary views ever.
#8 Oscar56
Oscar56
  • Loc: Summerland, BC
Posted 27 May 2016 - 11:56 AM
Finally ordered 2 of these for binoviewing.
#9 junomike
junomike
  • Loc: Ontario
Posted 27 May 2016 - 12:40 PM
Hmmmmmm.......
:question:
I tried both one evening but no sure If I did checked the transmission of each.  I did prefer the 24mm Pan as I recall.
#10 Tank
Tank
  • Loc: Stoney Creek, Ontario, CANADA
Posted 27 May 2016 - 02:18 PM
Great EP
Its a nice! :drool5:
#11 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 27 May 2016 - 03:11 PM
Hmmmmmm.......
:question:
The 24 Panoptic, but comparing them visually would be difficult since they would differ in exit pupil brightness by more than the difference in transmission.
#12 Scanning4Comets
Scanning4Comets
Posted 27 May 2016 - 03:28 PM
Hmmmmmm.......
:question:
I don't recall trying both?
#13 junomike
junomike
  • Loc: Ontario
Posted 27 May 2016 - 05:58 PM
Hmmmmmm.......
:question:
No you never did (at least with me) but I did one evening a few years back.
#14 Allan Wade
Allan Wade
  • Loc: Newcastle, Australia
Posted 27 May 2016 - 11:26 PM
You can use it with the eyeguard rolled down, and that provides plenty of eye relief. The original cap works as well that way.
#15 junomike
junomike
  • Loc: Ontario
Posted 28 May 2016 - 07:05 AM
Mark, Looks good.  Just be sure to keep all the OEM parts "in case" you eventually decide to part ways with it. :grin:
#16 Oscar56
Oscar56
Posted 28 May 2016 - 10:53 AM
Well, I couldn't wait until this week to try out this new way of using the 24mm Panoptic, so I tried it tonight through my back window. Conditions were ok, but not good enough to go outside, so I just checked out how it felt with the rubber eyecup removed.
Wow, what a difference! The 1-2mm gain in eye relief really does help a lot, and I also discovered that I can see the entire field while using my cheap reading glasses. The glasses *do* touch the housing, but they are not worth anything, so no bother there.
So, when I sketch, I can do it with my reading glasses using the 24mm Pan !!!! Without the reading glasses and without the rubber eyecup, the 24mm Pan is PERFECT !!!
I have that same dilemma.  I prefer to view naked eye, so ER of 14-15mm is fine.  But to sketch or view charts I need my reading glasses and swapping back and forth is a real pain.  Good to hear about your success with the Pan 24s.
When that Pentax XW 5 arrives I will be able to test my first 20mm ER eyepiece.  Then I will have to decide if shifting to 20mm ER eyepieces is my best solution.
#17 Starman1
Starman1
  • Loc: Los Angeles
Posted 28 May 2016 - 12:19 PM
I got a cheap set of readers from the drug store that have a spring-loaded temple piece.  They fit OK when I have only a cap on, and they spread and pinch in so I can actually wear them on the outside of a down parka hood.
I keep them on a lanyard around the neck and they go on and off my head 200 (or more) times a night (at least).  I can do it with one hand, but one could reasonably ask why I don't observe with glasses on.
1) no astigmatism in that eye, and just a tiny bit farsighted  No reason to wear glasses
2) my eye is deepset enough that, with glasses on, I'd need at least 20mm of Effective Eye Relief to use the eyepiece comfortably, and even 20mm eye relief eyepieces don't have that.
3) I like to roll my head over and look at the edge.  Very difficult to do so with glasses on.
4) No eyeglasses I've ever seen are completely free from distortion, chromatic aberration, internal reflection, or simply "aberration zones".  I've only owned about 60 pairs of glasses so far, and that's my experience.  Maybe yours is different.
Image quality ALWAYS suffers when using glasses.  I'd put up with that if I had to, but I don't have to.
5) If I'm wearing my everyday progressives, they're more expensive than an Ethos, so I have no desire to even allow for the possibility of scratching them, which could occur if they have to contact the top of the eyepiece hard in order to allow
me to see the entire field.  How in the world can 1 plastic lens, even with elaborate coatings, cost as much as a Paracorr, with 5 multi-coated lenses in a CNC-machined, anodized, aluminum housing?  Highway robbery.
6) not using glasses allows me to use any eyepiece there is (except a 4mm Plossl--I have no clue how a human could use one of those--the eye relief is shorter than the cornea-pupil distance in the eye! :lol: )
So, on and off my face they go a couple hundred times a night.  I've been doing that for the last 30+ years of observing, and I don't even think about it any more.
So careful--20mm of eye relief may not be quite enough to view with glasses on.
Edited by Starman1, 28 May 2016 - 12:21 PM.
#18 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 28 May 2016 - 12:42 PM
For you....there is the Televue 40mm plossl....... :cool:
#19 Oscar56
Oscar56
Posted 28 May 2016 - 02:07 PM
Don:
to paraphrase your response: GET OVER IT.
that is probably the best solution.  Apologies to Markus for steering this thread off course.
#20 Scanning4Comets
Scanning4Comets
Posted 28 May 2016 - 04:40 PM
Don:
:lol:
#21 Scanning4Comets
Scanning4Comets
Posted 28 May 2016 - 04:41 PM
I have a set of glasses on a lanyard too......just McGuyvered those up recently. On and off for me as well. LOL
#22 Kunama
Kunama
    Aussie at large
  • Loc: Garran, Australia
Posted 28 May 2016 - 05:17 PM
I tried having my glasses tied around my neck also but kept spilling the beer from them each time I put my hand to them so now I have my glasses in a cup holder on my Dobsonian.  Less spilt beer.......
Edit: We now return you to our previously advertised programs on Panoptic eyepieces.....
Nice custom work on the P24 Markus!
Edited by Kunama, 28 May 2016 - 05:18 PM.
#23 SteveG
SteveG
  • Loc: Seattle, WA
Posted 30 May 2016 - 04:34 PM
Some history of the Panoptic line below....I think I'm going to add the 22mm Pan to my collection and keep the 24mm as well.
http://www.cloudynig...ic#entry6966069
It's time to keep BUYING and stop SELLING. :lol:
I preferred the 22 Pan over the 24, due to its eye relief, which is very long if I recall. I used mine with a Dioptrx, which is useless on a Pan 24. The 22 is not as well corrected though. I did not get to test it with a Parcorr, which I've heard cleans it up nicely. My ultimate solution was a N22T4 (with Dioptrx).
#24 JimMo
JimMo
    I'd Rather Do It Myself
  • Loc: Under a huge light dome
Posted 31 May 2016 - 10:29 AM
Way back when I sold a 19 Pan to a local fellow who started a thread on astromart (back when the AM forums had more traffic) wondering what was wrong with the eyepiece I sold him.  It was his first wide-field eyepiece and I didn't discover the thread till a few weeks later when after many responses the conclusion was he was seeing the coma in his primary mirror for the first time.  I had a SCT at the time and it performed admirably.  Before he realized it was coma all kinds of speculation was offered from selling a bad eyepiece to taking the Pan apart and putting the lenses back in wrong.
My point?  A coma corrector it a valuable piece of kit that makes your newt perform like a really big APO.  Have you ever tried one Mark?  I can't use my f4.3 scope without it and stars are pinpoints to the edge of even 100ยบ eyepieces.
Edited by JimMo, 31 May 2016 - 10:32 AM.
#25 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 31 May 2016 - 11:23 AM
Just me, sometimes I use the paracorr, mostly not.  I'm not bothered by coma that much. I also don't use low power widefields on planets either...
