Verdict on 1.25" filters with ASI1600?
5 replies to this topic
#1 RafaelP
RafaelP
Posted 07 July 2016 - 09:33 AM
Yes, another ASI1600 thread. I did a search, and couldn't find a definitive answer.
I have a F/4 Borg and would like to use my (pricy!)1.25" filters with the ASI1600. I would be using Xagyl 1.25" filter wheel, which has 19mm of backfocus.
Any thoughts or experiences on amounts of vignetting with 1.25" filters and scopes faster than F/5?
Rafael
#2 bigeastro
bigeastro
Posted 07 July 2016 - 09:47 AM
I also have an F/4 Borg and the exact same setup you indicate.  I have the 77ED with the super reducer.  I think it gets me to f/4. You will get vignetting but not much.  You need to purchase the .8mm precise parts adapter in order to minimize the vignetting.  I am at the edge of vignetting at f6.7 with the precise parts adapter.  There is none on my setup, but when adjusting the filter wheel so it is perfectly centered I can see the cone drop off when I shift the filter either way.  As a result I suspect that f/6 is about as low as you can go with the 1.25" filters with no or tiny vignetting.
Hope this helps.
#3 happylimpet
happylimpet
Posted 07 July 2016 - 10:44 AM
At 12" f4.5, my Halpha flat that Im looking at drops by ~12-15% at the top and bottom edges, and by 30% very suddenly in the far corners. Should be fine.
EDIT Just remembered I have a coma corrector that makes me f4.5 , not f5. How much of a role this plays I couldnt say.
Edited by happylimpet, 07 July 2016 - 10:44 AM.
#4 happylimpet
happylimpet
Posted 07 July 2016 - 02:02 PM
Flat.
#5 bigeastro
bigeastro
Posted 07 July 2016 - 02:05 PM
Very nice result with 1.25" filters
#6 Jon Rista
Jon Rista
Posted 07 July 2016 - 02:13 PM
There is a small amount of vignetting with 1.25" filters with my 600mm f/4 Canon lens, but not much. I already get some vignetting with that lens anyway because I use the lens hood, which introduces some vignetting of it's own.
