Carry Handle for my Astro-Physics Telescopes
10 replies to this topic
#1 Rocket Ron
Rocket Ron
Posted 09 July 2016 - 08:12 PM
I've always wanted to have a carry handle on my AP telescopes, and I figured out a way to do it.
#2 Rocket Ron
Rocket Ron
Posted 09 July 2016 - 08:17 PM
My AP scope has an accessory plate on top, which takes an AP 10-inch slider.  I've been using the slider to attach guidescopes to.
I found a very durable plastic handle that is used as a safety handle for children's playgound equipment.  I was able to attach this handle to the 10-inch slider with 4 screws.
#3 Rocket Ron
Rocket Ron
Posted 09 July 2016 - 08:19 PM
The slider then slides into the accessory plate on top.  It works great! It handles the weight with no problem.  The total weight of the scope with rings & plates is about 25 pounds.
#4 Rocket Ron
Rocket Ron
Posted 09 July 2016 - 08:20 PM
Since my Traveler also has an accessory plate for the same 10-inch slider, the handle works for my Traveler too.
Edited by Rocket Ron, 09 July 2016 - 08:23 PM.
#5 Traveler
Traveler
Posted 10 July 2016 - 02:35 AM
I use the accessory plate as the handeling bar for my Traveler ;)
#6 RAKing
RAKing
Posted 10 July 2016 - 09:12 AM
Yup, that's all I need for my Traveler, too.
Over the years, there have been numerous threads here on CN about handles for scopes.  I use electronics rack handles on my scopes. They are anodized aluminum and carry the load quite well.
Ron
#7 Paul G
Paul G
Posted 10 July 2016 - 09:50 AM
Same here. On larger scopes I have a D plate on the top of the rings serving as the handle.
#8 Rocket Ron
Rocket Ron
Posted 10 July 2016 - 03:17 PM
True.  The Traveler though is compact and light, and really doesn't need a carry handle.  The handle I came up was primarily for my bigger AP 130mm GT, which just also happened to fit on the Traveler.
#9 wacopsc
wacopsc
Posted 10 July 2016 - 04:44 PM
TEC makes the best handle available, elegant design and not expensive. 9 and 12 inch
regards, Paul
#10 Rocket Ron
Rocket Ron
Posted 10 July 2016 - 08:33 PM
Here's where I bought my handles on amazon
https://www.amazon.com/dp/B000BQYBGM/
It comes with 2 handles, 4 wood screws and 4 washers.  I didn't used the included screws and instead used hex screws which I bought at a local hardware store.
Edited by Rocket Ron, 10 July 2016 - 08:34 PM.
#11 Rocket Ron
Rocket Ron
Posted 10 July 2016 - 08:38 PM
I used 4 1/4-inch hex screws and also added 2 wing nuts.  Here's how they were screwed into the slider. The slider is the Astro-Physics Dovetail 10-inch sliding bar (SB1000).
Edited by Rocket Ron, 10 July 2016 - 08:38 PM.
