New open project “Astronomy Linux”
469 replies to this topic
#451 Oleg Astro
Oleg Astro
    Astronomy Linux
  • Loc: Albufeira, Portugal
Posted 11 March 2021 - 09:47 AM
You can use Entan
Do you know how to download the driver for usb grabber (STK1160 chip)?
Greetings. Andy
I don't know. Maybe this can help you...
Stk1160 based USB 2.0 video and audio capture devices
#452 SP3UCA
SP3UCA
  • Loc: KONIN
Posted 11 March 2021 - 02:06 PM
Oleg have problem :
On step : sudo apt install libgphoto2
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libgphoto2
I see in system is only "libgphoto2-6"
can't find and add libgphoto2 package via synaptic...
maybe from terminal but I dont know how.
Andy
#453 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 11 March 2021 - 02:51 PM
sudo apt install libgphoto2-6
#454 SP3UCA
SP3UCA
  • Loc: KONIN
Posted 12 March 2021 - 03:35 AM
OK. Working.
But next is same problem :
cmake -DCMAKE_BUILD_TYPE=Release ..
-- Checking for module 'libgphoto2>=2.4.10'
--   No package 'libgphoto2' found
Andy
#455 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 12 March 2021 - 06:00 AM
Andy,
when we receive such messages after installing libraries, it may mean that compiling the program also requires their ...-dev packages.
sudo apt install libgphoto2-dev
#456 SP3UCA
SP3UCA
  • Loc: KONIN
Posted 12 March 2021 - 11:35 AM
GREAT !!!
Working.
Thank You !!!
Andy
#457 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 15 May 2021 - 09:21 AM
What astronomical software do you need in Astronomy Linux 21.04?
Edited by Oleg Astro, 15 May 2021 - 09:24 AM.
  • brave_ulysses likes this
#458 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 15 May 2021 - 09:23 AM
More images
#459 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 19 May 2021 - 05:47 AM
Uruk_One is already added to Astronomy Linux 21.04
"Uruk_One is neither a Planetarium, nor a user-friendly software for a novice amateur astronomer whose aim is just to see how the night sky appears tonight. Uruk_One is aimed at experienced astronomers who study past, present and future astronomical events, historians searching for a correlation between historical and astronomical events, verification of ancient reports about eclipses and so on. For the same reason this software does not include capabilities of controlling telescopes."
  • AaronF likes this
#460 daw316
daw316
Posted 20 May 2021 - 08:45 AM
What is the latest beta?
Thx!
#461 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 22 May 2021 - 06:18 AM
is ready for downloads and tests.
#462 boxcorner
boxcorner
  • Loc: France 45.29,2.22 (Bortle 3)
Posted 24 May 2021 - 05:18 AM
Oleg, what an amazing thread this is. Thank you for creating it and sharing so much valuable information.
My OS is Linux Kubuntu 20.04
I am considering getting a PoleMaster, so I installed PoleMaster_Qt 1.3.5 which created an entry in the application launcher, with an icon for the camera. When I click on it, nothing happens.
When I right-click on the launcher entry > click on Edit application > click on Application tab > I see that the Command is:
bash /usr/bin/PoleMaster/PoleMaster.sh
So, from a terminal (I use Guake Indicator), when I do this:
cd /usr/bin/PoleMaster
dir
I can see lib files, etc plus PoleMaster.sh and also PoleMaster.ini
when I do this:
I get this:
/usr/bin/PoleMaster/PoleMaster.sh: line 12:  3182 Illegal instruction     (core dumped) $dirname/$appname "$@"
Opening PoleMaster.sh in Kate, I see that line 12 is this:
Have you come aross this issue before? What do I need to do to get this app running, do you know?
Edited by boxcorner, 24 May 2021 - 09:58 AM.
#463 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 24 May 2021 - 06:37 AM
Who has already downloaded  astronomy-21.04.0-2021.05.21-desktop-amd64.iso?
It has bad sources.list
#464 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 24 May 2021 - 06:39 AM
When I right-click on the launcher entry > click on Edit application > click on Application tab > I see that the Command is: bash /usr/bin/PoleMaster/PoleMaster.sh
So, from a terminal (Guake Indicator), when I do this:
dir
when I do this:
I get this:
I have other problem with PoleMaster:
$ ./PoleMaster.sh
Inconsistency detected by ld.so: dl-call-libc-early-init.c: 37: _dl_call_libc_early_init: Assertion `sym != NULL' failed!
  • boxcorner likes this
#465 boxcorner
boxcorner
Posted 24 May 2021 - 09:37 AM
$ ./PoleMaster.sh
Ah ha! I've got it working now. I found this https://www.qhyccd.c...hp?topic=6782.0 very helpful.
So, from a terminal, to check if any libraries are missing, type
ldd PoleMaster
Then scroll up through the list of libraries, to see which ones are missing. I installed the libraries that were missing like this
sudo cp /usr/bin/PoleMaster/libqhy.so.1 /usr/lib/x86_64-linux-gnu
sudo cp /usr/bin/PoleMaster/libopencv_core.so.2.4 /usr/lib/x86_64-linux-gnu
sudo cp /usr/bin/PoleMaster/libopencv_imgproc.so.2.4 /usr/lib/x86_64-linux-gnu
ldconfig -n -v /usr/lib
Now I can start PoleMaster, like this
sudo /usr/bin/PoleMaster/PoleMaster
In order to be able to start PoleMaster using the Application Launcher (from the KDE Plasma GUI, in Kubuntu), right-click on the PoleMaster icon > click on Edit Application > click on the Application tab > then change the Command from
to this
finally, click on OK to save the change. Now I can start PoleMaster by clicking on the icon. Like so many other things, simple when you know how.
Edited by boxcorner, 24 May 2021 - 10:06 AM.
#466 boxcorner
boxcorner
Posted 17 June 2021 - 05:48 AM
Well the Linux version of the PoleMaster app, PoleMaster_Qt, seems to run okay, but ...
now I have a PoleMaster camera, with it connected via its USB cable, when I click on Device > Connect
a notification window entitled Info pops up, displaying the message: 'Not Found QHYCCD PoleMaster equipmment'
So, apparently the Linux driver doesn't work, as the app doesn't connect to the camera.
The notebook computer I am using is configured to dual boot Linux and Windows 7.
So, I have installed the PoleMaster app and driver for Windows and that seems to work fine.
Similarly, I have a NUC computer (Linux only), with the PoleMaster_Qt app installed.
The app seems to run okay, but with the camera connected via USB,
when I click on Device > Connect, I get the same 'Not Found' message.
Has anyone else experienced this problem? Does anyone know how to get a driver for Linux to work?
Notice that on QHYCCD's download page https://www.qhyccd.com/download.html
in the PoleMaster section for Windows there is a separate download for the driver, which I installed.
However, the LINUX Deb section does not list a separate driver.
Edited by boxcorner, 17 June 2021 - 07:06 AM.
#467 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 17 June 2021 - 09:32 AM
Maybe Polemaster can't found installed driver...
Read more about QHY CCD & Filter Wheel
#468 boxcorner
boxcorner
Posted 25 June 2021 - 12:02 PM
Thanks. In fact it turns out that the driver was missing.  Whilst I had installed .deb file, what I didn't realize is that I should have also downloaded the SDK from QHYCCD's website, as it includes the driver! I expected the driver to be included in the .deb file. When I saw SDK on their downloads page, I thought it was intended for developers (ie Software Development Kit). The SDK includes a file called install.sh which has to be executed, to install the driver. If anyone needs information on how to do this then let me know and I will gladly do what I can to help them. So, I now have the PoleMaster working with Linux Kubuntu 20.04 on my NUC and Kubuntu 20.04 on my Toshiba notebook. The SDK file is called sdk_linux64_21.03.13.tgz so it looks like it was last updated on 13th March. I have found support from QHYCCD to be excellent and would like to thank them for their time, patience and help. Now I just need clear skies to test it with starlight.
#469 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 22 July 2021 - 02:36 PM
Who has any recommendation for the project?...
#470 daw316
daw316
Posted Yesterday, 09:15 AM
>>recommendation?
A slightly smaller version that for sure fits on a dvd for OG's with old hardware.
Love the distro!
