iAstroHub 3.0: IoT for Astrophotography
540 replies to this topic
#1 anat
anat
    iAstroHub 3
  • Freeware Developers
Posted 30 September 2016 - 06:42 PM
iAstroHub is the world's first mobile and IoT platform for astrophotography. A user can interact with all astrophotography devices from any mobile device using only a web browser. iAstroHub is a software package embedded in ARM Linux platforms. This project has been developed on various platforms for more than 4 years as you see in the forum (Thanks to 1300+ replies and 150,000+ views ^0^ ). Now, Raspberry Pi 3 (RPi3) is used for iAstroHub 3.0.
Features:
- only need a web browser on a mobile device to control everything! ( "i" stands for internet)
- control an autoguider
- control a DSLR camera (Canon, Nikon, and Pentax)
- control DSLR setting and Liveview via qDslrDashboard
- control a CCD camera and a filter wheel for imaging (almost all brands are supported)
- control a focuser
- control Flip-Flat for flat-fielder and lens cover
- show real-time guiding error graphs and alert logs
- preview images taken by a camera
- perform dithering between frames
- manipulate histogram of images from a CCD camera
- perform plate-solving using the standalone Astrometry.net engine
- re-align mount based on the position from plate solving
- show skychart and control mount from built-in Skychart (Cartes du Ciel)
- show a plate-solving result directly in Skysafari and re-align the mount from Skysafari
- support the control of a mount from Skysafari on iOS and Android
- save all images on a USB flash drive
- speak imaging progress
- push notification to smart phones or smart watches
- low power consumption
- small enough to be installed on the telescope
- open-source software
What's new in iAstroHub 3.0?
- Native CCD control for QSI, SX, SBIG,  ATIK, and QHY cameras.
- Support INDI-compatible camera and devices. You can control almost all astro devices from the web browser now
- Pushover notification: So you will get a notification to a smart phone/watch when the imaging sequence is completed or the guiding error exceeds a certain threshold. RPi3 needs to connect to internet via Ethernet or Mobile hotspot (USB tethering from a smartphone)
- More support for autoguiders (using Linguider 3.3.0)
- RPI3 speaks! The imaging progress can be reported.
- Mount control: LX200, iOptron, Nexstar/Skywatcher, TheSkyX+Paramount
- Web-based VNC: So there is no need to use a PC for initial setup.
- Upgrade is easy now. Simply insert a USB drive and press "Upload patch"
- The 38-page manual is now included :)
Supported Hardware:
Autoguiders
Orion Starshoot autoguider, QHY5, QHY5-II, QHY5L-II, QHY6, ATIK, Starlight Xpress, ZWO ASI cameras
DSLR Cameras
Canon (since 300D) and Nikon (since D50) DSLR cameras. Pentax DSLR cameras (Refer to http://pktriggercord.melda.info/)
CCD Cameras and Filter Wheels
Native control with GoQat: QSI and Starlight Xpress
Native control with OpenSkyImager: SBIG, ATIK, and QHY (5, 5ii, 6, 8, 8L, 9, 10, 11,12, IC8300
INDI driver: FLI, Apogee, Moravian, ATIK, ZWO ASI, SX, SBIG, QSI, etc.
Mounts
Controlled by Skychart: mounts using LX200, iOptron, Nexstar/Skywatcher, TheSkyX protocols
Controlled by SkySafari: Almost all mounts are supported. Refer to http://skysafariastronomy.com/
Focusers
Native control: Robofocus
INDI driver: Robofocus, Moonlite, FocusLynx, etc.
Manual:
With the great help from THX59, the manual is included with the package. I provide both PDF and MS Word format. If you have any comment on the Manual, please edit it with tracked changes and send me.
Feel free to translate the manual. Please add "Translated to .... by ..." between the original authors' names and the date on the first page. Keep the original date of the manual so that it is easy to track the revision.
Download:
https://drive.google...cEE?usp=sharing
Eveything is bundled in a single file (.7z). Uncompress the file using 7zip. 7zip is used because of the best compression ratio. The file size is 5.2GB :) Inside the package, you will see 1) the image file, 2) Manuals in PDF and MS Word formats, and 3) A folder of source codes and instruction
Read the manual and enjoy iAstroHub 3.0 !
Anat
#2 anat
anat
    iAstroHub 3
Posted 30 September 2016 - 06:46 PM
While downloading the iAstroHub3.0 package, download and read the manual
https://drive.google...iew?usp=sharing
Anat
#3 Chote
Chote
Posted 30 September 2016 - 09:40 PM
Excellent work.
#4 Mr.Coffee
Mr.Coffee
Posted 01 October 2016 - 12:31 AM
Thanks, it is great!
#5 tango13
tango13
Posted 01 October 2016 - 03:49 AM
Excellent, excellent work Anat!!!
Thank you
Piero
#6 sampson
sampson
Posted 01 October 2016 - 07:55 AM
Thank you  :waytogo:  :flowerred:
#7 Mikele
Mikele
Posted 01 October 2016 - 08:40 AM
Amazing! Thank you!
#8 gapperns
gapperns
Posted 01 October 2016 - 07:41 PM
Unfortunately, I seem to be having a problem with 3.0. Using a Nikon D800 connected via USB in manual mode, Bulb exposure, Raw + Jpeg basic. I have started dslrdashboard server from the admin page, and am able to control the camera from qdslrdashboard. When I try from the dslr main web page, I see it display, "Frame 1 of 1 completed", "Frame 1 of 1 exposing 1/1 s", "Downloading...", "No JPG file!", "Ready to capture images." (in that sequence).  The shutter is not activated from the web interface.
If I take a photo with qdslrdashboard, then go back to the web page, and request a photo, it displays the same message sequence except that it ends with "Downloaded." but in this case it is the photo that was taken earlier in qdslrdashboard.
Version RPi3_step22 did work for me.
Can anyone see what I'm doing wrong?
  Jerry
Edited by gapperns, 01 October 2016 - 07:43 PM.
#9 anat
anat
    iAstroHub 3
Posted 01 October 2016 - 08:19 PM
Jerry,
Make sure you
1) select the DSLR protocol in the Admin page to "Nikon".
2) stop the DslrDashboard server before using the web interface.
If still having the error, please run this command in MobaXterm
sudo gphoto2 --set-config bulb=1 --wait-event=10s --set-config bulb=0 --wait-event=2s
Does the shutter open and close? Send me the screen output.
> I didn't change anything for Nikon Control.
Anat
Edited by anat, 01 October 2016 - 09:51 PM.
#10 tango13
tango13
Posted 02 October 2016 - 10:45 AM
Hi Anat,
playing a little bit in house with the new release :waytogo:
I have an Astrolumina Alccd8l (equivalent to the QHY8L) and one thing I noticed is that it wasn't recognized by the system out of the box because of a missing line in /etc/udev/rules.d/85-qhy.rules.
The missing line is
ATTRS{idVendor}=="1618", ATTRS{idProduct}=="6005", RUN+="/sbin/fxload -t fx2lp -I /etc/qhyccd/qhy8l.hex -D $env{DEVNAME}"
After adding that line, the CCD is correctly recognized
Oct  1 11:54:14 iAstroHub kernel: [    7.850276] usb 1-1.4: New USB device found, idVendor=1618, idProduct=6005
Oct  1 11:54:14 iAstroHub kernel: [    7.850292] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct  1 11:54:14 iAstroHub kernel: [    7.850304] usb 1-1.4: Product: QHY-8L
Oct  1 11:54:14 iAstroHub kernel: [    7.850316] usb 1-1.4: Manufacturer: QHY-CCD
Thank you.
Piero
#11 anat
anat
    iAstroHub 3
Posted 02 October 2016 - 12:51 PM
Piero
Thanks. Can you use OpenSkyImager to control the camera?
Anat
#12 gapperns
gapperns
Posted 02 October 2016 - 05:42 PM
Jerry,
Make sure you
Anat
Hi Anat,
I didn't know about shutting down dslrdashboard server after using qdslrdashboard, but that didn't seem to help. I have selected "Nikon".
using MacTerm to the iAstrohub...
root@iAstroHub:~# sudo gphoto2 --set-config bulb=1 --wait-event=10s --set-config
gphoto2: symbol lookup error: gphoto2: undefined symbol: gp_camera_get_single_co
nfig
#13 anat
anat
    iAstroHub 3
Posted 02 October 2016 - 07:15 PM
Try running the web interface without using qDSLRdashboard first. Does it work?
Next, please run
sudo gphoto2 -v
sudo gphoto2 --auto-detect
sudo gphoto2 -L
Then use the SD card with iAstroHub 2.2 and run
sudo gphoto2 -v
sudo gphoto2 -L
Type the commands into the console by yourself. Don't copy and paste.
Anat
Edited by anat, 02 October 2016 - 07:22 PM.
#14 anat
anat
    iAstroHub 3
Posted 02 October 2016 - 09:15 PM
Please ignore my previous post. I found the reason
http://gphoto-softwa...ig-td16208.html
The latest gphtoo2 2.5.10 needs the latest libgphoto2. I will send the patch very soon.
Anat
#15 Mr.Coffee
Mr.Coffee
Posted 03 October 2016 - 04:19 AM
Hi, Anat, thanks for your work. I just want to know did you upload the source code in https://sourceforge....ects/iastrohub/ for the 3.0 version? thanks!
#16 Mr.Coffee
Mr.Coffee
Posted 03 October 2016 - 04:24 AM
dear, I have to say the image "https://drive.google...cEE?usp=sharing" is not available for Chinese astrophotography society. It is a pity. So could you please provide the other available link? Thanks a lot.
#17 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 04:27 AM
The source code is bundled with .7z file. The sourceforge site will be updated soon.
Anat
#18 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 04:29 AM
Which cloud drive can you access?
Anat
#19 Giacomoa
Giacomoa
Posted 03 October 2016 - 08:22 AM
 Dear Anat,
playing with the new release ,p3
I have an CCD orion Star Shoot G3 mono and one thing I noticed is that it wasn't recognized by the system .
Help me..thanks...
Inviato dal mio M-IPRO7 utilizzando Tapatalk
#20 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 09:55 AM
Plesae get the patch (30MB) from:
https://drive.google...U3RTd2FSckVycEE
Steps:
1. Uncompress the files to a USB flash drive (FAT32 format). For example, patch.sh must be at the root directory of the drive.
2. Press "Upload Patch from USB Flash Driver" on the Admin page
3. After about 2-3 sec, Refresh the Admin page once (because the Admin page is patched also)
4. Press "Upload Status" to see the progress
5. Wait until "DONE". It may take about 20 mins.
Patch Log (as of Oct 3, 2016)
1. Update Admin page
- correct a contributor's name
- clarify that "GREEN LED" will be off when shutting down
- Upload Status is revised.
2. Edit INDI Control Panel: Click "Connect" to establish the link
3. Update gphoto2/libgphoto2 to version 2.5.10
4. Update udev rules file to support Astrolumina Alccd8l
Edited by anat, 03 October 2016 - 02:10 PM.
#21 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 09:59 AM
 Dear Anat,
Help me..thanks...
Sorry that Orion G3 CCD camera is not supported.
#22 gapperns
gapperns
Posted 03 October 2016 - 12:39 PM
Hi Anat,
So the update did not appear to update for me. Can the USB stick be a MS-DOS fat 16 format? The nested folder was copied so that patch.sh is at the root.
I never saw an Upload Status button, the File Status button remained and reported done. The "Finished, Enjoy it" etc. text did not appear. Is there a was to determine that the patch happened other than visual display on the Admin page, or a way to determine that the USB drive mounted?
  Jerry
Edited by gapperns, 03 October 2016 - 01:27 PM.
#23 gapperns
gapperns
Posted 03 October 2016 - 12:53 PM
To answer my own question. I reformatted the drive to FAT32 and it appears to be progressing quite well as it should. Thank you Anat. Sorry for the noise...
Update finished successfully and the Nikon D800 now works.
Thanks again   Anat.
Jerry
Edited by gapperns, 03 October 2016 - 01:29 PM.
#24 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 02:14 PM
Jerry.
Good to hear that :)
Anat
#25 Oleg Astro
Oleg Astro
    Astronomy Linux
Posted 03 October 2016 - 03:16 PM
What are the login and password for ssh connection?
