iAstroHub 3.0: IoT for Astrophotography
540 replies to this topic
#26 anat
anat
    iAstroHub 3
Posted 03 October 2016 - 04:57 PM
What are the login and password for ssh connection?
username: root   or   pi
password: raspberry
#27 tango13
tango13
  • Loc: Rome, Italy
Posted 04 October 2016 - 02:30 AM
Thanks. Can you use OpenSkyImager to control the camera?
Yes, it works as expected.
Thank you
Piero
#28 indoforever
indoforever
Posted 04 October 2016 - 08:28 AM
hello I have a problem I have download iastrohub 2.2 rpi 3 AC works fine but I want to install version 3.0 iastrohub there is failure on the sd card is empty you'd have a solution thank you
#29 anat
anat
    iAstroHub 3
Posted 04 October 2016 - 08:30 AM
Make sure that the card is 16GB in capacity. I recommend Sandisk Ultra.
Anat
#30 indoforever
indoforever
Posted 04 October 2016 - 08:36 AM
thank you for the quick answer my card is 16 gigabytes but kingston brand
#31 anat
anat
    iAstroHub 3
Posted 04 October 2016 - 08:55 AM
Please try a different card. If possible get Sandisk ultra.
Anat
#32 drew2578
drew2578
  • Loc: Bothell, WA
Posted 05 October 2016 - 06:35 AM
What is the recommended Raspberry pi 3 hardware?
#33 anat
anat
    iAstroHub 3
Posted 05 October 2016 - 06:41 AM
RPi3 :)
FLIRC case: https://flirc.tv/mor...spberry-pi-case
16GB Class10 micro SD card (SanDisk Ultra)
Anat
#34 Mr.Coffee
Mr.Coffee
Posted 05 October 2016 - 10:07 PM
dear, I have to say the image "https://drive.google...cEE?usp=sharing" is not available for Chinese astrophotography society. It is a pity. So could you please provide the other available link? Thanks a lot.
Which cloud drive can you access?
Anat
Thanks for your reply! Could you please use "https://pan.baidu.com/" which is very popular in China.
#35 tango13
tango13
  • Loc: Rome, Italy
Posted 06 October 2016 - 02:30 AM
I have a Sandisk Extreme and you're right, it works like a champ.
Actually I have a 32GB card and I had to run raspi-config and choose option 1 "Expand Filesystem" to use the card to its full capacity.
Thank you.
Piero
#36 tango13
tango13
  • Loc: Rome, Italy
Posted 06 October 2016 - 02:45 AM
Hi Anat,
I'm still playing a bit with the new release and I'd like to tell you that once again you've done a terrific job, the improvements are real!
However, one thing I believe it's a little overlooked also from the previous releases (which doesn't do justice to the powerful engine under the hood) is the user interface which, in my opinion, is a little too messy and confusing, especially in the main and admin pages.
As I already did with previous versions, I have modified my local installation by adding tabs which, I believe, give much more clarity to the user interface.
Also, since I use iAH on a tablet, having larger buttons and controls improves usability.
Maybe a possible future improvement to iAH could be to add UI skins, what do you think?
Attached you can see my present modifications so far, still working on it.
Thank you.
Piero
  • anat and Mikele like this
#37 anat
anat
    iAstroHub 3
Posted 06 October 2016 - 02:58 AM
Hi Anat,
Thank you.
Piero
Hi Piero,
Wow. It looks nice. I am sorry that I missed your UI in the last update.
Would you be able to update the iAH 3.0 interface to the UI style you made? It would be much more user friendly.  Please look for iAstroHub_*.html and admin.php :)
I will be happy to make the patch or upgrade the whole image.
Thank you.
Anat
Edited by anat, 06 October 2016 - 02:19 PM.
#38 Mr.Coffee
Mr.Coffee
Posted 07 October 2016 - 01:08 AM
Hi Anat,
Thank you.
Piero
Wow, this UI is really nice, I like it!
#39 Dennis Sakva
Dennis Sakva
  • Loc: Kiev, Ukraine
Posted 07 October 2016 - 01:23 AM
Wow! What an awesome project!
I have a quick question. Will I be able to guide a mount with guider port only (Like Synta Star Adventurer) using Lodestar on-board guider port?
Sky Adventurer Mount
http://ca.skywatcher...tail.php?sid=68
Lodestar
https://www.sxccd.co...star-autoguider
#40 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 01:38 AM
Lodestar
Yes. It was tested on staradventurer. You only select one axis in Linguider. It is explained in the manual.
Sent from my SM-G930F using Tapatalk
  • Dennis Sakva likes this
#41 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 04:04 AM
For users who want to download from baidu, you can get the iAstroHub image file, patch, and manual from
http://pan.baidu.com/s/1c1XVyH6  password:pjg4
Thanks to "Mr.Coffee".
#42 pepe.lombris
pepe.lombris
Posted 07 October 2016 - 06:26 AM
Dear Anat!
Thank you so very much for all your hard work and sharing this awesome product !!! iAstrohub will definetly help me a lot in astrophotography.
There is one thing I am struggeling with though and I wonder if iAH could help with polar alignment.
Sharcap 2.9 includes a handy polar alignment routine that works nicely with my standard autoguider + viewfinder combo (see http://www.sharpcap....polar-alignment). This tool was inspired by the PhotoPolarAlign application created by Themos Tsikas. The source code can be downloaded here: https://github.com/T...PhotoPolarAlign
Do you think this could be included into iAH as well?
Clear skies
Stephan
#43 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 07:02 AM
Dear Anat!
Clear skies
Stephan
Stephan
I have been thinking about ways to assist polar alignment using iAstroHub.  Thanks for stirring up the idea again :)  After finishing patches of iAstroHub 3.0, PolarAlign will be the top of my todo list.
Anat
#44 pepe.lombris
pepe.lombris
Posted 07 October 2016 - 01:40 PM
Dear Anat!
This is good news! Please let me know if I can help with testing.
Best regards
Stephan
  • anat likes this
#45 chaoticaffinity
chaoticaffinity
  • Loc: Alabama
Posted 07 October 2016 - 01:43 PM
Does the current version of IAH support connecting to the mount via Serial over TCP .  Ideally I would like to connect scope hand controller to skyfi or just use skyqlink  and then connect the IAH to that via wifi and then connect to the IAH via Skysafari . This way i can mount all the imaging equipment (RPi3, Powered USB Hub, DewContoller,  Power Distribution, Focus Controller, Flat EL Panel Inverter)  on a dovetail on the top of the scope and only need to run 1 12v power cable up to the top.  This would minimize cable lengths and allow for using the  dovetail for extra balance on my C8 since it tend to lean rear heavy.
#46 amell
amell
Posted 07 October 2016 - 01:44 PM
My Pi just arrived and looking forward to installing this. One question which doesn't seem to be covered in the manual - does this support Altair Astro GPCAM/GPCAM2 for guiding which is very popular in the UK?
Polar alignment assistance will be very helpful to me as I don't have a view of Polaris from my normal observation location.
Sent from my iPhone using Tapatalk
#47 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 05:37 PM
Yes. iAH talked with Skysafari from Day1 :)
Use Port 3300 and IP address 10.0.0.1.  And use Port 3301 for Tak Temma.
Anat
#48 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 05:43 PM
It looks very much like QHY5Lii. Can you confirm that it is manufactured by QHY?  If yes, it will work with iAstroHub. Maybe, we need to add the device in the udev rules file.
Please insert the camera and use these commands:
lsusb
dmesg
And send me the screen output.
Anat
#49 anat
anat
    iAstroHub 3
Posted 07 October 2016 - 06:11 PM
This answers my own question
http://qhyccd.com/bb...hp?topic=5023.0
  • amell likes this
#50 drew2578
drew2578
  • Loc: Bothell, WA
Posted 07 October 2016 - 06:12 PM
RPi3 :)
Anat
Would that include Pi 3 model B?
