ZWO ASI071MC-Cool Beta Test
246 replies to this topic
#226 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 08 February 2017 - 08:57 PM
Mono will always have the advantage. What I am saying is, I think OSC cameras are perfectly viable in yellow or darker zones, while in orange or brighter zones, they are actually more trouble than they are worth.
Mono has not only the advantage of being more efficient (period, even at a dark site), but also being compatible with NB filters. That makes them more flexible as well as more efficient.
I just have a hard time recommending OSC to anyone in a light polluted zone. I've had more than enough experience with OSC in a red zone (which depending on the time of year and atmospheric conditions, can vary from an orange zone to a white zone), and if you want to create pretty pictures, LP just destroys OSC data and it requires EXCESSIVE integration to overcome that. With mono, you still have to overcome LP, but the more efficient sensor makes it a lot easier...and if there is anything beginners need, it's easier. ;)
#227 gujarbhai
gujarbhai
  • Loc: Hillsboro, Oregon
Posted 08 February 2017 - 09:07 PM
Thank you Jon.
#228 Tsarbomba
Tsarbomba
  • Loc: Courtice, Ontario, Canada
Posted 09 February 2017 - 03:03 PM
I just pulled the trigger on the ASI1600MM-Cool with the filter wheel and filter set  :D  This will be my first foray into mono/NB imaging, and I can't wait! I think learning with a modded DSLR has taught me a lot, especially on the processing end of things. But I live in red/yellow zone, so I can't wait to see the difference.
  • StarMike8SE likes this
#229 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 09 February 2017 - 03:15 PM
Congrats!
Those two zones are separated by orange. :p You could be in a red/white, or red/orange but it's pretty tough to be in a red/yellow. :p If you do indeed live in a yellow zone, the ASI071 would likely have been pretty nice. If you live in a red zone, then I definitely think you made the right choice going with mono.
#230 entilza
entilza
  • Loc: Oakville, ON, Canada
Posted 10 February 2017 - 08:09 PM
Could someone try an Ha test with this camera?  I realize it's not a mono camera but with the results Shawnmar has got with his OSC camera and Ha filter, it makes me wonder how this camera would perform with an Ha filter?  I've also seen many full spectrum DSLR's perform quite well with an Ha filter.
  • cyber likes this
#231 Jesus Magdalena
Jesus Magdalena
  • Loc: Madrid, España
Posted 06 March 2017 - 11:15 AM
Excuse my English, I use the translator
Here is a sample of M42 with 30X300 "Ha plus RGB
0d15520efcdc857ebef8fcb08719d72a.1824x0_
  • StarMike8SE, premk19, gundark and 3 others like this
#232 Glutch
Glutch
  • Loc: North Richland Hills Texas
Posted 06 March 2017 - 11:22 AM
Dan, one thing to note. You are in a yellow zone. That gives you a BIG advantage in using an OSC camera. Yellow zones are pretty good...LP is more balanced with light from space and airglow, so it isn't overpowering. Your Orion nebula image demonstrates that...it's low noise, very clean with minimal gradients. My dark site is in a green zone near the border of a yellow zone, and sometimes sky brightness goes below 20.8mag/sq" (definite yellow zone)...and the results are still orders of (stellar) magnitude better than my red/white zone back yard (literally.)
For people in a yellow zone, and certainly green or darker, I think OSC cameras work great. They can definitely support a simpler workflow. I think people who live in an orange, red, pink or white zone really need to pause before they pull the trigger on an OSC camera, because LRGB, even if the equipment is a little more to learn up front, is going to be capable of delivering usable results without all the frustrations with nasty gradients and the like that you would have with OSC. Not everyone is lucky enough to have the kind of darker skies that a yellow zone offers, and for so many living in a red zone (most suburbanites), OSC data can be a frustrating mess more often than not.
Jon, won't the L filter still let in light pollution? So is it better to do RGB and synthetic L when imaging from a red zone? Or use an LPS filter for the luminance channel?
I've been going back and forth deciding between an OSC and mono frown.gif  My dark site is bortle 4 and local site is a red zone. The 071 is very tempting!
Yes L will let in LP. No, I don't believe synthetic L is going to improve anything. The thing about a synthetic L is that it LITERALLY ADDS ZERO INFORMATION to your final image. You may be able to do certain things with processing on a synthetic lum that are easier than doing them on the separate or combined RGB, however a synthetic L is derived from the RGB. It won't add any more SNR to your image. I have heard from a lot of people that synthetic L works great, however theoretically, mathematically and in my experience with DSLRs in practice, I have never found that they ever actually improve SNR. I often preferred separating out a synthlum with my 5D III just to simplify processing, and some things (like deconvolution) always worked properly on the synthetic lum, but rarely on the RGB.
If you truly want to improve your SNR, then you must use either an L filter, or an LP filter in place of the L filter (not for color, but for LP protected luminance). Only ADDTIONAL frames from a separate filter will actually give you the true SNR benefit of LRGB imaging. Conversely, you can simply skip L alltogether, and put a lot more time into the RGB filters. If you were aiming for say 6 hours of integration total, with 4 L and 2 of combined RGB, there is no reason you couldn't drop the L and just put 2 hours each into RGB. You would benefit from the couple of small gaps at the ends and between the RGB filters that way, which would block out some LP. But, for the most part, all that really does is block out the primary sodium vapor emission lines. It actually doesn't block out any other LP lines. IMO, you would still be far better off using an L filter, and just acquiring a lot of L data.
Here is an example (I may have posted this before, but here it is again). These two images of Andromeda are from my back yard, a red/white zone in a suburban area. The first image is 7.2 hours of 5D III OSC data during October and November from a couple years back:
The second image here is 3.4 hours with an ASI1600 and LRGB, with 1h56m of L, 20m of B, 30m of G and 40m of R from a couple months ago:
This is the same heavy LP. Less than half the total integration with the mono, and it looks significantly better. I added 1h24m Ha data to the new image as well, and enhanced the color a bit more:
The Ha data was a bit sparse, and really needs to be 3-4 hours of integration, so it pulled down the SNR of the final image a bit. However, it still looks considerably better than the OSC image.
Without the L data for my new image, I'd have had to put more time into each of the other filters. Since they are each only acquiring a third or less the light, I would have needed a lot more integration to get the same final SNR.
I've thought about picking up an IDAS LPS-D1 1.25" filter to use in place of my L. I haven't done that yet as it doesn't seem to matter what size IDAS filter you buy, they all cost the same ($190), which I find to be ridiculous, and I'm not really sure how much of an improvement it will really offer in the end. I have larger IDAS filters, and I keep meaning to give them a try before I buy another one. I always felt the color ended up a bit too blue-green with the IDAS LPS-P2, so I stopped using it on my OSC data. However, used as an L filter, it might be perfectly fine, and could provide higher contrast data for a luminance channel. I'd probably need to double my integration time with it, as the IDAS filters in my experience block out about a stops worth of light. So, my 3.4h integration would become a 5.4h integration.
Just to be clear to everyone. I am recommending mono if you live in a light polluted area. I think the ASI071 will be an awesome camera with a relatively large sensor, IF YOU LIVE UNDER DARK SKIES. OSC is great with dark skies, where LP can't decimate your SNR and spew colorful crap all over your data. I stopped using OSC cameras in my back yard in February 2015, as after seeing what just 2-3 hours could do at a dark site, spending 11, 12, 15, 18 hours in my back yard to get WORSE results just wasn't worth it anymore.
If you live in a yellow zone or darker, and want the largest frame in a cooled astro camera that you can currently get, I say look no further than the ASI071.
If you live in an orange or brighter zone, particularly red/pink/white, skip the OSC. Even with added mechanical complexity, mono+LRGB is vastly superior. Despite the fact that an L filter lets in more LP. tongue2.gif
Jon,
I am sorry to ask this question as I am still somewhat confused.  I live in yellow zone.  If I can afford to buy either ASI071 or ASI 1600 mm (mono with accessories) would you still recommend ASI071 for someone in yellow zone.  Will there be any significant advantage for someone living in yellow zone to have mono vs OSC.
Avi
I agree with Premk19, If you live in a yellow zone or better then you can't go wrong with the ASI071MC otherwise it may be better to go mono with filters.
#233 telfish
telfish
  • Loc: Adirondack Mountains NY
Posted 06 March 2017 - 12:08 PM
I am currently testing this camera in a grey zone and am very pleased with the results. I am going to mix HA in from my 1600 which should be a winning combination.
#234 entilza
entilza
Posted 06 March 2017 - 03:00 PM
Very nice!!  Do you have an Ha-only version only as well?  Thank you.
  • Glutch likes this
#235 Jesus Magdalena
Jesus Magdalena
Posted 06 March 2017 - 04:11 PM
Thank you
This is the stacking of the Ha shots, extracted the red and stretched channel
Sorry, stretched and processed
Edited by Jesus Magdalena, 06 March 2017 - 04:35 PM.
#236 entilza
entilza
Posted 06 March 2017 - 04:25 PM
Wow awesome!
#237 GaryO
GaryO
  • Loc: rochester ny
Posted 06 March 2017 - 05:46 PM
Really nice image!
Gary
#238 tommax
tommax
  • Loc: WI
Posted 17 March 2017 - 09:16 AM
Astronomy is a very tiny market. Cost will always be higher. It has nothing to do with how much it cost to make the camera, it has to do with number of people buying the cameras. There are significantly a lot more people buying DSLR cameras than astro cameras. If astro cameras cost as much as DSLR cameras, the astro camera business will go out of business due to small market.
Cooled cameras will always be better than uncooled cameras for long exposure times of at least 30 seconds. Cooled cameras significantly reduces dark noise.
Peter
the free market working as it should - without it there would be no astro cameras at all.
#239 tommax
tommax
  • Loc: WI
Posted 17 March 2017 - 09:19 AM
Sorry of this does belong here but all the guys commenting seem to know these very well. I recently acquired a 1600-color-cooled. Nice camera but the file sizes are huge. I am just learning and have a AT-65EDQ scope - I have been using sharpcap and it is difficult to get images due to the file size - it's huge on my laptop screen - I spend alot of time trying to find my target. What do you guys do about this? with that 65mm scope I certainly don't need an image that huge and it makes processing take longer - do you guys bin with these? are there any other tips?
again apologies if I should have asked this in a separate thread.
#240 Mr. Bill
Mr. Bill
  • Loc: Northeastern Cal
Posted 27 March 2017 - 09:56 AM
Been talking to the guys over at HiPoint Scientific.....they gave me a couple of links.
http://apogee-system...gee/ccd104.html
http://www.blackwate...maging-toolbox/
Looking at this camera....
http://www.highpoint...a-asi071mc-cool
Want a large format chip for wide field Milky Way starfield shots. This camera will give me a 1.69x1.23 degree fov using my Orion 800mm f/3.9 astrograph.
My main interest is near real time imaging and want something that will give me a decent color image of low contrast extended objects like bright and dark nebulae in reasonable amounts of time.
Could I reasonably expect images from this setup in 1 to 5 minutes with no post processing.
I guess binning would help with the acquisition speed...correct?
I live in a green/blue rural region but have frequent access to Bortle 1/2 skies.
Edited by Mr. Bill, 27 March 2017 - 12:22 PM.
#241 pyrasanth
pyrasanth
Posted 24 April 2017 - 06:43 AM
I live in a moderately light polluted area. I produce reasonable results with an LRGB and HA filter combination.
I would consider an OSC to use on my Celestron RASA with the Celestron/Astrodon LPR filter but I'm worried that a fast system with an OSC would amplify the effects of the light pollution. Do you have any thoughts as to whether an OSC would be good or bad under these light pollution issues on the RASA?
#242 lucutes
lucutes
  • Loc: Western Canada
Posted 27 April 2017 - 02:11 AM
If the ASI071 was offered in mono would Sam have to go with 2" filters? I noticed they don't sell a 2" filter system.
#243 jgraham
jgraham
Posted 27 April 2017 - 07:57 AM
"Do you have any thoughts as to whether an OSC would be good or bad under these light pollution issues on the RASA?"
If you are getting good results with the techniques that you are using now there will be a period of frustration climbing the learning curve of a different approach. Over the years I have also done narrowband and LRGB imaging and I really enjoyed it while I was doing it. I still have my monochrome gear and I still use it for specialty tasks, but for my general purpose imaging I now use a color camera, currently the ASI071MC. I do all of my imaging from my red zone back yard (typical lensed SQM of 18.6) and I have developed the techniques to get results with a color camera that are every bit as good as what I was getting with my LRGB gear. I also find that color imaging is a good match for my local sky conditions, which are rarely stable and can change all night long.
So, yes, I think that a color camera can be a very good match for imaging under light polluted skies once you have developed the techniques to make the most of these challenging conditions. Personally, while I really enjoyed my time with LRGB and narrowband imaging, I can't see myself going down that path again any time soon.
"If the ASI071 was offered in mono would Sam have to go with 2" filters?"
Maybe, it depends on the filter wheel and the f/ratio of the system. If you can get 1.25" filters close enough to the sensor they should work. I started out using 1.25" filters with my modified DSLR (same size chip as the ASI071MC), but I had to make a step-down ring to fit the filters inside the nosepiece of my camera.
My homemade step-down ring mounted inside my off-axis guider...
This shows the OAG mounted on my 8" SCT. This gives you some idea the spacing between the filter and the sensor, the filter is mounted inside the EOS adapter...
#244 lucutes
lucutes
Posted 27 April 2017 - 11:31 PM
Interesting, thanks for the photos.  I am considering either the Hyperstar or Focal Reducer options.  Problem is I would want to purchase the F2 filters with Hyperstar.  If I go 2" filters would there be any penalty using a camera that would only require a 1.25" filter?
#245 Peter100
Peter100
Posted 28 April 2017 - 07:04 AM
The Hyperstar accepts 2" filters in front of the adapter for your camera.  It would be handy to order 2 adapters in order to make filter changes easier.  Keep in mind that the Hyperstar is f2 so no focal reducer will match that.  I use a Hyperstar almost exclusively and use in-camera dark subtraction.  The major problem with a Hyperstar is that bright stars cause a reflection off the back of the corrector plate which creates "Hyperstar nebulas"
Peter
#246 jgraham
jgraham
Posted 28 April 2017 - 07:47 AM
"If I go 2" filters would there be any penalty using a camera that would only require a 1.25" filter?"
None that I can think of. I used 1.25" filters when I was using cameras with a small chip, but when I moved up to APS-c vignetting became a problem, particularly when my f/ratio dropped below about f/7. With 2" filters vignetting is no longer an issue (the fastest I work with now is f/4) and the 2" nosepiece and mounts are a lot  sturdier than 1.25". With a filter wheel 2" filters can get a bit pricey, but with a color camera I only use 2 filters; an Orion imaging skyglow filter for general imaging and a UV/IR cut filter for photometry.
#247 lucutes
lucutes
Posted 30 April 2017 - 12:11 PM
Baader UFC or Starizona Filter Drawer system? Also would a T2 adapter be compatible with the standard Nikon T-ring adapter?
