Masuyama 32/85 -- First Impressions
89 replies to this topic
#1 Jim Curry
Jim Curry
Posted 23 October 2016 - 12:12 AM
Mine came in today and I grabbed it from the mailbox as I was headed for our dark sky site.  Now my Nagler 31 has been my gold standard for great wide field views so I had that with me for comparison.  I used my 140 NA f5.7 petzval and a friends 16" f4.5 Teeter.  Transparency was a 6, seeing 5-6ish.
The first thing I checked was afov, comparatively.  The Masu was a smidgeon wider than the 31N.   I started looking for seagulls.  I have mild astigmatism as does my friend but except where M13 crossed the field stop there didn't seem to be any issues as we moved star fields and globs across the view.  I then looked at the Veil and California with both ep's.  Same-same.  I think the maker of the Masuyama has a winner.
The Masu eyepiece is significantly lighter than the Nag so balancing between 2" eyepiece changes isn't the octopus act it can be when pulling out the Terminagler.  I like this and I'll get some use in this fall.
Edited by Jim Curry, 23 October 2016 - 06:39 AM.
#2 Astrojensen
Astrojensen
Posted 23 October 2016 - 02:29 AM
This is interesting.
Clear skies!
Thomas, Denmark
#3 range88
range88
Posted 23 October 2016 - 04:10 AM
What about edge aberrations?
It seems they do have 85°.
#4 Smithfr2000
Smithfr2000
Posted 23 October 2016 - 06:16 AM
Waiting for second run...
#5 Jim Curry
Jim Curry
Posted 23 October 2016 - 06:21 AM
Like I said, when moving star fields across the view, there wasn't anything noticed in my scope. Flat field, no elongation or comet tailing of the stars. Keep in mind the petzval is dead nuts flat field.  I still have to run this thru f8, 12 and 15 scopes.  The Teeter had a very slight field curvature at the edge but far less than expected for an f4.5 without paracor.
I used to own one of the UO Extra Wide Fields and the aberrations were awful.  I couldn't sell it fast enough.  I took a chance on this, fingers crossed, that the Masayamu name wouldn't be etched into another one of those.
The packaging was very good and Agena threw in a bolt case for it. Kudos to them.
Edited by Jim Curry, 23 October 2016 - 06:40 AM.
#6 Smithfr2000
Smithfr2000
Posted 23 October 2016 - 08:18 AM
I look for a long focal EP, light, very light, for my newts, this one seems appealing. Do you think it is better than à Swan 33 or à Moonfish 30 ?
I am at f4.8 without paracorr and f3.5 with paracorr.
#7 jrbarnett
Posted 23 October 2016 - 11:40 AM
Jimbo, no Paracorr in the Teeter, correct?
Oh I see you hit that in the second post.  That's pretty impressive if not only is it not astigmatic at f/4.5 (which was my fear) but also possibly somewhat corrective of coma.  I went ahead and ordered one too.  Probably won't get it until the second shipment shows up in November, so I'll happily read your further adventures.
Edited by jrbarnett, 23 October 2016 - 11:42 AM.
#8 Jim Curry
Jim Curry
Posted 23 October 2016 - 02:37 PM
Mssr Smith
I have no experience with those ep's.  The 16" teeter is a beefy scope and not phased by a N31 change-out through most of its range.  The Masu 32/85 should be especially appealing to the lighter dobs which can be more sensitive to multi-pound :>) eyepiece changes.
#9 mgwhittle
mgwhittle
Posted 23 October 2016 - 02:56 PM
I'm surprised. Obviously not the same optical formula as the Kasai, which is a good thing. I've gone from pass to maybe on this one.
#10 John O'Hara
John O'Hara
Posted 23 October 2016 - 03:08 PM
Very interesting.  It's advertised as weighing 450 g or about 1 lb.  That would not upset balance in my scopes as much as would eyepieces like the 31 Nag.  That's quite light for a premium wide field ultrawide.  Does really have the 20 mm eye relief?  Due to my own astigmatism, I wear glasses at exit pupils much above 3mm.
John
#11 Smithfr2000
Smithfr2000
Posted 23 October 2016 - 03:11 PM
Any comment about focus point ? More or less intravel than 31T5 ?
#12 Jim Curry
Jim Curry
Posted 23 October 2016 - 06:30 PM
John  The eye lens is quite recessed.  I too wear 1.5 readers and I tried using them.  No go.  I never used the rubber eye shield.  It may be 20mm relief but I was in fairly tight to see the field stop.
Mr. Smith  I don't recall focus adjustments.  I used this as a finder ep then switched to a turret.
I remember thinking that the field stop was out of focus as stars drifted across.  I just looked in daylight to see what was going on.  When your eye is centered and solely moving around to see the edge you're looking down the tapered barrel.  You have to slide your head to the side a bit to see the field stop.  No issues, just an observation.
Edited by Jim Curry, 23 October 2016 - 08:59 PM.
#13 Howard Gao
Howard Gao
Posted 23 October 2016 - 06:40 PM
Thanks Jim. Look forward to some reports on testing with f8 or 11 scopes.
#14 ybor
ybor
Posted 23 October 2016 - 08:46 PM
Yes , looking forward to viewing report since I am interested in getting one for wide field viewing .
#15 Jim Curry
Jim Curry
Posted 23 October 2016 - 08:50 PM
Here's a few photos for comparison purposes.
#16 Jim Curry
Jim Curry
Posted 23 October 2016 - 08:51 PM
#17 Jim Curry
Jim Curry
Posted 23 October 2016 - 08:52 PM
#18 Jim Curry
Jim Curry
Posted 23 October 2016 - 08:55 PM
And now, a most interesting find.  The Tele Vue Dioptrix is a perfect fit.  I discovered that today after looking down on both ep tops and realizing how similar they looked in diameter.
Edited by Jim Curry, 23 October 2016 - 08:56 PM.
#19 Zamboni
Zamboni
Posted 24 October 2016 - 09:08 AM
Wow! Definitely report back how well it plays with the dioptrx. If it works well, I'll be seriously eyeing one of these.
#20 Scott99
Scott99
Posted 24 October 2016 - 11:15 AM
Sold out???   I never had a chance! :(  :(  I'm surprised this sold out but not the regular 2-inchers.  Seems like response has been very positive so far, hopefully all these eyepieces will go into regular production.
The 32mm never appeared on the KK website, I guess their regular customers claimed them all in advance??
*EDIT* OK, Agena says early November, maybe they aren't sold out after all.
Edited by Scott99, 24 October 2016 - 12:03 PM.
#21 mgwhittle
mgwhittle
Posted 24 October 2016 - 12:52 PM
The "regular" two inchers sold out too Scott, but they got another shipment.   I believe that for now, these will be regularly produced as the original batch of 60mm (or maybe 50mm) sold out and was replaced at least two times now.
Edited by mgwhittle, 24 October 2016 - 12:54 PM.
#22 jrbarnett
Posted 24 October 2016 - 01:58 PM
Perhaps that's what they meant by improving on the Kasai version - DioptRx compatibility.  That is awesome news.
#23 Howard Gao
Howard Gao
Posted 24 October 2016 - 03:48 PM
Check here
http://www.kkohki.co...e/whatsnew.html
#24 Scott99
Scott99
Posted 24 October 2016 - 07:22 PM
>>>At the end of 10 will be in stock! Deluxe wide horizons domestic eyepiece of multi processing
sounds good!  I have to think this would be better at f/10 or longer.  Would be fun to experiment with it though.  I wonder if it has lateral color like all other wide fields.   The Tak LE/Masuyama design does not have lateral color.
The FOV the Pentax XW 30mm and 40mm must be better-corrected at the edge with 7 and 6 elements.  The XW40mm does well at longer f-ratios though and does not have a negative lens (barlow) in front.
#25 ybor
ybor
Posted 24 October 2016 - 10:05 PM
Any viewing reports  on this eyepiece ?
How does it  fair against a Nagler 31mm ?
How is it on edge correction or is  it softer in the outer  10% of FOV ?
Is it sharper or have wider FOV than the Nagler 31mm ?
