Source of Bright Star Reflections?
6 replies to this topic
#1 Gary Imm
Gary Imm
  • Loc: Onalaska, TX
Posted 07 November 2016 - 10:11 AM
I have been pretty happy with my setup for deep sky objects:
Orion EON 130mm ED Triplet Refractor / Orion EON 3" field flattener / ZWO Mini EFW with Astrodon Filters / ASI1600MM-Cool Camera
But for very bright stars, I always see a distinct symmetric pattern around them.  Attached is an example, cropped of a Pleiades star from a 5 second blue filter sub.  Of course, the pattern is much more obvious in the integrated master.
What is your view on what is causing this?  I assume it is the CMOS window or the flattener.
Is there any way to prevent it (aside from not imaging bright stars)?
Gary
Edited by Gary Imm, 07 November 2016 - 10:13 AM.
#2 nikao
nikao
Posted 07 November 2016 - 10:19 AM
doesn't look like reflection, but more something like blooming?
I'm not familiar with this camera, so not sure if it is a known 'problem' of it?
#3 Gary Imm
Gary Imm
  • Loc: Onalaska, TX
Posted 07 November 2016 - 10:26 AM
Just to add - my camera settings are typically 200 gain, 35 offset, and 40 USB.  For this camera, that gain is a bit higher than the unity setting of 139.
#4 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 07 November 2016 - 10:34 AM
Rotate the camera and see if the pattern rotates with it. I expect it will. I suspect reflections/diffraction from the sensor, a little like a diffraction grating. Is there anything else in the system with that symmetry?
Edited by happylimpet, 07 November 2016 - 10:34 AM.
#5 james7ca
james7ca
  • Loc: San Diego, CA
I think that's a combination of diffraction (perhaps from the lens spacers) and also artifacts from the micro lenses on the sensor's photo sites.
#6 Gary Imm
Gary Imm
  • Loc: Onalaska, TX
Posted 07 November 2016 - 11:46 AM
A few more points:
- This pattern is usually only apparent in the final integrated master when a bright star saturates an area which is more than 10 pixels by pixels wide in the sub.   Smaller than that, and the pattern does not appear.
- When it occurs, the pattern seems to always be aligned with the CMOS dimensions, with the four main spikes being oriented exactly up/down/right/left on the image.
#7 happylimpet
happylimpet
Posted 07 November 2016 - 12:40 PM
A few more points:
So I would guess its a reflected diffraction effect from the CMOS, being reflected back by some optical element close to the chip. Maybe a filter. You could jig things around if possible but probably hard to eliminate.
