Lunar X predictions 2017?
21 replies to this topic
#1 altair1956
altair1956
  • Loc: Light polluted central Mass
Posted 15 December 2016 - 02:55 PM
Can anyone point me in the right direction to find predicted times for the upcoming year?
thanks
#2 beggarly
beggarly
  • Loc: Belgium
Posted 16 December 2016 - 02:01 AM
Let's see.
https://en.wikipedia.org/wiki/Lunar_X
http://www.universet...ng-the-lunar-x/
So, a few hours before First Quarter,
http://aa.usno.navy....ump=50&format=p
https://the-moon.wik...ces.com/Lunar X
http://www.rasc.ca/s...c2007-04-hr.pdf page 51. Keith Burnett’s Excel spreadsheet mentioned in this PDF runs in LibreOffice: http://www.sohcahtoa...er/mooneph.html section 'Altitude of Sun over a given feature';
Rik
Edited by beggarly, 16 December 2016 - 07:17 AM.
#3 67champ
67champ
  • Loc: Ohio, USA
Posted 23 December 2016 - 02:55 PM
Lunar X approx. "Start times"... 2017:
01/05/2017                0654UT
02/03/2017                2046UT
03/05/2017                0956UT
04/03/2017                2221UT
05/03/2017                1010UT
06/01/2017                2136UT
07/01/2017                0857UT
07/30/2017                2033UT
08/29/2017                0839UT
09/27/2017                2125UT
10/27/2017                1051UT
11/26/2017                0046UT
12/25/2017                1450UT
Dana Thompson
Edited by 67champ, 23 December 2016 - 06:50 PM.
  • Doug Neal, aa6ww and jgroub like this
#4 Dave Mitsky
Dave Mitsky
  • Loc: PA, USA, Planet Earth
Posted 23 December 2016 - 04:21 PM
Thanks as always, Dana!
Dave Mitsky
  • 67champ likes this
#5 gmartin2000
gmartin2000
  • Loc: Hazelwood Missouri
Posted 03 January 2017 - 03:49 AM
01/05/2017                0654UT
02/03/2017                2046UT
03/05/2017                0956UT
04/03/2017                2221UT
05/03/2017                1010UT
06/01/2017                2136UT
07/01/2017                0857UT
07/30/2017                2033UT
08/29/2017                0839UT
09/27/2017                2125UT
10/27/2017                1051UT
11/26/2017                0046UT
12/25/2017                1450UT
Dana Thompson
Hi Dana:
What tool did you use to generate your times? I'm using LTVT with a Colongitude of 359.019 degrees. The data is calculated for St. Louis Missouri. The colongitude is *supposed* to be for maximum event while your predictions are for the start of the event.
While LTVT shows times later than yours by no more than 3 hours (expected), I'm seeing some odd differences in predictions for the year. What I didn't expect was the change in month to month difference. LTVT deltas start out at 41 minutes then increase till the max difference is 3 hours and 30 minutes on 6/1. After that, they begin decreasing to a minimum difference of 25 minutes on 11/26. Then it starts to increase again.
Do you (or any one reading this) have an idea why this is happening? The difference, in minutes, when plotted sure make a nice little 1/2 cycle Sine wave   ;)
Thanks much in advance!
   Date         Dana   LTVT   diff(h:mm)
01/05/2017  0654  0735    0:41   x = Moon below horizon in St louis Mo so the event is not visible this month
02/03/2017  2046  2209    1:23
03/05/2017  0956  1210    2:14   x
04/03/2017  2221  0121    3:01 (4/4 LTVT date)
05/03/2017  1010  1337    3:27   x
06/01/2017  2136  0106    3:30 (6/2 LTVT date)
07/01/2017  0857  1205    3:08   x
07/30/2017  2033  2301    2:28
08/29/2017  0839  1018    1:39   x
09/27/2017  2125  2220    0:55
10/27/2017  1051  1118    0:27   x
11/26/2017  0046  0111    0:25
12/25/2017  1450  1540    0:50   x
#6 SaberScorpX
SaberScorpX
  • Loc: illinois, usa
Posted 03 January 2017 - 03:57 AM
thanks dana.
the blue x in july is cool. otherwise no blue or black moons this year. i guess i'll let it slide since there's that eclipse thing in august : )
peace, stephen
http://www.c14isawesome.blogspot.com
http://www.saberdoes...s.wordpress.com
Edited by SaberScorpX, 03 January 2017 - 04:09 AM.
#7 altair1956
altair1956
Posted 03 January 2017 - 02:01 PM
Wasn't able to get on for a while. THANKS Dana, just what I was looking for!
Steve
#8 beggarly
beggarly
  • Loc: Belgium
Posted 04 January 2017 - 05:39 AM
Here's a nice picture of Lunar X: https://lpod.wikispa...cember 12, 2013
The output from LTVT and Keith Burnett’s Excel spreadsheet:
Edited by beggarly, 04 January 2017 - 06:34 AM.
#9 edosaurusrex
edosaurusrex
  • Loc: Wadsworth, OH
Posted 04 January 2017 - 11:58 PM
The Sun's colongitude is where the terminator crosses the lunar equator. The Sun's latitude can go 1.5 degrees above and below the lunar equator. The Lunar (Werner, etc) X is 25 or so degrees below the lunar equator. This means there can be about 1.5 degrees (or 3 hours at 0.5 degrees of terminator movement per hour) of difference between the Sun altitude at the X versus the colongitude at 359 degrees. I ran some numbers and the Sun is 1.2 degrees above the equator in January and 1.5 degrees below it in June.
So, in June,  by the time the colongitude is at 359 degrees the terminator is running East of North to West of South and the X is well illuminated compared to the time when the Sun's altitude is at the desired value for the "classic" looking X.
Dana uses position and Sun altitude and it is a more accurate predictor of the event versus just the colongitude. I use a slightly different position and Sun altitude than Dana so my calculated times vary by a few minutes from his.
A picture is truly worth a thousand words.
Ed
Edited by edosaurusrex, 04 January 2017 - 11:59 PM.
  • Dave Mitsky, 67champ and gmartin2000 like this
#10 67champ
67champ
  • Loc: Ohio, USA
Posted 05 January 2017 - 10:39 PM
Thanks Ed!  I use the same spreadsheet that Beggarly posted.  For years I have used 1.2 Sun Altitude over crater Werner as a good indication of the "start time" for the event.  It seemed to work pretty well.  Colongitude is typically anywhere from 357.xx to 358.xx at that "start time"...  359.xx is too late into the illumination to see it for long in it's "classic" sense.  I would be calling that a "late X" at around 359.xx!  You would be a lot better off just using 358.00.
Anyways, I think in my future predictions I will be posting the "start time" corresponding to -1.000 sun altitude of the actual approx. location of the "X" feature; not 1.2 sun altitude over crater Werner...
Dana T
  • gmartin2000 likes this
#11 67champ
67champ
  • Loc: Ohio, USA
Posted 06 January 2017 - 06:40 AM
Using Werner (1.2 Sun Alt) with coordinates of:
LAT      -28.0
LON     3.3
and Using X Coordinates of:
LAT      -24.9
LON     .9
01/05/2017                0654UT          -.916 @ X
02/03/2017                2046UT          -. 958@ X
03/05/2017                0956UT          -1.011 @ X
04/03/2017                2221UT          -1.058 @ X
05/03/2017                1010UT          -1.078 @ X
06/01/2017                2136UT          -1.079 @ X
07/01/2017                0857UT          -1.061 @ X
07/30/2017                2033UT          -1.019 @ X
08/29/2017                0839UT          -. 969 @ X
09/27/2017                2125UT          -.924 @ X
10/27/2017                1051UT          -. 897 @ X
11/26/2017                0046UT          -. 896 @ X
12/25/2017                1450UT          -. 925 @ X
                                                   -. Average – 1.066 @ X
#12 beggarly
beggarly
  • Loc: Belgium
Posted 07 January 2017 - 05:55 AM
LTVT is a great tool for predicting the appearance of Lunar X. https://ltvt.wikispaces.com/LTVT
I finally figured out how to use the basic functions. I haven't installed the high resolution maps yet, but the results from the minimal installation are sufficient.
This is for 05 March 2017.
Edited by beggarly, 07 January 2017 - 06:34 AM.
  • Dave Mitsky and gmartin2000 like this
#13 beggarly
beggarly
  • Loc: Belgium
Posted 10 January 2017 - 05:19 PM
It's cloudy.
Thank you LTVT.
Edited by beggarly, 10 January 2017 - 05:20 PM.
  • Dave Mitsky, 67champ, John Gauvreau and 1 other like this
#14 gmartin2000
gmartin2000
Posted 17 January 2017 - 12:43 AM
Thanks for all the help folks. This is making a lot more sense. G
#15 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 17 January 2017 - 12:01 PM
Already missed the first one, but if I recall correctly, the weather wasn't conducive to observing that night. (Yes, even in Tucson this happens!)
Better luck in February!
#16 REC
REC
  • Loc: NC
Posted 28 January 2017 - 10:27 AM
So what time is that EST?
Also, don't forget to check out the Lunar "V" as well. It's just below the X on the terminator.
Edited by REC, 28 January 2017 - 10:29 AM.
  • PrestonE, 67champ, John_Moore and 1 other like this
#17 JimFR
JimFR
  • Loc: Toronto
Posted 03 February 2017 - 09:36 PM
'Twas tonight
  • Dave Mitsky, 67champ and John_Moore like this
#18 REC
REC
  • Loc: NC
Posted 04 February 2017 - 10:00 AM
Good for you, we got clouds! Next Op is in April for us.
  • JimFR likes this
#19 Abhat
Abhat
  • Loc: Central Maryland, USA
Posted 27 September 2017 - 06:38 PM
Posting the image taken on 09/27/2017 via Nikon D3300 attached to Orion 90mm F/10. Moon was at a perfect phase to display Lunar X.
Edited by Abhat, 27 September 2017 - 06:39 PM.
  • nicknacknock likes this
#20 nicknacknock
nicknacknock
    A man of many qualities, even if they are mostly bad ones
  • Loc: Nicosia, Cyprus
Posted 28 September 2017 - 12:16 AM
Abhat,
You also got the Lunar V as well ;)
#21 desertstars
desertstars
  • Loc: Tucson, AZ
Posted 25 November 2017 - 12:37 PM
X should mark the spot again tonight. As luck would have it, I have both clear skies and time. I was going to be out there moonwatching anyway, so why not?
#22 tacun
tacun
Posted 16 December 2017 - 07:57 PM
Hi guys, I photographed it but by pure chance when I take out my telescope the first time !
The forist Greyhaven told me (thanks ...)
I still can not believe it. You can see the story in the post.
https://www.cloudyni...ew-first-light/
You see?
  • Dartguy, outofsight and beggarly like this
