Homage to Homemade Crayford Focusers
55 replies to this topic
#51 Stub Mandrel
Stub Mandrel
Posted 20 September 2018 - 05:16 PM
I was inspired to see all this great work, so I thought I'd share a couple of my own Crayford focusers:
3D printed in PLA with aluminium running strips:
DSCN1118
Aluminium focuser for custom scope built around Skywatcher ED 66 lens cell:
DSCN0256
66ED (2)
Edited by Stub Mandrel, 20 September 2018 - 05:17 PM.
  • cmooney91 likes this
#52 miak
miak
  • Loc: Vancouver, BC
Posted 21 September 2018 - 01:45 PM
That aluminum one is quite nice! Don't see a lot of dual-speeds ATM focusers, how hard was it to get the balls in and aligned, and to get enough pressure (assuming you used ball bearings for it)?
#53 Stub Mandrel
Stub Mandrel
Posted 26 September 2018 - 04:02 PM
The dual speed took a 3D-printed mock up and then a couple of cages and cups. The real problem was the secondary shaft, I tried turning a groove, that was too uneven. I ground a groove and that worked well, but kept loosing its tension - the balls were hammering the sharp corner of the groove.
In the end I found a conical stone and ground a round profile groove to match the balls and that worked much better (and keeps its setting). I used a very small roller thrust bearing to allow me to use plenty of tension.
#54 mikelab
mikelab
Posted 31 July 2019 - 11:49 AM
Here is a Crayford focuser that I 3D printed 3 years ago. First I designed it in SolidWorks and then printed it.
I also attached a pic of some of the other parts I printed and the finished
scope. The fork mount was laser cut out of Aluminum.
(and yes, the scale and numbers are also printed - raised up about .030")
The focuser is smooth as silk. it rides on a stainless steel shaft with internal Teflon tension adjusters.
Edited by mikelab, 31 July 2019 - 04:49 PM.
  • PrestonE, brave_ulysses, don clement and 2 others like this
#55 brave_ulysses
brave_ulysses
  • Loc: far outside the wire
Posted 31 July 2019 - 08:45 PM
welcome, mikelab; great first post! looking forward to seeing your other projects
#56 brebisson
brebisson
Posted 08 October 2019 - 01:03 PM
Hello,
Just finished 2 small crayford focusser for some of my single pole scopes…
Used a 12mm thick cherry board and a cnc to machine the parts…
The bearings are 8mm outside diameter with 4mm inside diameter…
The drawtube is 34mm outside and had to use a lathe to grind the inside to the proper size ☹
I used a 5mm push screw with a spring loaded ball at the top. I brazed a bronze thumb nut on it to look nice and buried a nut in the “center part” of the focusser…
After gluing, I “shaped” the focusser (slightly visible in the last picture) as wedges (mostly to look nicer and to shed weight).
I used a 3mm knitting needle as a rod and used one of the little round cut by the CNC as the turn button.
Final product is 46g!
Cyrille
  • Diego, Pierre Lemay, R Botero and 2 others like this
