ElectroPhysics NV AstroScope (Nikon version) coupled to a Sony Alpha 7
NV
4 replies to this topic
#1 jdbastro
jdbastro
Posted 22 December 2016 - 01:52 AM
Well this is something that you don’t see every day.
AstroScope 9350 NV Unit with NIK-SP BBA and c-mount FLA
The so called AstroScope image intensified camera module has been produced by ElectroPhysics (now SofraDir) for at least a decade.  These devices are designed to work elegantly with both Nikon and Canon DSLR’s and previously SLR’s (film).  One simply removes one’s Nikon or Canon lens from the camera body, attaches the AstroScope to the camera body, re-attaches the lens to the front of the AstroScope and when the Nikon/Canon camera powers up, the AstroScope’s  internal MX1016 image tube receives power direct from the camera mount and one has a pretty seamless NV camera setup.
These AstroScope units have been showing up on eBay for a while now.  I recently scored a used unit without an image tube.  The parts that I got were:  1) A Nikon BBA (back body adapter) complete with an internal relay lens, 2) A Nikon FLA (front lens adapter), 3) and an empty CIU module (central intensifier unit - this is a two-piece shell that holds an MX10160 image tube.  The CIU has electrical contacts that pass camera connections from the BBA thu the CIU (and into the image tube) and then onto the FLA (for a front AF camera lens).   I later purchased a c-mount FLA direct from SofraDir for using c-mount lenses and telescope attachments on the front of the AstroScope.
MY CIU shell came with a small voltage regulator chip that takes the camera body voltage and squeezes it down to 3 volts for image intensifier input.
Astroscope 9350 NV Module Voltage Regulator (SOT 223 package)
It seems that the factory normally solders this voltage reg direct to the image tube electrical contact pad(s), but I’ve never liked that idea, so I redid the wiring in my CIU by adding a pair of EMI shield spring finger contacts (like the contacts included in many other NV units) so that I can simply slide my image tube into the CIU shell without soldering the tube to the wiring.
Astroscope 9350 CIU housing rewired with EMI Shield Spring Finger Contacts
Astroscope 9350 CIU housing rewired with EMI Shield Spring Finger Contacts - Image tube installed
So what’s the thing that you don’t see every day?  Well since a company called Vello recently introduced an E-mount adapter that works with certain Nikon AF lenses, I got the crazy idea to connect my AstroScope unit to my Sony Alpha 7 camera using this Vello AF adaptor.  The Vello unit passes power from the Alpha camera body into the Nikon BBA electrical contacts straight to the image tube tucked away in its CIU shell.
AstroScope 9350 w/ NIK-SP BBA coupled to Sony Alpha 7 via a Vello AF E-mount to F-mount wired adapter
I did some quick test videos (night sky star fields) of the image quality and image scale produced by the BBA’s internal relay lens,
AstroScope 9350 NIK-SP BBA (camera end view)
and the images look quite sharp.  At least as sharp as what I have seen from some of my other relay lens setups with other NV housings.
Here's a full-frame real-time NV video sample.
and an APS-C crop NV video sample.
Just thought I would share…
#2 cnoct
cnoct
Posted 22 December 2016 - 09:14 AM
Those EMI shielded contacts sure are a nice touch, are they butter smooth and gentle on the tubes EMI coating?
BTW: Beautiful setup, it's as if this particular astroscope was made for the a7S.
#3 jdbastro
jdbastro
Posted 22 December 2016 - 11:42 PM
Thanks.
As near as I can tell, the EMI shield finger contacts are gentle on the image tube's EMI coating.  The parts that I am using have an uncompressed height of 4mm.  The channel that they fit into is about 3mm deep, so they only deflect inward about 1mm.
I got the contacts from DigiKey.  The part # is:  A119327CT-ND
This part should also work:  952-1480-1-ND
#4 Eddgie
Eddgie
Posted 24 December 2016 - 09:31 PM
Congratulations!
Now that you have it, I am hoping to see many new Youtube videos!!!
#5 cnoct
cnoct
Posted 31 December 2016 - 05:41 AM
J,
There's a number of manufacturers and a whole lot of devices that should have done what you've done.
The inside should look as good as the outside even something so seemingly insignificant as contacts.
The Micro could certainly benefit from using a quality contact like the one you used and it's not the only current production unit that has pitiful contacts.
I really like the image scale this relay produces in full frame  :p
