Small bore challenge: Venus w/ 6" or less
astrophotography planet
168 replies to this topic
#101 DMach
DMach
  • Loc: The most light-polluted country in the world :(
Posted 11 September 2018 - 08:28 AM
Finally have a capture of Venus I feel worth sharing. Finding this to be a tricky target ... the brightness, lack of surface features and generally poorer seeing make it harder to be sure focus is spot on. The lack of features also make processing feel a little like guesswork!
Anyway, here it is. Visible light only ... maybe need to think about getting one of those fancy UV filters and doing some mono work.  wink.gif
Celestron 6SE, iOptron CEM60, ASI290MC, PowerMate 2.5x, UV-IR filter
  • zjc26138, eros312, caheaton and 5 others like this
#102 DanBorja
DanBorja
Posted 27 January 2020 - 08:32 AM
So I gave Venus a shot last night. It's my first time imaging Venus and I'm pretty happy with the result even though it was low, 26 degrees if I recall correctly. Hopefully as it gains altitude towards March I can resolve some detail of its atmosphere, although I'm not sure if I can manage that with 6".
This is a stack of 8,000 frames. I tried using the drizzle x3 and then downscale the image, but sharpening on registax brought many artifacts and it just didn't work for me this time.
  • George Bailey, Stargazer3236, Bootmaker and 1 other like this
#103 KiwiRay
KiwiRay
  • Loc: Seattle, USA
Posted 27 January 2020 - 09:21 AM
Hi Dan - Nice, crisp image.  We also have a Venus small-bore thread:
https://www.cloudyni...us#entry8826842
Ray
#104 DanBorja
DanBorja
Posted 27 January 2020 - 11:47 AM
First try at Venus...
6"SCT + TeleVue 2x Barlow + ZWO ASI290mc
  • zjc26138, Jeffrey C., cyberplocos and 7 others like this
#105 cyberplocos
cyberplocos
  • Loc: Ribeirão Preto, Brazil
Posted 28 January 2020 - 10:38 PM
Hi all,
Venus some days ago using an ETX90 Maksutov telescope with ASI 290MM camera. IR(G)UV image, fair to good seeing conditions.
regards,
Fabio
  • zjc26138, Jeffrey C., gfeulner and 12 others like this
#106 DanBorja
DanBorja
Posted 29 January 2020 - 08:22 AM
Hi all,
regards,
Fabio
That's an amazing image Fabio. I love the colors! Do you have a link of your UV filter?
#107 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 09 February 2020 - 09:03 PM
I have to try Venus with my ETX90 soon!
#108 evan9162
evan9162
  • Loc: ID
Posted 10 February 2020 - 07:33 PM
Venus season is upon us again.  Time to dust off the VX6L:
OO VX6L, Astrodon UVenus, TV 2x, ASI178mm. ~5000 frames
2020-02-10, ~23:56 UTC
Edited by evan9162, 10 February 2020 - 07:34 PM.
  • zjc26138, FXM, psandelle and 9 others like this
#109 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 10 February 2020 - 09:05 PM
What are the details of your capture? Gain, ROI, image capture software?
#110 evan9162
evan9162
  • Loc: ID
Posted 10 February 2020 - 10:36 PM
Gain 275, shutter 16ms,  ROI = 800x600 (~60fps), 16-bit capture, in SharpCap
#111 evan9162
evan9162
  • Loc: ID
Posted 13 February 2020 - 10:40 PM
Venus this afternoon.  Pretty good seeing for a portion of the capture
  • TorstenEdelmann, Jeffrey C., troyt and 6 others like this
#112 evan9162
evan9162
  • Loc: ID
Posted 14 February 2020 - 09:55 PM
Another today
  • TorstenEdelmann, John Boudreau, Kokatha man and 4 others like this
#113 Trevor N
Trevor N
  • Loc: England
Posted 15 February 2020 - 04:48 PM
Mounted an ED100 on a skytee mount to have a look and then thought I would have a go at an image. You need four hands !. One to focus, one to pan, one to tilt and one to work the laptop. Chasing Venus around the screen manually during the video was interesting ! No prizes for this one but amazed I got anything.
  • eros312, Lacaille and MalVeauX like this
#114 MalVeauX
MalVeauX
  • Loc: Florida
Posted 15 February 2020 - 07:57 PM
Heya,
I picked up a Celestron 127mm Mak and decided I would collimate it on Sirius B then point it at Venus and do a RGUV composite to test it out. First Mak I've ever had. I used a mono sensor and a filter wheel (manual) to do a RGUV composite, using a 610nm long pass as ®, 500nm as (G) and 395nm as (near UV, B). I did about 33k frames on R & G, and 12k frames in UV and stacked 33% of that. Aligned in AS!3. Wavelets in R6. Final touches in CS5.1 (PS).
Setup in the obs:
Collimation prior to imaging on Sirius B:
Location, Date & Time (34 degrees Alt):
Very best,
  • Jaimo!, eros312, Stargazer3236 and 4 others like this
#115 sunnyday
sunnyday
  • Loc: the Canadian nebula .
Posted 15 February 2020 - 10:26 PM
I tell you,there are photos here that are beautiful and filled with expertise.
#116 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 15 February 2020 - 10:33 PM
Heya,
Setup in the obs:
Very best,
Firecapture or SharpCap? Gain, exposure?
  • MalVeauX likes this
#117 MalVeauX
MalVeauX
  • Loc: Florida
Posted 16 February 2020 - 08:15 AM
I used FireCapture. Here's the capture settings and limits from the logs. The ASI290MM is a very sensitive camera, very efficient and of course Venus is very bright. Being able to image with no gain and very short exposures is easy with Venus, the challenge is going short wavelength (UV) where the seeing conditions are worse and most of these filters are lower transmission, so you can see down below my 395nm (UV) filter requires very different exposure values from the R & G.
Red Filter (Baader 610nm Long Pass):
FireCapture v2.6  Settings
Camera=ZWO ASI290MM
Filter=R
Profile=Venus
Duration=180.030s
Frames captured=33694
FPS (avg.)=187
Shutter=1.876ms
Gain=0 (0%)
Histogramm=49%
Green Filter (Baader Green 500nm):
Camera=ZWO ASI290MM
Filter=G
Profile=Venus
Duration=208.288s
Frames captured=33689
Shutter=2.362ms
Gain=0 (0%)
Histogramm=38%
Blue (UV, Andover 395nm filter, lower transmission significantly, so I had to use long exposure and lots of gain):
Camera=ZWO ASI290MM
Filter=UV
Profile=Venus
Duration=180.013s
Frames captured=11169
FPS (avg.)=62
Shutter=16.00ms
Gain=235 (39%)
Histogramm=55%
Very best,
Edited by MalVeauX, 16 February 2020 - 08:15 AM.
  • Stargazer3236 likes this
#118 eros312
eros312
  • Loc: Tampa, FL
Posted 23 March 2020 - 09:15 PM
Taken with a Meade 6" ACF
ASI 183MC
Astodon UV filter
1.25X barlow
First time imaging in 2 years, I think you can make out some streaks in the cloud tops. My focus looks off and I think I screwed up the settings somewhere because I see a grid pattern.
  • Kokatha man, Lacaille and Foc like this
#119 Foc
Foc
  • Loc: South Canberra
Posted 23 March 2020 - 10:18 PM
Excellent outcome Ken for imaging with the cobwebs on.  Sure looks like cloud markings.  How high was Venus when you took it and what time of the day was it taken?  No ADC? Then your image does not seem to show much need for an ADC in this instance.
  • eros312 likes this
#120 eros312
eros312
  • Loc: Tampa, FL
Posted 23 March 2020 - 10:34 PM
8:39 PM and about 34° altitude. I've an ADC but didn't use it.
#121 xb39
xb39
  • Loc: Germany
Posted 25 March 2020 - 04:03 PM
here is mine:
Skywatcher Esprit 150, Vivitar 3x, ASI174MM-Cool
CS
Stefan
  • eros312, gfstallin, Lacaille and 1 other like this
#122 MalVeauX
MalVeauX
  • Loc: Florida
Posted 29 March 2020 - 11:22 PM
Heya,
Venus tonight in RGB+UV and RGUV composites to show clouds.
150mm F8 Achromatic Doublet (Celestron C6R)
ZWO ASI183MM
ZWO Filter Wheel + Astronomik RGB and Andover 375~395 UV filter
Best 60% Frames of 5k per channel
Natural color RGB + UV and RGUV composites
Very best,
  • eros312, deepwoods1 and Lacaille like this
#123 Toddeo
Toddeo
  • Loc: Sierra Vista, AZ
Posted 30 March 2020 - 10:06 AM
Not much, but I had to shoot a couple of Venus. Was out with the AT72EDII and ZWOASI178MM shooting the Moon- before finishing, took a few captures of Venus.
  • eros312 and MalVeauX like this
#124 gfeulner
gfeulner
  • Loc: Bergen county, New Jersey
Posted 01 April 2020 - 09:30 PM
This is my first image of Venus in years. Taken with a Celestron 80mm Fluorite, ZWO 290MC and ES 3x extender. Best 40 percent of about 20 thousand frames. Just wish I had a filter to bring out the cloud structure.
Gerry
  • eros312 and Stargazer3236 like this
#125 james7ca
james7ca
  • Loc: San Diego, CA
Posted 01 April 2020 - 10:23 PM
Gerry, that's a good shot from an 80mm scope.
Also tagged with one or more of these keywords: astrophotography, planet
