So preparing to fix mine and the have worldest best DX-8, I needed to test the primary to see if it had any issues. So I first set the scope back up and tested it via double pass autocollimation. It's one of the worst scope I have ever seen. The test images show a very rough surfaces , with a turned edge and it is over corrected. I'm pretty sure the overcorrection and turned edge is coming from the secondary and the roughness from the corrector. To check that I pulled the corrector plate off the scope and tested the primary with a knife edge and Ronchi test at the radius of curvature. It showed an excellent spherical primary. I could not see a flaw. It's really too bad Criterion couldn't have got their process down to make the correctors and why they didn't test them I have no idea.
So here are some pictures showing how the complete scope tested. First is inside of the focus
Next is at focus. Notice how you can see the roughness and asymmetrical pattern.
Here is the outside of the focus. Notice how the lines now bend inward indicating over correction and also how jagged they are. They almost look like lighting bolts !
Finally a the primary mirror by itself. Jail bar straight Ronchi band indicating an excellent spherical surface. The goal is for the whole scope to test like that in double pass and I'll have a scope that will give just about any other a run for it's money.
- Dave
Edited by DAVIDG, 22 January 2017 - 10:17 PM.
