Perseus OB-3 (Alpha Persei moving group)
Obs-1: Time: 2017-02-10, 18:00 UT, Loc.:56N 12E Denmark, Alleroed,
Setup: Vixen FL-55S/440mm, 1.5xGPC + Masuyama 2” 32mm
Transp.: 3-2/7 (14dy/99% Moon, 5° Alt), Seeing: 4-5/10,
Light wind; Bortle: Red, suburban (SQM 17.6 NELM 4.8m)
Obs-2: Time: 2017-02-11, 18:30 UT, Loc.:56N 12E Denmark, Alleroed,
Transp.: 3-0/7 (15dy/100% Moon, 12° Alt), Seeing: 5/10,
No wind; Bortle: Red, suburban (SQM 17.3 NELM 4.7m)
It’s a couple of early evenings in mid February; It has been snowing the past days, but now a southerly wind is blowing the clouds away, -- almost. There’s a thin layer of high cirrus and some rags of lower altocumulus drifting up NW, and furthermore there’s a full moon (14-15 day, 99-100%) at 5-10° altitude in LEO in the east.
The overall transparency is correspondingly low, with a SQM around 17.5 (NELM ~4.7m), but I can trace the outline of Perseus almost overhead (~70° Alt), so I’m out under the night sky with my “little horse”, the Vixen FL-55-S/440mm refractor. Why bother? you may ask… I’m thinking of these lines by Robert Frost (*):
He gives his harness bells a shake / To ask if there is some mistake. / The only other sound’s the sweep / Of easy wind and downy flake.
The woods are lovely, dark and deep, / But I have promises to keep, / And miles to go before I sleep, / And miles to go before I sleep.
So, tonight I’ll focus on the OB-associations in Perseus, starting with Per OB-3, the Alpha Persei Cluster, (=Melotte 20 =Collinder 39 =O’Meara Hidden Treasures 14). The most luminous stars in the association are the yellowish type-F supergiant Alpha Per (~2m Mirfak) and ~4m type-K Sigma, but the association also includes several blue type-B stars such as Delta, Psi, 29, 30, 31, 34 and 48 Persei. The cluster has a beautiful overall “S”-shape, somewhat like the Orion OB-1b association. O’Meara has described it as an outline of the serpentine body of the sea monster, that Perseus turned to stone (using Algol, the fierce eye in the snake-haired head of the Gorgon Medusa). I find this description very fitting (although O’Meara interpreted the outline a little different, than the way I see it).
*click*
Allan
(*) Footnote, on suburban observing:
When I was doing construction, QA and teaching in the software business, we had this concept of “good enough quality”. It came from the realization, that any non-trivial software has such high complexity, that you can never prove or test it to be 100% correct (error free) viz. the specification. So instead you use smart heuristic techniques to develop and test it to a certified “good enough” level of error, that will allow you to ship a product on time and with a quality, that will keep the customer happy.
Same thing with my observing conditions and equipment; There are maybe a handful of nights in a year here north of Copenhagen, that could be said to approach perfection, and there are other telescopes I could get, with better specs (Aperture, FOV, Strehl, etc. etc.). But I observe where I live for a reason, and I’ve acquired the scopes I own after doing my research. My conditions and equipment are past the burn-in test phase. They are of “good enough quality”, and now I’m luckily left with : “Many a wonderful sky to sweep, / And miles to go before I sleep”, to paraphrase Frost.[/end sidetrack].
