Hi raa, -- I thank you for your thoughts and questions on my "Classic Rich Field" project!
First some background info; This project has been in the making over the past 5 years by now, so there has indeed been several sub-projects along the way, from observations of our Local Bubble co-moving star groups, to stellar streams in surrounding bubbles and further out to the local shell of interstellar molecular clouds (IMC) with their embedded OB-associations in our own Orion-Cygnus spiral arm (Gould's Belt, Radcliffe Wave) and out to similar shells in the surrounding Sagittarius and Perseus Milky Way arms; And further out to our local group of galaxies (Andromeda etc.), the Local Sheet (M81, Leo, Virgo), then further diving into surrounding galaxy superclusters (UMa, Virgo) and out to distant voids and walls, attractors and galaxy streams, all as observable on my suburban backyard night sky with my small 2-4" refractors.
Some CN'ers have followed this CRF-thread as it unfolded, and several have participated with valuable contributions, -- data and information, suggestions and points of view. Also, the scientific knowledge of many astronomical objects has increased dramatically in the recent years (e.g., new data provided by the ESO GAIA mission), so my observation logs have also been updated along the way. All this has added to the volume of the thread, but there's absolutely no need to plow through it end-to-end, as you can just dive into any sub-project or search for any object that has your current interest.
Wherever possible, I do try to document my observations with sketches and/or snapshots to make it easy doing follow-up studies plus sharing and comparing my views with those of fellow amateur astronomers; Also, to understand the astrophysics of the objects, I like to include maps and figures from recent scientific publications in my observation logs, often annotated to further my own understanding.
When I share my observations in an informal way (as here at CN or on my personal web-page), I normally just post my observation logs "as is", usually without wanting to clutter the documentation with long lists of references and credits to academic research, articles and litterature. If you think about is, how much of actual astronomical information that is typically shared on astronomical fora has been collected by the poster himself, and how much is properly referenced and credited as required by scientific publication? Not much, really, -- and that is OK in my opinion.
When publishing observations in articles and books, it is another story. When I collected some of my observations for publication in the NightFall Magazine and on LuLu books, I did take the time and effort to properly reference all information and illustrations, as should be.
As an example, i have an amateur astronomy friend who (like you) has done a lot of personal observation and research into open clusters, encompassing photometric and spectroscopic recordings and analysis, including studies of stellar evolution with generation of color-magnitude diagrams for the OCs. All with a small RC-reflector from his backyard. So it is certainly possible (and fun and educational) to get results in this field, but OC membership selection for an amateur is restricted to an estimated cluster radius, whereas for a professional, membership data is currently based on precise stellar kinematics (proper motion and velocity data) that effectively can exclude contamination from field stars.
If you search the CRF thread, you will find some of my observations of R associations (Mon R1 and Mon R2 & following) plus on Strömgren Spheres (68 Cyg).
Thanks again!
-- Allan
Thanks for the reply! I'm not going to use multiquote, as that tends to confuse me, so I hope you can follow the following :-
Indeed, I tried that once long ago, but unfortunately I had no staying power! Also, observing chances declined dramatically. A little bit of quite basic physics, often with no maths, goes a long way in astronomy. It was just after I bought the Hipparcos conference book and data CDROMS. Especially as a lot of things are set up (eg logarithmic scales etc, or units relative to the Sun with the Sun being = 1) so you can think of things in simple arithmetic terms, sometimes just addition and subtraction or relative values!
I tend to be spotty in my traget of concentration, and or jump about needlessly at times. I blame the internet. I find it very difficult to read a book cover to cover anymore, for instance, I'm too used to jumping around web interfaces to pick up information. Can't get back into the concentrated and single track though processes, and will sometimes hatch on to one aspect and dig deep into it like a puppy worrying a slipper, whilst barely glance at something else of a similar nature.
Coincidentally, I am also very interested in many of the aspects you are, what I somewhat lamely call the Galactography or even the Galactomorphology, the structure of it all, both as classes of things and also as a whole, it really helps the understanding of it all does the contextual aspect.
However, from the look of all your data and clips from sources, I've been slipping a great deal! I must have missed out on one or two review type sources, especially given all those HR diagrams you have found.
The last thing I concentrated on was using GAIA EDR3 G, Bp and Rp and parallax to make HR diagrams in terms of both variability type and spectral type via crossing it with the GCVS, which I quite liked. Similar for common motion and distance double stars, in that case using LAMOST data too, but I haven't figured out a way to represent the A and B stars in a connected way graphically, just one for A stars and one for B stars, but no interrelation route. I did try some separation in AU based histograms in relation to spectral type or delta colours or delta absolute magnitude related to said, but it didn't really work as I had no firm concept of what I was really after. Besides which, double star data are riddled with discovery selection effects, so I doubt even a well thought out approach would have much chance of getting meaningful results.
Ah, I agree, that is okay. I didn't mean to infer otherwise, formal stuff, give references, informal stuff, not so much, and if given at all just a general reference (eg to a much used entire book without page numbers and figure numbers and such).
I didn't intend to imply anything underhand, it is just in the computer age it is not always possible to tell what has been designed formally in a publication and cut and pasted, or what some skilled people can do to augment their observations. Some were obviously from sources, especially heavily annotated and coloured graphs and plots. However, some plots could have been generated with something like gnuplot and some data from VizieR, and even the evolutionary isochrones and the like could be formula-ed in. So it wasn't always clear. Also, to be more honest about it, I thought it easier to ask than to keep looking in the thread, given the thread's size ; )
Indeed, I had a thought and attempt at moving groups when GAIA DR2 came out, but gave up as I didn't have the mathematical skills. Binaries are easy enough, but even triples can become problematic quite quickly. Mostly getting rid of the immense number of false positives without losing the true positives, which in itself can be tedious for even binaries if you take too wide a separation.
Also, you shouldn't trust professional papers too much. The statistical tools they use nowadays are so assumption ridden a lot of the time there is more belief in results than scientific method. Most of the thoughts and ideas on Stellar Streams and exoplanets of late will look embarrassing when looked back from the future. Some stellar streams have been independently confirmed via spectroscopic studies using metallicity and the like on top of the kinematics, but most of the kinematics are using clever statistics to over-ride the fact that the errors in GAIA are far too large in real terms to do this thing. Yet some streams turn out to be independently confirmed, it seems. Yet in DR2, and to some extent in DR3, parallax for two stars in a binary that has been watched complete two or more orbits over time can have values where one is impossibly more distant than the other, by a sizeable fraction or more of a parsec, should the parallax be as good as claimed for GAIA. Things of that ilk.
It can be tricky.
A "recent" paper I saw on arxiv said most of the OB Associations it examined in Cygnus (I think it was Cygnus) were shown false by GAIA EDR3, meanwhile they had found some "real" ones in the same area, quite a few, using GAIA. I can imagine some of the Cygnus OB Associations are poorly defined, but they pretty much only confimed the big one, OB2, which has Cygnus X etc involved. And even then they redefined it and I think broke it up into subsections. This is actually pushing GAIA data to the limit, especially pre-spectroscopic data as exists now, just pretty much using low parallax values and the very broadband photometry from it, with also very few radial velocities as of yet.
It's all a bit up in the air at the moment. But that at least makes it interesting!
Given that though it is difficult to do some amateur level work, and even if, increasingly, python scripts are available to do some processing in sophisticated ways, you have to still fully follow the basic concepts, and understand python, which I cannot.
I knew I should have searched better! ; ) I thought they'd be there. Somehow I'd missed out on 68 Cyg being a Stromgren Sphere, I'd only just started in on them, and the season was more Perseus and Cassiopeia orientated at the time if I remember rightly, before high pressure sodium, and more recently the dreaded LED, street lighting came into use. The latter fully ruins sky brightness, despite being downward pointed it reflects off road asphalt very efficiently.
Anyway, thanks for the reply, interesting stuff.
Now, thanks to another thread I responded to where I mentioned I had found a handful of preprints on arxiv/astroph for chapters from a book on star forming regions, I did a deeper search and found the book was in fact two monographs, for norther and south skies, from Astronomical Society of the Pacific. As it is dated 2008, websearch revealed it was no actually available as a public access download. Scroll down and click on monograph 4, or 5, 4 is North, on the following webpage. You then get links to each chapter to download as a PDF. Pick one for an area of interest, each chapter is named after a region or major object in that region.
2008 might just be a bit out of date on some of this, but the figures and diagrams are still as valid today, and even if some are infrared, microwave or radio plots, they are at times overlain with optical, and it helps to understand the structure. Have a look, see what you think. For all I know you may have the originals in your personal library!
https://www.aspbooks.org/a/volumes
Anyway, five years, I'm impressed! Glad you're still enjoying it rather than having it have turned into a chore.
Just think, when you started on the Gould Belt, the Radcliffe Wave hadn't even been known about, and now it is claimed that the Gould Belt is not real and an artefact consequent of the local Radcliffe Wave, but apparent, not real.
There was also a paper very recent on the Local Bubble, I think I found a news item on it on phys.org. That included something new to me that I'd never heard of called "The Split", although it apparently had a more traditional name.
I wish they'd stop using common words and acronyms for things and for surveys, it makes it very difficult to find the relevant thing when doing a websearch!
I've certainly become a bit more familiar with some Galactomorphology.
Here's an Halpha image resource you may not be aware of
http://www.star.ucl....&halpha=on&i=on
I've tried to set it for 12 arcminutes boxsize on this 68 Cyg field. You just change the URL RA and DEC figures %20 is HTML code for space character. Boxsize is the size in arcminutes I think. There's a form for searching somewhere, but I find these things easier to do directly.
.fz is a new compressed fits format, if it is unknown to you, but Aladin will load them, and some things will uncompress them I believe. I just tried it, I had to play with the pixel histogram option in Aladin to see the Halpha cloudes, but it has some utility. IPHAS was around +/- 5 degrees north and south of the Galactic Equator.
