Old Scopes and Modern Imaging
ccd classic equipment imaging
917 replies to this topic
#1 Bomber Bob
Bomber Bob
  • Loc: The Swamp, LA (Lower Alabama)
Posted 07 February 2017 - 07:14 PM
Old Scopes and Modern Imaging (or, learn from my mistakes!)
Focal Length = 1000   IME, 1000mm is about the minimum to get a usable disk size on the CCD chip.
114x920 Newtonian:  C114 - Jupiter 20170110V08X02.jpg
76x910 Refractor:  Lafayette Galactic - Jupiter (GRS) 20160709V02A03.jpg
We can increase the scope's native FL by either using a Barlow or using eyepiece projection.
60x910 Refractor + OR18 + 50mm projection distance (eye lens to chip) = 2160mm:
I pushed my Monolux 4380 to its limits to get that image of Mars with Syrtis Major.  I almost gave up.  Everything has to be lined up on the scope, and the seeing has to be near perfect, and focusing is a nightmare.  ANY vibrations wreck the attempt.
I don't try eyepiece projection any more.  Instead, I use Barlows...
Edited by Bomber Bob, 07 February 2017 - 07:51 PM.
  • Ptarmigan, deSitter, Adam S and 33 others like this
#2 Terra Nova
Terra Nova
  • Loc: 39.07°N, 229m AMSL, USA
Posted 07 February 2017 - 07:18 PM
You got that image of Mars today?!?! That is amazing! It's only 5 arc seconds across!
  • Augustus likes this
#3 kansas skies
kansas skies
  • Loc: The middle of nowhere, USA
Posted 07 February 2017 - 07:25 PM
Those really are some amazing images, especially given the rather diminutive optics you're using. Have you done any imaging with your Questar yet?
Bill
  • paulymo likes this
#4 Bomber Bob
Bomber Bob
Posted 07 February 2017 - 07:49 PM
The Mars image is from April 2014.  (If you let your mouse pointer hover over a picture, you'll see its original file name - mine are coded for Scope, Target, & Date.)
  • Terra Nova, Piggyback, solarviewer and 1 other like this
#5 Bomber Bob
Bomber Bob
Posted 07 February 2017 - 08:07 PM
Barlows
One reason I tried EP first was that my vintage Barlow lenses weren't in good enough condition for digital imaging.  They doubled or tripled the focal length, but the resulting image was big & messy.  I was skeptical of the APO qualities of the GSO 2.5x Barlow, but it has made a difference.
Edmund 100x1500: Edmund 4 - Jupiter 20170127V02R03.jpg
With 2.5x Barlow:  Edmund 4 - Jupiter (GRS) 20170131V05R01.jpg
  • Adam S, Mike Spooner, KiranKumar and 10 others like this
#6 Terra Nova
Terra Nova
Posted 07 February 2017 - 08:15 PM
I see that now, by the file name 20140427T21.jpg- 27apr2014. I looked at Mars the other night in my 60mm Swift and also  Monolux/Carton 60x1000 and saw a nice sharp orange disk, albeit very, very tiny and no real discernible detail. That is why I was shocked to see this image, posted today and with no other date noted, lending to the assumption that it must be current.
  • Piggyback likes this
#7 clamchip
clamchip
  • Loc: Seattle
Posted 07 February 2017 - 08:32 PM
I never needed a barlow until I started observing with stubby modern scopes (I'm just
a visual observer) and was surprised how well the Celestron Ultima triplet barlow works
and the TeleVue Powermate. This is visual use but if the eye can see a quality product I
would imagine film or a chip would too?
I just thought I would mention it because I was really impressed  with these two products
and I see you are using barlows for your imaging.
Robert
  • Bomber Bob, Augustus, lsquaredb and 1 other like this
#8 Tenacious
Tenacious
  • Loc: Northern KY
Posted 07 February 2017 - 09:51 PM
I always enjoy your images.
  • Bomber Bob likes this
#9 Adam S
Adam S
  • Loc: ABQ, NM
Posted 07 February 2017 - 10:01 PM
That's impressive stuff Bob, it's not easy to get that kind of detail from 60mm aperture.  The seeing at our place rarely gets above a Pickering III, otherwise I'd pursue planetary imaging with my Tinsley.  Do you have good winter seeing?
#10 Bomber Bob
Bomber Bob
Posted 07 February 2017 - 10:18 PM
Thanks y'all.  Yes, the seeing here in March is close to perfect for planetary.
Got other topics to post about - the good, the bad, and the downright ugly.
  • Terra Nova likes this
#11 Bomber Bob
Bomber Bob
Posted 08 February 2017 - 11:39 AM
Robert
Thanks Robert, and I encourage folks with either of those Barlows to try them with digital imaging.  The GSO APO Barlow appealed to me in part because a few refractor owners said it seemed to reduce False Color...
#12 Terra Nova
Terra Nova
Posted 08 February 2017 - 11:47 AM
The TV 1.25" 2.5X Powermate is excellent. It is pretty much a true telecentric. I use it with one of my solar H-alpha filters.
Edited by terraclarke, 08 February 2017 - 11:53 AM.
  • Phil Cowell, Fhuyu, clamchip and 6 others like this
#13 Bomber Bob
Bomber Bob
Posted 08 February 2017 - 11:52 AM
False Color
Reflector owners have their headaches, and Classic Refractor owners have the bane of Chromatic Aberration.  False Color is quite obvious when observing with my antique Mogey 3" F14, and it's tough to reduce with digital imaging:
Took me a while to figure it out, but there are ways to limit that blue / violet ring:  Your imager should have a BRIGHTNESS control.  Setting that toward the minimum helps.  But if you go too low, the target can disappear!  I counter that by increasing the EXPOSURE LENGTH for each frame:
Adjusting these two settings really helps.  Depending on the graphics software you have, there's more magic you can work with the images to completely eliminate false color.  However, image detail degradation caused by CA is -- to the best of my knowledge -- unrecoverable.  That is, if your scope didn't grab those photons, and the chip didn't capture them, your final images won't have them.
  • Fhuyu, kansas skies and Piggyback like this
#14 tim53
tim53
  • Loc: Highland Park, CA
Posted 08 February 2017 - 12:09 PM
Mars, taken 7 years ago with Mayflower 76x1200:
And with my Celestron 80mm, f/11:
  • Fhuyu, clamchip, Sasa and 13 others like this
#15 Bomber Bob
Bomber Bob
Posted 08 February 2017 - 12:12 PM
Hardware Headaches
Most of our old scopes weren't designed for astrophotography -- much less digital imaging.  The vast majority don't have a clock drive -- a deal killer for DSO imaging.  Here's some other headaches...
Classic OTAs (Optical Tube Assemblies)
- Loose / Sloppy Focusers.  My Edmund 4" F15 is my favorite observing scope, and it's a great visual instrument, but it stinks for digital imaging.  The focuser is the least precise of any that I use:  Goofy two piece pipe drawtube that can slip & sag; friction applied by the plastic knobs rather than from separate grub screws through the housing;  slotted accessory holder that may require clamping; and, a straight rather than helical cut rack (perfect focus often seems to be between two teeth where it's least likely to hold during a capture).  The digital imagers I use aren't very heavy, but try adding a metal eyepiece projection adapter + eyepiece + imager, and you find out real quick where the weak points are!
- Dinky / Toy Finder Scopes.  Yeah, try long-exposure manual guiding with the typical 5x24 or 6x30 straight-through finder (often with a severely masked singlet objective lens!) -- one reason I stick with lunar / planetary imaging.  I added a good quality 50x600 scope to my Edmund 4, and that made keeping the target on the chip much easier.
  • Piggyback and Augustus like this
#16 Bomber Bob
Bomber Bob
Posted 08 February 2017 - 12:13 PM
Excellent Mars shots!  Did you use the original mounts?
  • doug mc likes this
#17 tim53
tim53
Posted 08 February 2017 - 12:24 PM
No, these were taken piggyback on my 6" f/10.3 Kludgescope, itself on my Tak NJP mount.
-Tim.
#18 tim53
tim53
Posted 08 February 2017 - 12:26 PM
...but I could have use the C-80 on the SP mount it came with, which has excellent tracking with the original stepper motors and Skysensor (made just after the bouncy one - mine is very smooth).  But that mount has been apart in my shop for several years.
-tim.
  • memento, Terra Nova and Bomber Bob like this
#19 Terra Nova
Terra Nova
Posted 08 February 2017 - 03:05 PM
Here are some solar pictures that I have snapped with my iPhone and classic telescopes in the past couple of years:
  • Paul Schroeder, starman876, Fhuyu and 18 others like this
#20 Paul Schroeder
Paul Schroeder
Posted 08 February 2017 - 03:47 PM
Great images!  It's very impressive to see what can be coaxed out of these older scopes.
FWIW, attached is a Jupiter image I did about 10 years ago, using a 1972 Questar duplex in very good seeing near Fort Myers, FL.
Paul
Edited by Paul Schroeder, 08 February 2017 - 03:49 PM.
  • tim53, BarabinoSr, Bonco and 18 others like this
#21 paulymo
paulymo
  • Loc: Vermont
Posted 08 February 2017 - 04:19 PM
Bookmarked!  BB can you speak to the mounts you use for imaging?  Do you use modern mounts with tracking or vintage mounts you happen to have drives for?  One of your posts implied manual but boy that seems like an exercise in frustration.
With eyesight getting worse,  my interest in EAA (as opposed to pure AP) is increasing.  And while I'd love to utilize vintage equipment to do it, it seems like more modern mounts would be a better fit.
#22 Bomber Bob
Bomber Bob
Posted 08 February 2017 - 04:44 PM
You don't need a drive for lunar / planetary imaging.  The exposures are very short, and the stacking programs can compensate for the planet's drift across the chip.
But obviously, if your old mount has a polar drive, and the alignment is good, keeping the target in the chip's tiny FOV makes imaging less stressful.  And, I've found that keeping the target close to the chip's center during the capture makes for a more detailed final image.  My 1980s Meade mount uses a battery-powered mechanical polar drive that is very accurate -- visually, it'll keep the planet near C-O-F (Center Of Field) at 300x and higher.  But my 1964 Sears (RAO) 6336 has an even older mount & plug-in polar drive that is almost as accurate.  Ditto for my 1971 RV-6 plug-in drive.
IOW:  If your vintage mount tracks good enough to keep a planet near COF at 200x or higher visually, it should do well during your imaging sessions.
I can use 300 second (5 minute) captures at 30 fps (frames per second) for 9000 frames in one video file with all 3 of these old mounts.  In general, the more frames to stack, the better the resulting image.
RV-6 Jupiter ~ 11000 frames: RV-6 - Jupiter (Moon Shadow) 20170201V02T04.jpg
I'd say this old economy scope mount & drive are good enough for planetary imaging.
In comparison, my 1956 Goto-Hy-Score - a 60mm refractor - required manual tracking:
Not bad for a small refractor, but I could've done better.  I was determined not to have a yellowish disk (something I see with my fracs), and took out too much color!
(Goto offered a plug-in drive for these mounts, and I'd love to have one - bet it's pretty accurate, too!)
Edited by Bomber Bob, 08 February 2017 - 04:57 PM.
  • Fhuyu, memento, TerryWood and 3 others like this
#23 AllanDystrup
AllanDystrup
  • Loc: 56N 12E, Denmark
Posted 09 February 2017 - 05:33 AM
     I'm not doing serious imaging with my classic scopes, but I am increasingly employing EAA (electronically assisted astronomy), enabling me to see fine details in faint DSO (clusters, nebulae, galaxies etc) with my small classic 3" refractor, that is fully equivalent to what can be seen visually in a 12" telescope..
Here's an example showing several Herbig–Haro objects in M42 :
And another showing the swirls in the wake of GRS on Jupiter:
Both are snapshots from live EAA sessions with my classic Vixen FL80S/640 refractor from a Bortle red, suburban backyard just N of Copenhagen.
Allan
  • Phil Cowell, Fhuyu, memento and 10 others like this
#24 AllanDystrup
AllanDystrup
Posted 09 February 2017 - 06:15 AM
A couple of attempts at imaging, with my small classic refractors:
Moon (AS63/840 early Telementor):
You can clearly see the DMD (dark matter deposits) of vulcanic glass and ash from fire-fountain vulcanism around Sinus Aestuum.
Sun (Vixen FL-80S/640),
Showing spots, granulation and flare areas
Allan
Edited by AllanDystrup, 09 February 2017 - 06:21 AM.
  • KiranKumar, TerryWood, Terra Nova and 9 others like this
#25 paulymo
paulymo
  • Loc: Vermont
Posted 09 February 2017 - 08:24 AM
"I'm not doing serious imaging with my classic scopes, but I am increasingly employing EAA (electronically assisted astronomy), enabling me to see fine details in faint DSO (clusters, nebulae, galaxies etc) with my small classic 3" refractor, that is fully equivalent to what can be seen visually in a 12" telescope.."
Love this--that's exactly what I want.  Thank you Allan--wonderful images!
  • AllanDystrup likes this
Also tagged with one or more of these keywords: ccd, classic, equipment, imaging
