What does a ZWO ADC do to focal length? Does it act like a barlow? Thanks in advance. Tom
#1
Posted 20 February 2017 - 11:12 AM
#2
Posted 20 February 2017 - 11:18 AM
It acts like an extender. The images look a little bigger
#3
Posted 20 February 2017 - 12:39 PM
In itself the ADC shouldn't change the focal length. However, it does use ~30mm backfocus so with a moving mirror telescope like an SCT it would extend the total focal length slightly (maybe 100mm?). Also, if you put a Barlow before the ADC, as recommended, the extra distance between the Barlow and the sensor would result in greater magnification. About an extra 0.6x with a shorty Barlow like the Celestron Ultima or Orion Shorty Plus.
#4
Posted 20 February 2017 - 07:39 PM
Precisely what martini said - 100% correct.
#5
Posted 23 February 2017 - 04:18 PM
Would this effect a Powermate just the same?
#6
Posted 23 February 2017 - 07:10 PM
Powermates work a little differently in that the image size does not necessarily increase with added distance between the rear surface and the sensor:
see http://www.televue.c...werIncrease.jpg for the specific Powermate you have in mind.
For those concerned about any perceived need to put the Barlow *before* the ADC - I'm not sure this isn't a fallacy. You can even just screw a "nosepiece Barlow" (e.g. the business end of a Meade #140) into the end of the camera nosepiece, affording a reasonably low magnification (e.g 1.6x).
