GSO 2" Dual Speed Crayford Focuser on the ST80
87 replies to this topic
#76 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 12 February 2019 - 11:40 PM
Here are some photos of my 2-inch focuser ST80 rig.
Edited by kfiscus, 12 February 2019 - 11:41 PM.
  • mikerepp likes this
#77 Ryan555_1
Ryan555_1
  • Loc: Phoenix, AZ
Posted 12 February 2019 - 11:48 PM
I note your list includes "ST80 upgraded with 2-speed 2" focuser." That's pretty much where I'm headed with my 80mm (except I'm looking at a single-speed focuser to start). I'm looking at spending in the neighborhood of $500 to do this since I don't have any 2" stuff at all. Is it worth it?
It is worth it! I found that investing in better quality eyepieces accentuates the scope. When I used my Q70s originally with my scope, the outer 50 percent was useless. I still loved it, but it was nothing compared to using a more premium eyepiece. After I bought my ES30 82, the scope really came alive. While there is field curvature due to the fast scope, the whole 6 degree FOV is very usable and pleasing. Gives the best views of the MW!
  • MAT_Blue likes this
#78 MAT_Blue
MAT_Blue
  • Loc: Saint Louis, Missouri, USA, Earth
Posted 13 February 2019 - 12:48 AM
Budget money for a good 2" diagonal (available used for $75+) and good EPs.  I use all 2" EPs or have dedicated 2-inch adapters on my last two 1.25" EPs.  I strongly feel that the views are worth the money.
I’m looking at "GSO 2" 90-deg 99% Dielectric Mirror Diagonal for Refractor" for $100 from Agena Astro.  There are more expensive one available.  You think this one is a good start?  I realize that's kind of a wide-open question but my setup will be a lot like your ST80.  I'm still researching EPs.
#79 rowdy388
rowdy388
  • Loc: Saratoga County, NY
Posted 13 February 2019 - 10:57 AM
I also did the 2" focuser mod on my ST80 with very good results. Yes, the GSO 2" diagonal is a
good product and is a good choice. Be aware that the 2" focuser plus star diagonal doubles the
weight of the original scope. Worth it IMO though as the telescope becomes a low power, wide
field specialist that can do that trick better than any other telescope. It makes a great finder scope.
That's why I usually use mine piggybacked to a larger scope.
Edit: I opted for the 2 speed version of the focuser as well. At F/5 it's a nice feature to have.
Edited by rowdy388, 13 February 2019 - 11:01 AM.
  • kfiscus likes this
#80 MAT_Blue
MAT_Blue
Posted 13 February 2019 - 05:11 PM
Did any of you guys who put the 2" focuser on an 80mm have to add an extension tube in order to get focus?  In particular, if you used the GSO focuser.  The GSO web site says an extension may be needed.
#81 kfiscus
kfiscus
Posted 13 February 2019 - 05:43 PM
I didn't need one for any of my EPs.
#82 Agatha
Agatha
  • Loc: Wisconsin
Posted 13 February 2019 - 07:04 PM
I have the standard GSO crayford focuser and no problems.  I have only heard of focusing issues when installing the linear bearing version.  The linear bearing version has a shorter drawtube.
#83 rowdy388
rowdy388
Posted 13 February 2019 - 08:45 PM
No extension needed. The whole mod was to remove three screws, pull off old focuser, install new
focuser, put three screws loosely back in, look straight through the new focuser without an eyepiece
to make sure I have a clear, round aperture, and finally tighten down the screws. Took as long to type
probably than to do. Very simple.
#84 kksmith
kksmith
  • Loc: Montana
Posted 16 February 2019 - 07:51 AM
I upgraded my ST80 with the Lunt version of the GSO 2 speed focuser which is almost half the price of the GSO branded version. Definitely a sweet upgrade to this venerable little scope.
https://luntsolarsys...cuser-3-travel/
On the other hand, I recently picked up a Skywatcher 102/F5 with the same Synta focuser, but a 2" version with a 1.25 insert. My first thought was to upgrade it also. But then I decided to strip, relube, and adjust the stock Synta focuser. What a difference in operation this makes. I can get the same fine range of focus the 2 speed gives my ST80. I can literally move it a millimeter at a time. From the factory, the Synta focuser is a weak performer, some call it "junk," but  it has everything in place that allows it to be fine tuned. And while it doesn't look as sophisticated as the GSO, it's definitely cheaper since it is already on the scope.
Ken
Edited by kksmith, 16 February 2019 - 07:57 AM.
  • PXR-5 and Ryan555_1 like this
#85 Jim1804
Jim1804
  • Loc: Raleigh-Durham NC, USA
Posted 16 February 2019 - 06:35 PM
Ken
Ken - this looks like a great option! Is it “plug and play” as described by Rowdy above for the GSO?
#86 kksmith
kksmith
  • Loc: Montana
Posted 17 February 2019 - 04:17 AM
Yes it is. Undo the screws, remove the stock focuser, replace, and attach the screws. I have the GSO SCT focuser on my C8. Other than mounting style, the GSO and Lunt are identically made with one exception - while the Lunt is rotatable, it doesn't have the knurled locking screw for rotating. You have to loosen grub screws to rotate it. It holds my 2" diagonal and a 2" Meade 50mm Super Plossl (1.4lbs!) just fine.
Ken
  • Jim1804 likes this
#87 kksmith
kksmith
  • Loc: Montana
Posted 17 February 2019 - 05:46 AM
I should add that the Lunt version does not come with a 1.25" adapter - it is a straight 2".  You would still have to buy the adapter if you don't have it plus Lunt charges shipping. I had the one from my GSO SCT focuser so it was not an additional purchase for me. Which was why the Lunt was attractively priced.
Ken
#88 Jim1804
Jim1804
Posted 17 February 2019 - 08:41 AM
Ken
Good to know - sounds like a great alternative, especially if you already have the adapter. Thanks for pointing this out!
