Problems with ZWO ASI071 smears and streaks
5 replies to this topic
#1 Christian-UAE
Christian-UAE
Posted 04 March 2017 - 01:55 AM
Hello,
I do have an ASI071 for some weeks.
Yesterday the following occurred:(I have not noticed this before but my usage of the camera was very, very limited in the last weeks)
When cooled down to minuses temperatures, streaks and smears starts to appear as soon as the camera sensor temperature dropped to minus degrees.
When switching off the cooler and the sensor reaches again positive Celsius temperatures, the streaks vanished.
Cooling down-they start again. the smears are not random but have always the same patterns...seems like wiping smears ??
This occurs whether the window dew heater is switched on or off-but I recognized there is a dew on the window from the inside.
Please see attached picture, unstretched and stretched, no filter used.
What can I do ?
Thank you very much for some hints.
Regards
Christian
Edited by Christian-UAE, 04 March 2017 - 01:56 AM.
#2 Tapio
Tapio
Posted 04 March 2017 - 02:25 AM
That looks weird -almost like textile pattern.
Maybe changing desiccant tablets might help if that's frost.
#3 Astro829
Astro829
Posted 04 March 2017 - 03:20 AM
Yeah weird, looks sort of like brush strokes on canvas.
Try a slower cool down, i. e. instead of 5 minute use 10 for example.
Look for residue (because of the pattern) that maybe moisture is clinging to then freezing.
Dan
#4 Christian-UAE
Christian-UAE
Posted 04 March 2017 - 11:13 AM
I have done some more tests and definitely when cooling, ice builds up on the sensor.
I have changed the desiccant tablets and will see what is the outcome.
During some tests with cooler just above zero, no streaks but have a look at the attached pic.
What is this rectangular shape ?
This is just in the center of the sensor (pic is cropped).
When strechting more, only this area is workable with, all other area outside this shape is "white"
Edited by Christian-UAE, 04 March 2017 - 11:20 AM.
#5 telfish
telfish
Posted 04 March 2017 - 02:54 PM
Try cooling to a lower number. I know it's counter intuitive but this camera uses residual heat from the heat sink of the TEC and routes it to the front chamber. If you cool to a higher number the heat increases and should cure this issue. You can test this out indoors. If you can get the TEC running at say 60% for a while then re test.
#6 wenjha
wenjha
    Vendor
Posted 04 March 2017 - 08:58 PM
Hi Christian
please contact us through email,sam.wen(at)zwoptical.com
seems the sensor we didnot clean very well
you may need to clean it again to solve this problem
we will tell you how to do it in email
