Revolution Imager Advanced IMX224 USB Imaging Kit
astrophotography EAA equipment imaging solar planet accessories ccd
25 replies to this topic
#1 OC Telescope
OC Telescope
    Vendor (OC Telescope)
Posted 13 March 2017 - 10:41 PM
We are excited to announce our new Advanced Imaging Kit!
Being the most affordable complete camera kit in its class, the Advanced 224 imaging kit is not only for Deep Sky and Planets but also as you advance in imaging it will continue to serve as a superb guider.  EAA (Electronic Assisted Astronomy) is the fastest growing sector of modern astronomy, you can see in almost real time deep sky objects and planetary detail you may have only dreamed about before.
We've put the complete package here at your fingertips, everything you need except a computer, tracking telescope and clear skies (please feel free to call us and I will tell you how much I hate clouds, I really do!).
https://www.revoluti...om/products/224
Clear Skies!
Mike Fowler
Head Revolutionary
Revolution Imager
888-471-9991   760-529-1414
info@RevolutionImager.com
  • Relativist, geminijk, CharlesC and 4 others like this
#2 MawkHawk
MawkHawk
  • Loc: SE Michigan, USA
Posted 14 March 2017 - 05:35 AM
Amazing deal. What is the diameter? Can the camera body be inserted into a 1.25" focuser?
#3 39.1N84.5W
39.1N84.5W
    He asked for it
  • Loc: cincinnati
Posted 14 March 2017 - 07:08 AM
Yes it is 1.25"
#4 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 14 March 2017 - 08:41 AM
The front section is 1.25" in diameter (same as those black adapters, focal reducer, filters, etc.) but clearly the rest of the body is slightly larger in diameter (about 35mm) ... and so less than 2"/50.8mm.
So the camera will go a bit deeper into a 1.25" focuser barrel than other cameras that have a different body style (helpful if you are very close in coming to focus). The narrower body style also lends itself to being used with a 2" focuser and with a suitable adapter being inserted even deeper, that's even better news for folks who have run out of inward focuser travel (potentially a big advantage for Newtonian scope owners).
https://www.cloudyni...ives/?p=7756728
#5 CA Curtis 17
CA Curtis 17
    OPT/Amazon Affiliate
  • Vendor Affiliate
  • Loc: California
Posted 14 March 2017 - 09:33 AM
Mike,
Very Nice!   Always making EAA easy and available at low cost.
Best Regards,
Curtis
#6 GoFish
GoFish
  • Loc: Wisconsin
Posted 14 March 2017 - 09:50 AM
  • Dragon Man and OC Telescope like this
#7 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 14 March 2017 - 10:15 AM
#8 Phil Cowell
Phil Cowell
  • Loc: Southern Tier NY
Posted 14 March 2017 - 02:11 PM
Nice.
#9 OC Telescope
OC Telescope
Posted 14 March 2017 - 02:19 PM
Resistance is futile!
(Hope you love it!)
  • REC likes this
#10 Phil Cowell
Phil Cowell
Posted 14 March 2017 - 09:23 PM
(Hope you love it!)
Another order placed
  • OC Telescope and fromEarth like this
#11 Stargazer3236
Stargazer3236
  • Loc: Waltham, MA
Posted 15 March 2017 - 11:02 PM
Mike, do you offer just the camera DIY? Like you did with the Revolution Imager R1 and R2?
#12 mclewis1
mclewis1
    Thread Killer
Posted 16 March 2017 - 02:43 PM
While I've got a pretty good drawer full of bits and pieces I look at Mike's new kit and think at that price I could always use another good 1.25" focal reducer and UV/IR filter. smile.gif
#13 Uzelessknowledge
Uzelessknowledge
  • Loc: Alabama
Posted 19 March 2017 - 10:21 PM
Will the zoom and all sky lens work with the RI224 camera?
https://www.revoluti...-60mm-zoom-lens
https://www.revoluti...olution-imagers
Travis
  • OC Telescope likes this
#14 OC Telescope
OC Telescope
Posted 21 March 2017 - 04:09 PM
Travis
Hi Travis,
Absolutely, however the 224 Imager does not have the 1/4-20 tripod socket so attaching the camera with lens to a tripod or piggyback adapter will be DIY, though I imagine fairly easy.
Clear Skies,
Revolution Imager
www.RevolutionImager.com
  • Uzelessknowledge likes this
#15 starblue
starblue
  • Loc: St. George, Utah, USA
Posted 30 March 2017 - 12:59 PM
Be wary of the zoom lens. Mine focuses at maximal wide and maximal long settings and nothing in between. If I handhold the lens a few millimeters in front of the camera it works at all settings, but once screwed onto the camera it doesn't.
#16 mclewis1
mclewis1
    Thread Killer
Posted 30 March 2017 - 05:32 PM
With which camera ... the R2 or the new 224 based one? Probably best to discuss the specifics with Mike but it sure sounds like the lens simply needs a 5mm C-mount spacer. I'd guess that the lens is a C-mount spacing (17.5mm) model and the camera is a CS mount (12.5mm spacing) setup.
#17 GoFish
GoFish
  • Loc: Wisconsin
Posted 30 March 2017 - 05:45 PM
When should I use the IR cut filter with the R224?
#18 Uzelessknowledge
Uzelessknowledge
  • Loc: Alabama
Posted 31 March 2017 - 09:11 PM
Hi Travis,
Clear Skies,
Revolution Imager
Hey Mike. I see someone comment they had issues. I'm about ready to pull the trigger (had to woo the wife) and wanted to see if I needed anything else to use the zoom lens with the 224.
Also, I didn't see it listed in the product page. Still have some?
Travis
#19 The Enginear
The Enginear
  • Loc: High Desert of Southern California
Posted 01 April 2017 - 05:56 PM
Mike, how does the Touptek 224 (IMX224) compare to the Touptek GCMOS, which has the AR0130C sensor?
#20 mclewis1
mclewis1
    Thread Killer
Posted 01 April 2017 - 07:52 PM
The ToupTek GPCMOS are a series of cameras with a variety of sensors. One model has the ARO, another the 224, and another the 290 ... but they are all GPCMOS model cameras. Mike's Advanced IMX224 is a GPCMOS camera.
But it's certainly a good question about comparing one with the ARO sensor with one with the IMX224.
  • The Enginear likes this
#21 seasparky89
seasparky89
  • Loc: Springfield, VA
Posted 09 May 2017 - 05:20 PM
Mike:
I have an R1 system. Can I just purchase the 224 camera alone?
Stan
  • wrpspeed16 likes this
#22 JimH123
JimH123
  • Loc: Morgan Hill, California
Posted 13 July 2017 - 05:08 PM
Travis
That 6 - 60mm zoom is not parafocal and is somewhat a pain to use.I have some Rokinon/Samyang manual lenses that work well with an adapter with the R2.
Edited by JimH123, 13 July 2017 - 05:17 PM.
#23 Herschel400
Herschel400
Posted 20 December 2017 - 02:12 PM
Hello to all
need help
i am trying to focus a 224 in the eye piece cylinder of a NexStar 8” In daylight I focused on an object miles away with a 25mm EP. Then , as recommended , turned the scope focus knob counterclockwise 7.5 turns. I do not even get a blurred image on my laptop screen. Is there some setting on the left of the Toup Sky screen that I should adjust. Trying to get the hand of this is daylight
thanks
#24 mclewis1
mclewis1
    Thread Killer
Posted 21 December 2017 - 08:00 PM
It can be a little intimidating to initially figure out exposures ... but with a little experience you'll find it becomes second nature.
For daytime testing I've found it helpful to use the Auto Exposure setting. It's under the Capture and Resolution tab. When you do this you'll notice a small box in the middle of the image, that box is where the software is sampling the image to do the auto exposure trick (you can re size or move the box if you want to have the exposure sample a particular area of the image).
This will give you an idea about exposures for bright (daytime) objects. Just remember to un click the Auto Exposure when you are working with dark images. The Auto Exposure can work for the moon but with small objects like planets and very dark images (deep space objects) it won't work well, there you'll need to manually set the exposure and gain.
Edited by mclewis1, 21 December 2017 - 08:02 PM.
  • mightymouse likes this
#25 nrcapes
nrcapes
  • Loc: Minnesota
Posted 01 August 2019 - 08:23 PM
Sounds great. I have an R2 and have been thinking about upgrading to a CMOS.  Will this work with SharpCap?
Also tagged with one or more of these keywords: astrophotography, EAA, equipment, imaging, solar, planet, accessories, ccd
