DLSR battery substitue for darksite ops
accessories astrophotography DIY dslr
8 replies to this topic
#1 ssagerian
ssagerian
Posted 15 March 2017 - 09:41 PM
I started out using my modded T3i with batteries, lots of batteries. Then I purchased a AC to DC converter that fits in the battery well and works continuously provided I had access to 110 AC. Then I hacked my AC to DC converter by adding a voltage regulator. Now I can operate off my 12V battery at a dark site. Here is the completed system:
Here is a close up of the old AC to DC converter in a new slightly larger housing, along with the 12VDC to 7.5 VDC adjustable voltage converter.
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 15 March 2017 - 10:58 PM
I did the same thing long ago.  Now I use this and a 12VDC Deep Cycle Battery that also powers my mount, laptop, radio ...etc.
http://www.telescope...?keyword=21126d
#3 drew2578
drew2578
  • Loc: The Garden Isle
Posted 15 March 2017 - 11:30 PM
Just put a simple dc to dc adapter together a buck convertor.  Tested with both Canon and Nikon camera and it works great!  Best part is that it took only about ten minutes to make wink.gif. Just input up to 30ish volts on one side and out comes 7.5 although i find Nikon like 7.7v better.
Would be cooler if it would step down from 120v AC as well as DC though :)  I only run 12V now though.
My two cents.
Edited by drew2578, 15 March 2017 - 11:34 PM.
#4 fishonkevin
fishonkevin
  • Loc: Michigan
Posted 16 March 2017 - 05:55 AM
Jim, what size fuse do you use in the cigarette lighter adapter?
#5 ssagerian
ssagerian
Posted 16 March 2017 - 07:16 AM
The switch allows me to select the AC to DC 7.5 output when I am running off AC in the back yard or to select the voltage regulator output 7.5 VDC when I am running off battery, when I go to a dark site.
#6 kd4pbs
kd4pbs
Posted 16 March 2017 - 09:02 AM
I did a similar thing; an 8 volt regulator mounted inside the fork arm and a power receptacle mounted on one of the fork arm covers for the LX200.  Powered directly from the same 12V coming in for the scope, and of course fused.  It's very convenient to simply plug the camera into the fork arm for power :)
#7 geothomas
geothomas
  • Loc: Huntsville, Alabama
Posted 16 March 2017 - 09:39 AM
I was thinking about doing this, but I am in a very humid environment and was worried about moisture entering my D810 camera if the battery door is left open all night. Any thoughts/experiences?
#8 ssagerian
ssagerian
Posted 16 March 2017 - 09:56 AM
The AC/DC adapter has a battery adapter that is inserted into the battery 'well' and the door is closed, the cable is clamped with a rubber gasket that keeps moisture out. SO you should be ok.
#9 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 18 March 2017 - 03:34 AM
My field use power system consists of a box that uses DC-DC regulators to provide 5V, 7.5V, and 13V. The 13V supply is for my mount that doesn't like to run on less than 12V. PowerPole connectors connect the box to either a 17AH gel cell or a 100AH deep cycle battery. When AC is available, a salvaged computer AC supply provides 12V and the 17AH battery is put in the circuit as a UPS backup for the occasional kicked AC power cord. The box has worked very well for over 5 years.
Also tagged with one or more of these keywords: accessories, astrophotography, DIY, dslr
