NGC 2903 w/ long focus ACHRO
3 replies to this topic
#1 jimegger
jimegger
    Vendor
  • Loc: Palmer,Alaska
Posted 18 March 2017 - 01:46 PM
We had another clear night - cold at 3 above so I put the 9.25 inch ACHRO to work with a modded Canon 6D at ISO 1600 and a Baader Contrast Booster filter for this image. There were 7 shots of 8 minutes each at f/12 (106.5 inches ) I guided manually as usual for me using a guide scope at high power with the standard double cross hair reticle. The whole scope system is hand built from the lens grinding to the mount which really tracks nicely using some Vexta stepper motors and a joystick for corrections. The objective is a BK7 crown with an F2 flint Clark style air spaced glass.
The moon is waning so the sky was fairly dark and no sign of northern lights. I could have gone 10 minutes easily but since I let the camera do dark frame subtraction 8 minutes was used to save some time. By the time I was done shooting the temperature was at -3 F.
This is full frame.
  • starbob1, guyroch, mikewayne3 and 2 others like this
#2 aacc66
aacc66
Posted 18 March 2017 - 11:28 PM
Nice image.  Round stars too.
When you say 9.25 achro.  Do you mean 9.25" diameter?  That is a big telescope.  How much it weights.  Can you lift it by yourself to the mount? or do you need help.
Alvaro
#3 jimegger
jimegger
    Vendor
Posted 19 March 2017 - 12:34 PM
The scope is 9.25 inches diameter and weighs 49 lbs. It is left on its mount but I can lift it to the cradle easily by myself and I am 65 years old. One just needs a technique and to be careful !
  • MalVeauX likes this
#4 aacc66
aacc66
Posted 20 March 2017 - 11:21 PM
That is still a big telescope.  My SCT is a 9.25" but only weights about 21 to 22 pounds with the focuser.  I do have to move in and out  if I am skipping several days between sessions and between weekends.  I will not feel safe leaving the setup during the day in a work day.
