Questar Repair Bench – Q&A Thread
72 replies to this topic
#26 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 20 January 2019 - 11:14 AM
I was cleaning up my parts drawings and consolidated all my old worn drive discs.  It's a bigger collection than I realized.
IMG 1145
  • Wisconsin Steve and retroman2 like this
#27 Les Aperture
Les Aperture
  • Loc: Central Illinois
Posted 20 January 2019 - 09:18 PM
"Questar Cymbals"
Priceless!
#28 Rpsqueezer
Rpsqueezer
Posted 20 January 2019 - 10:16 PM
OK Ben, how many serviced Qs do they represent? There are about 9-12 per telescope, correct?
Ross Schlabach
#29 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 20 January 2019 - 10:21 PM
There are three per drive but sometimes the middle disc isn’t replaced because it’s never necessary and not always included in the set. So this is 10-15 drives or maybe 6-7 scopes.
#30 troy6666
troy6666
  • Loc: Washington DC and Virginia
Posted 09 April 2019 - 03:48 PM
Hi Ben - do you know if there is a way to re-connect the excentric brass fitting and the brass lever that puts tension on the RA knob (see pic).  I really can't tell how they were attached to one another (solder maybe?).
Thanks much,
Troy
#31 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 09 April 2019 - 09:27 PM
Solder I believe. Some epoxy should probably work. Factory replacement should be inexpensive too
#32 BillHarris
BillHarris
  • Loc: northwest Alabama
Posted 10 April 2019 - 02:13 AM
I'm replacing the PowerGuide motor with an AC motor. Is the spur gear (and motor pinion gear) lubricated?. I think that I still have a can of instrument somewhere.
#33 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 10 April 2019 - 09:59 AM
They are dry in my experience. Unlike a gear that has multitudes of revolutions per unit time and millions of cycles in a lifetime, the main gear gets maybe dozens of revolutions per year if used with unusual frequency. I am also reminded how surprised to learn early in my Mechanical Engineering coursework that normal gears have zero rubbing friction. They roll like a scrivener’s blotter.
My main observation is that systems that will be expected to operate for decades without intervention are often better dry because lubrication can fail and cause more problems than it solves. I’d say that lubrication of the prism shuttle and Barlow control are essential and that the focus train lubrications is also important. I can’t think of anywhere else that needs lubrication other than the main axles for RA and dec, pinions etc.
#34 BillHarris
BillHarris
Posted 10 April 2019 - 05:33 PM
That makes sense. At 1/2 rpm and the light loading the geartrain will have, lubricant is not really necessary. Lubricant attracts dust and gets gummy after a few years. With the more common (and more precise) worm gear system, the action slides the gear teeth together and lubricant is necessary and frequently needs cleaning and relubing.
The mounting holes in the motor flange have been enlarged and I assume I'll need to set a backlash with the gears. I'll assume the spur gear is concentric with the axis and set the backlash close to zero, or very small. I'll see what it feels like before I remove the old "servo" motor.
#35 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 14 August 2019 - 10:43 PM
I have two sets of 3.5 optics soon headed to Cumberland for reciting. If anyone wants to join it can help pricing to have a batch order.
I just need to remove a mirror from a Fast Focus II, which I haven’t done before.
The corrector was a bear because it was essentially glued in. But I had the recommended adhesive dissolver and was able to push it out without damage.
I also dismantled and partly refinished a 1964 standard today. That’s the other recoat set. Rather dirty on the exterior and mostly cleaned up with wet cloth. I think someone did a lot of eating when observing.
#36 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 15 August 2019 - 10:50 AM
Before and after cleaning a grubby scope:
IMG 2435
How to (carefully) remove a barrel from the base for access to the mirror.
IMG 2440
#37 Gregory Gross
Gregory Gross
  • Loc: Pacific Northwest
Posted 15 August 2019 - 12:34 PM
Are those photos of that distressed Questar that was listed on eBay here and here earlier this summer and that you reference in this post of yours from last month? Keep those photos coming (maybe start a new thread?) -- I absolutely love seeing the progress you make restoring those old Qs.
#38 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 15 August 2019 - 03:29 PM
Yep, that's the one.  It was an odd sale with a friendly seller.  They took a long time after the close to ready their paypal, and having seen here worse optics problems I urged them to hold and we should resolve that before shipping.  I advised that they relist with the new photos, but they decided to sell to me for a discount that accounted for the the need for a recoat (which isn't badly needed, but still justified).
Here's more of the before pictures.  The rear of the corrector has some water-drop looking streaks in the coating, and the mirror has some little lines of sparkles.  Not pretty, but unlikely to much affect performance.  But once it's out might as well recoat.  It's like there was fluid in the tube that affected it, but I can't image.  The scope was dirty all over, and I'm not sure how the eyepiece will clean up.  The pinion for the dec drive had the tip broken off so that didn't move.  Nothing major, just clean and polish.
IMG 2313
IMG 2314
IMG 2318
IMG 2315
IMG 2325
  • retroman2 likes this
#39 Gregory Gross
Gregory Gross
Posted 15 August 2019 - 04:30 PM
Seeing those pictures both mortifies me (I know I can be fussy about my optics and can get easily upset by so much as a fingerprint, but how on earth does someone let something like that go?) and makes me think that that scope is a wonderfully fun restoration opportunity. I think that, if I attempted my first Questar restoration project, I'd probably go for a scope in that condition. For sure, there would be no worries about messing up something that was already in bad shape.
Keep us all up to date on your progress!
#40 BillHarris
BillHarris
Posted 15 August 2019 - 10:34 PM
OP said:
"How to (carefully) remove a barrel from the base for access to the mirror."
Strap wrenches-- automotive tools?
#41 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 15 August 2019 - 10:46 PM
It’s OK. I have a Carpod.
And Sears doesn’t sell many telescope repair tools. Must make do.
#42 BillHarris
BillHarris
Posted 19 August 2019 - 09:06 PM
Nothing wrong with that. A tool is a tool. Didn't remember seeing strap wrenches with that nice rubber strap.
#43 Wisconsin Steve
Wisconsin Steve
  • Loc: Wisconsin
Posted 20 August 2019 - 07:33 AM
I haven’t had to use strap wrenches yet but was successful in unscrewing a very stuck barrel after warming up the threaded area with a hair dryer.
#44 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 20 August 2019 - 07:44 AM
I definitely will use heat and manual torque before getting out the strap wrenches.
I also have a fixture that bolts to the naked back plate with prism removed and clamps to the bench so that I don’t need to wrench the control box. But the illustrated method was handy if potentially risky.
  • Wisconsin Steve likes this
#45 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 20 August 2019 - 04:24 PM
Cumberland confirms that they will soon (weeks not months away) be doing a Questar run, and they will be including some re-coats for me in that batch to save my costs.  Anyone interested in joining in is welcome and I'm happy to help coordinate.
Sorry I don't have exact pricing.
#46 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 26 August 2019 - 04:02 PM
Cumberland kindly offered me the choice on a 1964 set I sent in for recoating either to recoat to modern standards, or alternatively for a more historically-correct condition, to leave the front surface uncoated as they advised was the norm back then because the factory was concerned about coating degradation due to owners cleaning the front surface too much.
I picked the modern approach, and would think that's the easy choice unless perhaps restoring a 1954-55 model.
Cost for two sets (one without mirror) was $500 total.
#47 Gregory Gross
Gregory Gross
Posted 26 August 2019 - 07:01 PM
Great info on multiple counts - thanks for sharing! This raises the question of when Questar/Cumberland began coating the front surface of the corrector.
I would also imagine that the cost for recoating differs from time to time. $500 seems low for that amount of work.
#48 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 26 August 2019 - 07:52 PM
This was a good price because it holds until a Questar new production. It’s not atypical but it’s not guaranteed so get a quote before assuming. It could be several times more if it’s one order.
#49 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 27 August 2019 - 01:16 PM
Alas, the mirror of the 1964 set had a bad chip on the back that turned into a crack on the front, and the set has been deemed unusable.
I may transplant from one I have or keep an eye out.
#50 Optics Patent
Optics Patent
  • Loc: Dallas TX
Posted 29 August 2019 - 02:04 PM
Linhof tripod tip:
The levers that tighten the different nuts at the collar for the riser and head have a nice feature in that the handle can be with drawn and reoriented.  This can get the lever out of the way of other motions.
But these can get so gummed up that you might not even realize they are mobile.  Here's how to loosen them up:
  • Optional: a drop of solvent at the shoulder where you'll doubt whether there is a seam or not (there is).  Careful not to damage finish.
  • Unscrew the large flathead screw.  There will be a spring inside.  When operating right, this is that the handle slides back against and is limited by.  The spring bears the handle toward the nut it surrounds.  These just need a little cleaning.
  • From the end exposed by screw removal, you'll see an aperture (maybe 1/4" or less)  This reveals the back end of the nut, with the smaller tapped screw hole.  Find a large pin punch to fit in the aperture.
  • With the shoulder of the handle supported (like by vise jaws) tap the pin punch to push the nut out.
  • Clean up all the gummy grease, and apply a light film to the appropriate surfaces.
