Here's the latest Sony A7S problem I'm working on. Image taken with the Tak Epsilon under 20.8mag/arcsec/arcsec skies:
There's a wide purple swathe going top to bottom through the image left of centre. This is a particularly bad example but all my images display a similar problem to a greater or lesser degree before I apply heavy gradient removal techniques.
I've already eliminated darks and bias frames as the cause - the problem remains when the darks are removed and when the bias is replaced by a synthetically generated bias. So the issue is probably some kind of mismatch between lights and flats. The flats are dusk sky flats, so banding from an artificial light source is not to blame.
In this particular example there is a fairly sharp change from purple to green at the left edge of the purple swathe. It could be related in some way to the concentric coloured banding caused by the in-camera scaling applied to the digital data but if so, why would it appear as a broad vertical swathe?
Another possibility is the UV/IR filter I'm using or the anti-reflective coatings on the replacement glass I used when modifying the camera. But why would that manifest itself as vertical swathes?
My current line of attack is to shoot various sets of flats at different ISOs and with different positions of the back of camera histograms.
If anyone has any other good suggestions then I'll be happy to hear them.
Mark
Edited by sharkmelley, 04 May 2017 - 05:13 PM.
