Saturn - May 15, 2017
4 replies to this topic
#1 yock1960
yock1960
  • Loc: (Mostly Cloudy) Ohio, USA
Posted 19 May 2017 - 06:51 PM
Reasonable seeing, so I get 2 images out of 5 straight opportunities this past week. April seems to be a better month, for Saturn at least. Only seven more years until Saturn climbs back up to the height that it was when I started imaging it and just 14 years until it climbs to ~72 degrees elevation in these parts! How many camera generations is that going to be? Assuming of course, that I'm still around to see either....fingerscrossed.gif
18 minutes in WinJupos, C9.25 @ f/16, ASI224MC, ASH ADC, 0626UT, 150% re-sample.
Steve
  • Sunspot, jim kuhns, George Bailey and 10 others like this
#2 NiteGuy
NiteGuy
  • Loc: Arizona
Posted 19 May 2017 - 07:29 PM
Is that the same ringed planet from the same solar system as last time?
Nice work, great shot!
#3 Timothy S
Timothy S
  • Loc: Bakersfield, CA
Posted 19 May 2017 - 08:08 PM
Steve:  That is a really nice image and you can clearly see the hexagon.  I've been thinking about a C9.25 to complement my 4" APO which is just too small for the planets.  Are you using the factory visual back / focus system or is an aftermarket system needed to hold the camera plus ADC ?
#4 yock1960
yock1960
Posted 19 May 2017 - 08:24 PM
Thanks Tim! I use a Rigel Systems DC focus motor with their nFocus controller on the factory visual back. I don't find focus shift to be a big problem, so a Crayford just adds back focus. If the seeing is good, then, is the extra precision of a stepper motor needed? Eventually, when I run out of other things 'astro' to buy, I may look to upgrade to something from Moonlite and go stepper.
The C9.25 is like a souped up C8, no different in use as far as I'm concerned. I'm finding moving up to a C11 tougher with the low planets though.
Steve
#5 yock1960
yock1960
Posted 19 May 2017 - 08:28 PM
Thanks! Yeah, that's the thing with Saturn at low elevation. One decent image looks about the same as another.....unless the seeing is above average, or very good in any case.
Steve
