Plato image - strange
7 replies to this topic
#1 Joe1950
Joe1950
Posted 19 May 2017 - 09:56 PM
Greetings.
With relatively small scopes and typical jet stream seeing, the craterlets found in Plato are difficult visually.
But with a 102mm refractor, I grabbed a couple single shot images of the area and thought I could make out a craterlet!
[attachment=869246:Plato area.jpg]
Zooming in.....
[attachment=869247:plato zoomed.gif]
That looks like a craterlet. Even the shadow is correct. I see the same thing in another image I took. But if you look at Plato in Virtual Moon Atlas, there is nothing there of any significance!
Edited by Joe1950, 19 May 2017 - 10:16 PM.
  • jeremiah2229 and Augustus like this
#2 SKYGZR
SKYGZR
  • Loc: Planet Earth, Milky Way Galaxy, Speeding towards the Virgo Supercluster
Posted 19 May 2017 - 11:31 PM
Perhaps it's "new"..and you may have discovered it??
  • Joe1950 likes this
#3 Redbetter
Redbetter
  • Loc: Central Valley, CA
Posted 20 May 2017 - 01:56 AM
One hot pixel next to one cold pixel?
#4 einarin
einarin
Posted 20 May 2017 - 03:20 AM
That could be just small dust mote or some other contamination in optics.
Have see like that many times.
#5 Joe1950
Joe1950
Posted 20 May 2017 - 04:01 AM
#6 ChrisWhite
ChrisWhite
  • Loc: Colchester, VT
Posted 20 May 2017 - 06:20 AM
How far apart in time where the multiple images you took?  Were you just doing a rough PA or is this a precisely aligned pier mounted setup?  If you had any drift at all of the moon within the frame between the images that had this "artifact" and the "artifact" stayed in the same exact place within the Plato.... it could be real!
#7 dkeller_nc
dkeller_nc
  • Loc: Central NC
Posted 20 May 2017 - 09:07 AM
Report it, then get someone else with a long focal length scope to image it.  You might've found something!
#8 Joe1950
Joe1950
Posted 20 May 2017 - 10:30 AM
I was not doing precise tracking at all. The moon drifted between frames. Looking at the other frames, there are several marks that are similar but none at exactly the same spot and none clearly defining a crater as the sample here seems to.
I'd have to assume it's artificially induced at this point. Maybe when the moon comes around again, someone will image it properly and see if anything is there - but I doubt it...
Also, the other craterlets that are definitely there are not showing up at all. That's suspicious too. Oh well. shrug.gif
As Brando said, "I cudda been somebody."
Thanks for the info and comments all!
