ZWO 1600MM-C Flipping on the Power Switch for the First Time
7 replies to this topic
#1 Seanem44
Seanem44
  • Loc: Stafford, VA
Posted 06 June 2017 - 05:27 AM
Yeah... another ZWO 1600 post.  These seem to be in abundance, but I think its good for the hobby/passion, opening up CCD imaging (yes, I know it's technically CMOS) to thousands of new imagers.
I turned mine on for the very first time last night.  I've owned it for three months (at least), however, preparing to move to a new home (Red Zone to Orange... Yay?) has kept me very busy.  With the Almost Heaven Star Party approaching in July, I decided it was imperative I started to learn my new system.
Last night a I did a dry run hooking the camera up to my laptop.  This was crucial. Last week I downloaded SGP, ASCOM and all the necessary peripherals.  I downloaded the required ZWO driver last night and was up and running.
SGP... wow!  Kind of busy looking.  I tried to wing it, but found myself in the manual.  After going through the getting started portion for mono cams, it was fairly simple.  The filter wheel worked perfectly in conjunction with the camera.  Really impressed.  I was able to cool the camera, and SGP seems to be as easy or as hard as you want to make it.  Really reminds me of BYE, though at a much higher level.
I ran a couple of sequences, just taking black frames.  I have my image train setup, but it terminates at my Esprit 100ED's field flattener at this point.  I did not connect to the OTA.  Doing this though, I was able to get the "starless" images, save them, and see how the system works.   So baby steps achieved.
Now for the questions...  and there are a few.
I set the gain.  Is offset labeled as something different in SGP?  I think the gain had a drop down with literally every number available up to whatever you need.  Thought that was interesting as opposed to a system where you could just type in your preferred gain.
File size.  Yeah... I heard they were big.  30 MB.  That's huge.  And I only have 1TB on my laptop, half of which is gone.  I can't imagine short high gain images being efficient unless I have them save to an external drive.  Of course, I see there are benefits to both.  So what is better?  Will an hour of medium-ish gain images at 1.5 minutes be as good as the same integration of high gain 30 second images?  I know one will eat up more hard drive space.  Coming from the DSLR world, its hard getting used to high gain being good, where 3200 ISO will be noisy as anything.
The AC adapter I purchased doesn't have an on/off switch.  Turning the camera off is achieved by unplugging it from either the power source of the camera.  Is this bad in anyway, or am I worrying for no reason?
Actually, those are the only  big questions right now.  Next step is move in two weeks, then do another dry run this time with the Mount, Scope and guiding Camera added in to get them all talking together.  Then the last step will be actually trying to image with them.  That, and praying I estimated everything correct and have the right back focus.  This is what scares me.
I also downloaded cartes, but I think all of this might be more advanced for the time I have before AHSP and will likely just use the old fashioned method of using the mount's goto to slew and then starting that way.
One last question... when I connect my Orion SSAG, PHD within SGP will run it, correct?  Or do I need to do that outside of SGP?
So much to learn in so little time.  Any hints, tips or help would be greatly appreciated.
I even stacked my "black' frames in DSS just to get fiddle around.  In one year, I had already forgotten that is where the FITS files go.  It's all coming back.
Thanks guys.
Edited by Seanem44, 06 June 2017 - 05:30 AM.
#2 baron555
baron555
  • Loc: Lockport, IL
Posted 06 June 2017 - 06:01 AM
Read Alex's SGP First Week article, its on the website.
  • Seanem44 likes this
#3 Darren in Tacoma
Darren in Tacoma
Posted 07 June 2017 - 08:42 PM
I can't answer all your questions, but I will tell you this:
This camera benefits from lots of sub exposures. If you don't have enough memory to store it you will need another drive or another laptop. You have enough invested in this hobby, (money and time) that you don't need drive space to be your limiting factor.
As far as SGP and PHD, I have had a few problems. I can only get them to work together by launching SGP and connecting my equipment, then launching PHD and connecting. SGP has a window for PHD available, but as far as I know, and I could be wrong, it only shows you what PHD is doing. If you need to change settings you need to pull up PHD.
#4 Darren in Tacoma
Darren in Tacoma
Posted 07 June 2017 - 08:46 PM
Also, SGP will connect and disconnect your camera. You don't need to unplug it. You can set SGP to warm your camera up at the end of the sequence. When your done, just disconnect all equipment, close SGP and start unplugging.
#5 Kaos
Kaos
  • Loc: VA
Posted 07 June 2017 - 09:17 PM
Thanks guys.
You control the gain setting with this camera by clicking on the wrench beside the camera. That will bring up the ZWO ASCOM driver dialog where you can set the gain. See https://astronomy-im...n-ascom-driver/
Without getting too complicated. The higher the gain the lower the well depth of the pixel and the faster it will saturate. Think of a glass of beer. If you pour it in slowly, it does not foam up as fast and does not overflow (akin lower gain = to the higher well depth). If you pour the beer in fast (higher gain with lower well depth)) the glass will overflow. The offset is essentially the black point. File size is the same at ~ 32MB. I use an external HD to save my images to. They DL to my HD and I copy them onto the external.
Target and exposure time will dictate your gain setting. On a bright target like M42, you will saturate the core if you use anything above the highest dynamic range setting unless you use REALLY short subs and that will require a LOT of them to control noise. I am in a burgundy zone (a little darker than a red zone). On faint targets, imaging at a higher gain setting is not a problem. Also, if you use NB filters, a higher gain setting is probably preferable on most targets.
This camera does like a lot of shorter subs. I can do 3 min L subs (and 6 min GB subs and longer R subs) from my burgundy zone without a problem with a median histogram reading of about 1250. There are a lot of posts and threads on here that discuss this issue. a darker site like yours you should be able to get a lower median histogram reading and better SN ratio on your target than I get.
I do not have any issues with SGP and PHD2. However, you must use PHD2 to control guide settings with the exception of dithering. You should dither frequently with this camera to substantially reduce fixed pattern noise. There is a lot of discussion on this site on that issue to. Most recommend 5% of total subs. So if you are taking 100 L subs, you should dither every 20 subs. I generally do it a more aggressive (like every 2-5 subs depending on the total number I am taking).
Kaos
Edited by Kaos, 07 June 2017 - 09:18 PM.
#6 Jon Rista
Jon Rista
  • Loc: Colorado
Posted 08 June 2017 - 12:44 AM
First off, congrats! It's a good, capable little camera. Lots of fun!
With the post-2.6.0.17 builds of SGP, for the time being you need to use the "Not Set" option in the gain by binning settings in the Camera settings of SGP. You then set the gain and offset within the ASCOM driver. Offset is a key setting with these variable gain cameras...they allow you to maximize dynamic range by minimizing the offset, rather than using one overly large offset that could work at any gain setting. However, ASCOM currently does not have support for exposing offset control, so SGP does not have any way of setting offset itself. By using the Not Set option and configuring within the driver, you can control both offset and gain appropriately.
Another ASCOM setting to be aware of is USB Limit. This is a critical setting for minimizing FPN. At a low setting (minimum is 40), FPN and glows can be much more significant:
At a high setting (maximum is 100, but should never use more than 90 to maintain stability and reliability), FPN and glows can be much lower:
You want to choose the highest USB Limit setting in the ASCOM driver that is reliable and stable. You can test this with the frame and focus exposures in SGP. If you set USB Limit too high, then SGP will simply not download the frame. You can stop the F&F exposure then notch the setting down in the ASCOM driver little by little until all F&F exposures download reliably. You want to keep that setting fixed, don't change it if you can avoid it...changing it will result in changes to the FPN, even if you restore it back to the same setting. The changes may be slight, but it can still invalidate existing calibration frames (which would otherwise be reusable for months.)
Think of gain as a means of optimizing the camera performance to your scope and skies. If you have a really fast scope under really bright skies, then you will need to use Gain 0. You will probably suck photons down so fast that you might not get more than 60-90 second subs, and you could easily acquire so much signal that you'll swamp read noise by 100x or more, and have 99% stacking efficiency.
On the other hand, if you have a long focal length scope at a really high image scale (say SCT f/10) under very dark skies, you could probably use the max gain setting (well, max "viable" gain, the driver range goes from 0-600, but for this particular camera, any setting over 300 is just throwing away DR for no additional benefit in read noise) without any real issues with clipping. Further, at such an image scale with minimal LP, you could probably use fairly long exposures as well.
The general idea is to find the setting that gets you the minimum read noise with no clipping or acceptable clipping, at an exposure length you can handle. Using the longest subs possible is not necessarily ideal...at lower gain settings, quantization error can be quite high. Depending on what you are doing, you may be able to swamp the quantization error quite handily with skyfog noise (i.e. LRGB), however in other cases you may have a tough time swamping the noise and quantization error at all, resulting in issues with posterization. Dithering can help a bit there, however dithering is more effective with more subs... You can see how low gain and long subs are a bit counter-intuitive with this camera. This camera DOES benefit from stacking at least 80-100 subs, and can continue to benefit from stacking 250-300 subs. With effective dithering, I've been able to see continued improvements stacking upwards of 1000 frames, however it's not really necessary to go beyond 300 in any normal DSO imaging circumstance.
If you are concerned about disk space, you could try to base your exposure lengths off of your integration time goals and sub counts. If you wish to integrate 6 hours per narrow band channel, and want no more than 80 subs, then you would need to use 270 second subs. Find the gain setting under your average skies that will allow you to use that exposure length, make sure you don't clip too much, and there ya go.
Because with variable gain you have variable dynamic range, you might want to optimize your exposures a little more than that. The main thing to check is, assuming you aren't already clipping or clipping too much, are you swamping the read noise effectively? There are several guidelines to help you determine that...the 20xRN guideline, the 3xRN^2 guideline, etc. Pick one that you feel is effective, measure some of your subs, and figure out if you are sufficiently swamping the read noise with those 270 second (or whatever) subs. If you are, and you may well be more than sufficiently swamping the noise, then you might have found your sweet spot. If you find you are clipping too much, and your exposure are more than sufficiently swamping the read noise, then you have more room to optimize...maybe use 210 second subs.
The camera is actually powered off the USB 5V only. The power adapter is purely for the cooler. This camera has built in cooler throttling, and the heatsink has plenty of mass to absorb the heat load if you just turn the cooler off without a warmup period. So there should be no harm in just pulling the plug. However, it's probably more ideal to make sure the cooler is turned off in SGP first before unplugging.
SGP works with PHP. You will need PHP to be running in the background...so you should just connect PHP normally.
With CCD cameras, you have column and cluster defects and RBI. With CMOS cameras, you have glows and FPN. Now with CCD cameras, read noise is often high enough that many of the sensor defects are hidden by the noise. With CMOS cameras, read noise these days is often so low that FPN starts out at a larger magnitude, or at the very lest it may only take stacking a dozen subs or so for FPN to grow larger in magnitude than read noise. This makes dithering a very critical part of imaging with CMOS cameras. You want to make sure you are dithering enough and dithering by large enough amounts to allow any remnant FPN in your calibrated subs to be averaged out. You want to dither at least 5 pixels each time.
Here is an example of FPN reinforcement with undithered subs (example created from dark frames to demonstrate worst case FPN):
And here is an example of dithering subs (example created from same set of dark frames, with random offsets applied using the dynamic crop tool in PI):
The scale of the dithers in this test case were 3-10 pixels. Note how the fine scale FPN (including the ray structures in the glows) have all been completely eliminated. Also note that there are some larger scale pattern structures that a 10 pixel dither was not quite large enough to average out. This is the worst case scenario, these are the effective corrolary to uncalibrated, read noise limited subs (i.e. narrow band subs from a dark site, with areas of true black sky that are read noise, and FPN, limited. With proper calibration, most of the FPN would be eliminated. Dithering will usually take care of the rest. If for some reason you still have some remnant FPN, deeper exposures to swamp more of the read noise can be effective, if an option...as a larger skyfog offset can effectively "bury" the FPN.
Depending on how many subs you plan to stack, you may be able to sparse dither. If you are stacking 80 subs, you might want to dither every frame. With 100 or more subs, you could dither every two frames. With 200 or more subs, you could dither every 3 maybe 4 subs. This applies per channel. You might acquire 100+ L subs but only 30 each for RGB. Dither L every 2 subs, but dither RGB every 1 sub.
Another key factor with CMOS cameras is the glows. Glows on the ASI1600 are not bad, and easily calibrated out. However, you must make sure you cali brate effectively. With exposures 90 seconds or shorter, you want to stack 36-49 frames per master. For exposures 120 seconds and longer, you probably only need 25 frames per master. When you calibrate, because of the potential for bias shading differentials, you should NOT use both a master bias and master dark to calibrate the lights. Use only a master dark (which will have the bias in it). Further, make SURE you are NOT scaling those darks (i.e. disable any kind of dark optimization). Dark scaling will missmatch the glows, and they will either not calibrate out, or could result in inverse calibration (the glows could become dark spots). Because you will never scale the darks, there is no reason to use a bias on them or the lights. Just use the master dark.
Here is an example of dithered darks that have also been calibrated by a 25-frame master dark:
Almost perfect. ;)
Regarding flats. Flats will likely be fairly short. However, recent testing I did indicated that there is some quirky behavior with exposures shorter than 0.2 seconds with this camera. Beyond 0.2 seconds, the behavior of the camera normalizes:
Flats will require the bias offset to be removed, however you will want to make sure that both the flats and the bias frames are no shorter than 0.2 seconds to avoid issues with variable bias shading and incompatible offsets. Using biases of 0.2 seconds and flats of 0.2 seconds or longer, and the issues that were showing up in my recent testing disappeared.
One potential problem with this camera, and it does not occur for everyone, and may have as much to do with the scope as the camera, is microlens diffraction. In many cases it just shows up as a bit of diffraction spikes around brighter stars. For particularly bright stars, however, especially with large unobstructed apertures (i.e. large refractors), it can be a problem:
Something to be aware of. I generally just try to avoid stars this bright (this is Gamma Cass). I also think I have a bit of a worst case scenario, with a 150mm aperture f/4 refractor...bright stars with this scope can be INTENSE, a lot more intense with a 150mm aperture than say an 80mm aperture (even if both scopes were f/4, aperture counts more for stars since all the light is concentrated into a point on the sensor.) I cannot say with certainty that this is why I get more microlens diffractions than other people, it's just my working theory.
  • seigell, *Axel* and cyber like this
#7 Kaos
Kaos
  • Loc: VA
Posted 08 June 2017 - 01:08 AM
Jon...how in the world do you get the images between the text? For the life of me I cannot figure out how to post images in between the text... Your point about the FPN and the 90 setting is interesting! I will have to double check what mine is set to. I know it is not the minimum...but it is worth checking if it will help with the FPN. Also, with my F7 Orion EON 115 refractor, SGP set the exposure time to .10 secs (using the calibration wizard) to get a 20K level on my L filter (as Sam recommended 20-30K for this camera). I am using the Gerd Neuman FP for my flats. They seem to correct the images fine as I have not noticed any crazy results after calibration. Maybe a noise issue as opposed to FPN lines? I have the Gerd filter to reduce the FP illumination but with this scope it significantly increases the exposure time for flats so I run it naked with this scope. I use to need it for my LXD75 SN 8 (F4).
#8 McConkey
McConkey
  • Loc: Alberta
Posted 08 June 2017 - 10:19 AM
Sean,
   Like you I just got this camera up and running the other day for the first time and this post has been incredibly helpful! Jon's detailed response, like every other single response he has made about this camera was VERY helpful and informative!
I started out by shooting at unity gain (selected in SGP by clicking on the wrench symbol when connecting to the camera as suggested by Kaos). For testing purposes and to get used to the camera I found the results to be very impressive! I know by following Jon's suggestions we'll be able to get the absolute most out of this camera.
If you don't mind I do have another question for the group to add to the ones you have! Is there a preferred temperature to run this camera at? The other night I ran it at -15 and it was at 21% power so I know I can do lower but is there any benefits? Is there a huge difference in image quality past -15?
Really looking forward to seeing your first light Sean!
