Zeiss Telementor
293 replies to this topic
#276 oceanoprofondo7
oceanoprofondo7
Posted 08 September 2021 - 04:48 PM
Other photo
  • Corcaroli78, Terra Nova, Bomber Bob and 1 other like this
#277 Bowlerhat
Bowlerhat
  • Loc: Melbourne, Australia
Posted 09 September 2021 - 02:51 AM
I use an adapter from baader, without the extension tube. I can focus on the planets just fine.
Edited by Bowlerhat, 09 September 2021 - 07:12 AM.
  • Corcaroli78 likes this
#278 oceanoprofondo7
oceanoprofondo7
Posted 09 September 2021 - 06:34 AM
do you also have a finder bracket? can you tell me which baader adapter you bought? I took the m44 / t2, but it can't screw
#279 Bowlerhat
Bowlerhat
Posted 09 September 2021 - 07:13 AM
I think I use that one as well, to m44/T2 adapter
#280 oceanoprofondo7
oceanoprofondo7
Posted 09 September 2021 - 09:56 AM
I bought this:
https://www.teleskop...o.php/info/p579
baader told me there is only this adapter ring. how is it possible that on your telementor it can be screwed while holding the finder bracket still? and not me? but do you have the zeiss finder? because otherwise, without anything, it is screwed to me too
#281 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 09 September 2021 - 01:48 PM
You can't use the finderscope with the Baader T2 adapter, unfortunately. Ideally, you need the 20mm long original M44 extension tube with extra long threads and knurled exterior, so you can tighten it enough to hold the finderscope in place. Unfortunately, these extension tubes are INSANELY hard to find.
Clear skies!
Thomas, Denmark
Edited by Astrojensen, 09 September 2021 - 01:49 PM.
  • Corcaroli78, Bomber Bob, Piggyback and 1 other like this
#282 oceanoprofondo7
oceanoprofondo7
Posted 09 September 2021 - 04:40 PM
what I thought. in fact, I would have had a 20mm extension tube made in Italy as I imagined. you are the best! that's why I signed up, because here I know I find passionate and expert zeiss.
what about the other things i was asking about? when you have time. take your time.
Edited by oceanoprofondo7, 10 September 2021 - 12:56 PM.
  • Bomber Bob, Piggyback and mikerepp like this
#283 oceanoprofondo7
oceanoprofondo7
Posted 10 September 2021 - 12:57 PM
Other
  • R Botero, mdowns, Bomber Bob and 2 others like this
#284 Piggyback
Piggyback
  • Loc: Germany
Posted 11 September 2021 - 05:00 AM
As suggested by Astrojensen, the original Zeiss 20mm adapter for attaching a 7.5x42 finder is unobtanium. A friend made me an improved 30mm featuring M44 threading and double grooving for a safe adaption of 2" accs.
  • Astrojensen, R Botero, Corcaroli78 and 7 others like this
#285 Piggyback
Piggyback
  • Loc: Germany
Posted 11 September 2021 - 05:11 AM
Pikky of custom made 30mm at bottom and Zeiss 20mm above.
  • R Botero, Corcaroli78, AllanDystrup and 2 others like this
#286 Piggyback
Piggyback
  • Loc: Germany
Posted 11 September 2021 - 05:32 AM
This shows the "knurled" edition of the Zeiss 20mm Astrojensen was mentioning.
  • Astrojensen, Terra Nova, AllanDystrup and 3 others like this
#287 oceanoprofondo7
oceanoprofondo7
Posted 12 September 2021 - 01:00 PM
I did not understand: in my case, a 20mm ring is not enough? or do I have to make one of 20 and then others of 10mm possibly to be screwed to the first? and the thickness of the fillet, must it be the same as the original? or if I do it a little longer is it a problem?
#288 Piggyback
Piggyback
  • Loc: Germany
Posted 12 September 2021 - 02:51 PM
You may want to utilize either a 20mm or a 30mm. Length is not critical. The aforementioned adapters are merely meant to tie down the finderscope bracket.
#289 oceanoprofondo7
oceanoprofondo7
Posted 13 September 2021 - 03:16 PM
I have seen that by simply using the original zeiss 6cm tube, the finder bracket is screwed. there is only the problem that then with the diagonal and eyepieces, I do not go into focus. that's why I was wondering if it was enough just to make a new 20mm one, with the same thickness as the original pitch. while you have multiple adapters to attach the finder bracket. that's all. I'm just trying to understand, because this is the first time I have to make these kinds of changes. and I don't want to throw money away. thank you very much everyone
  • Corcaroli78 and Piggyback like this
#290 Astrojensen
Astrojensen
Posted 14 September 2021 - 01:04 PM
The threaded part on the adapter really should ideally be a few millimeters longer than on the 60mm long extension tube, to ensure it holds the finderscope solidly.
Clear Skies!
Thomas, Denmark
  • Piggyback likes this
#291 oliver55
oliver55
  • Loc: East of France
Posted 17 September 2021 - 11:57 AM
A friend has got a special adapter which it can perhaps help you :
https://www.webastro...entor_59392.htm
#292 Disciplus55
Disciplus55
Posted 18 September 2021 - 02:32 AM
I no longer have any, all sold unfortunately… but if we have 10 new potential buyers, Skymeca can make a second run maybe.
#293 Astrojensen
Astrojensen
Posted 18 September 2021 - 01:26 PM
No, the threads on it are too short to hold the finderscope ring. I've already tried that.
Clear skies!
Thomas, Denmark
#294 Astrojensen
Astrojensen
Posted 18 September 2021 - 02:07 PM
What we really need is something like this:
Clear skies!
Thomas, Denmark
