I know others have asked about encoders for the AZ8, so here are a few pics showing how it's done with magnetic 311,000 step/rev encoders and Nexus II from AstroDevices.
Key points:
1. The aluminium knob Losmandy fit on top of the alt axis is removed and replaced with a new knob (black) with a central hole. This knob supports a black plastic bracket that holds the Nexus II box (its about the size of a cigarette pack) and on top of that I have placed my iPhone 6Plus, which is in an OtterBox case held in place stuck to the Nexus with velcro.
Unfortunately so many piece are all black so they don't photograph well. I'll try again when it stops raining here (weather has been wet, for weeks).
2. The cable for the azimuth encoder is run down through hole in that knob down through the hollow azimuth axis and out from underneath.
3. The encoders are just a ring that sits on a black delrin ring that is a very tight fit on each axis.
For the altitude axis, remove the dovetail, the rotating clutch disk, the wavy washer and black spacer. Install encoder which is a very tight push-fit on the axis. Then install a set of 6 stainless pins to transmit the clutch pressure without straining the encoder, a thrust bearing and its washers, the clutch ring goes back on (without the wavy washer) and the dovetail mount.
The alt axis is unfortunately too short to fit the wavy washer in but it doesn't really matter; the clutch is nonetheless adjustable without it and very positive when clamped firmly which is a blessing when assembling the scope on the mount (or disassembling) which is usually when it wants to swing down suddenly.
The azimuth axis is similar though Losmandy left enough length to accommodate the wavy washer as well, so the azimuth clutch has its original feel, i.e. gradual tension.
4. It comes with instructions and is relatively easy to use, I had no problems with Sky Safari.
5. It is well worth getting out the allen keys and adjusting your worms carefully so there is no slop and no chatter in each axis. Properly adjusted the mount moves beautifully smoothly and precisely in response to the worms, and pushing it around the sky is a doddle...
Edited by luxo II, 10 June 2017 - 06:13 AM.
