CCD vs CMOS (ASI1600MM) - Have you used both?
2 replies to this topic
#1 midnightlightning
midnightlightning
Posted 19 June 2017 - 04:39 PM
I am on the verge of buying an SX814 CCD but have spent a few evenings looking at posts, and the image thread, on the ASI1600MM - Cooled.
Some of the ASI1600MM images are superb although I find the main object colours in many to be too bright/saturated whilst lacking colour in stars (probably my personal taste vs the processing used rather than due to the camera).
I have also read of issues with sensors icing over, driver issues etc - although some of these were in early models and may now have been resolved(?)
What I have noticed is that a lot of posts are from people who have gone straight from a DSLR to the ASI1600MM.
I would really like to hear from anyone who has in depth experience of using both CCD Cameras and the ASI1600MM.
What are the benefits and weaknesses of both?
If an SX814 (or similar CCD) and an ASI1600MM-cooled were the same price, same sensor size, and you could only have one of them, which would you choose - why?
(Bearing in mind that I am using SkyWatcher Esprit 80/400 APO Pro - both of the above give Sample Rate around 1.9"/Px)
Mid
#2 leemr
leemr
Posted 20 June 2017 - 04:05 AM
I used to own the SX-674 before switching to the ASI-1600MM-C.
First big difference is that the CCD favours traditional long exposures, partly because of the added read noise, partly because of the download time which is 7s in the case of the SX-814, I believe). Some people like this, some people don't. Shorter exposures will accumulate less blurring due to poor guiding / tracking / seeing issues. Shorter exposures themselves have a lot of overhead depending on the software you use though, so you may lose a significant chunk of final SNR if you use very short exposures with high overhead (e.g. on my computer I recently captured 6hrs worth of 35s subs, but incurred about 17s overhead in between each sub!).
I *never* had an issue with frost on my sensor, nor dew on the glass of my SX-674. I've had both on my ASI-1600. It'll be more of an issue in more humid environments (and it's *very* humid in QLD, Australia, where I am). Definite plus for the Argon-purged CCDs here in terms of sensor frost in humid environments.
ASI-1600 has amp glow, which can be calibrated out but adds noise to the image. The CCD shouldn't, and in general will have much "cleaner" images with less FPN. My 674 did show up a lot of cosmic ray strikes though, while the ASI-1600 did not.
You shouldn't need darks with the SX, and the ASI may have some issues with FPN creep reducing the effectiveness of calibration frames. In my experience with the 674 you'll probably still want to dither due to the odd hot pixel.
ASI has variable gain which allows you to trade off full-well capacity for read noise, which can help in getting "sky limited" images in dark skies, particularly for narrowband.
FOV is quite different on the two sensors, whether that's a factor depends on the targets you're imaging.
QE is a fair bit higher on the 814 as well, which will offset the higher read noise. Last I knew the ASI absolute QE wasn't known but was estimated at about 55%, while the 814 peaks at 75%.
SX-814 is definitely a higher quality product, with cleaner images, but not very flexible and favours a system with good tracking / guiding / seeing. The ASI can still produce good quality images, but favours more, shorter exposures (and thus may result in sharper results on lower-end mounts) and produces single subs that aren't as clean out of the box.
Honestly it's a pretty tough call. I shifted from the 674 because I wanted a bigger FOV and higher resolution (in terms of "/px)... if I'd had an 814 I might have kept it instead of going for the ASI... having said that, I am happy with the ASI, and have produced some very nice images with it and would not be inclined to sell it and replace it with an 814 simply due to the cost factor.
Some images I've produced with the ASI in combination with the Esprit 120:
  • mikefulb, Ken Sturrock, Jon Rista and 4 others like this
#3 midnightlightning
midnightlightning
Posted 20 June 2017 - 03:55 PM
Thanks for that excellent and balanced analysis, I still don't know which to buy but that information is very helpful.
Your images are stunning by the way, excellent data and processing smile.gif
There seem to be three clear benefits with the 1600 for me, shorter exposures (for the easier guiding requirements but mainly because of the UK weather - I didn't get a single session in between Jan and May!! - partly because of work). The large sensor, although this would be more of a benefit if I ever get the scope you have, I highly rate my Esprit 80 but would love a 120, and finally the price.
I'm not sure these are enough to persuade me and I'm probably leaning towards the CCD but if I do get a CCD now I suspect my next camera will be a CMOS as they are already good and going to get better and better (and hopefully even cheaper) over the next few years.
Thanks Again Lee.
Mid
  • leemr likes this
