Display flip in Sky Safari
13 replies to this topic
#1 abaum
abaum
  • Loc: Mesa, AZ
Posted 19 June 2017 - 06:33 PM
Is there a way to have Sky Safari display on the screen what I see through the eyepiece?  I use an SCT w/ diagonal and when I look at Jupiter, the moon through the eyepiece don't match the locations in Sky Safari.
Adam
#2 abaum
abaum
  • Loc: Mesa, AZ
Posted 19 June 2017 - 06:38 PM
Found it.  Why the setting is under "Coordinates" and not "Display" baffles the mind....
Edited by abaum, 19 June 2017 - 06:39 PM.
#3 J A VOLK
J A VOLK
  • Loc: So. Cal.
yes - go to "Coordinates (Coords)" then you have option to flip horizontally, vertically or both
  • Steve Cox likes this
#4 JHollJr
JHollJr
  • Loc: Northern Virginia
Posted 19 June 2017 - 07:45 PM
It may sound old fashioned to suggest practicing without the flip. It helps if you ever find yourself using atlases. Spent some time with a 102mm last evening around the Graffias and just looked at everything "backwards". smile.gif
  • Jon Isaacs likes this
#5 btschumy
btschumy
    Vendor - Simulation Curriculum
  • Loc: Longmont, CO, USA
Posted 19 June 2017 - 09:27 PM
You can also tap the blue field of view label in the upper right to bring up a pop up panel to quickly access that setting (and others).  There is another pop up panel attached to the label in the upper left of the chart.
  • Cyrano, Jon Isaacs, JHollJr and 3 others like this
#6 btschumy
btschumy
Posted 19 June 2017 - 09:28 PM
Because you are flipping the coordinate system when doing that.
#7 nicknacknock
nicknacknock
    Heghlu'meH QaQ jajvam!
  • Loc: Nicosia, Cyprus
Posted 20 June 2017 - 02:43 AM
This! I use a RACI and a Dob or Frac. This makes life oh-so-easy!
  • JHollJr likes this
#8 Roger Corbett
Roger Corbett
Posted 20 June 2017 - 06:26 AM
Veteran Sky Safari user here...  agree with abaum.  From a user's perspective, one thinks about flipping the field of view or the display -- not the coordinates!  (Plus, under Display, Appearance, is where one turns on Coordinates and Field of View, adjusts Screen Rotation, etc.).
Coordinates, one thinks of as the place to choose among the Coordinate Systems --horizon, equatorial, ecliptic !
In any event, never used that inside option anyway, given the ease of use and brilliant FOV indicator you get by tapping on in the upper-right corner!   (Hmm... that is also the Field of View selector, not the CGF-- Coordinate Grid Flipper!  )
#9 bleep
bleep
Posted 20 June 2017 - 04:18 PM
I used to swipe down on the top right then hit the both on the display but I found it much easier to just turn my iPad upside down!
  • JHollJr and Roger Corbett like this
#10 abaum
abaum
  • Loc: Mesa, AZ
Posted 22 June 2017 - 05:08 PM
Not sure what you mean by flipping the coordinate system.
#11 Jon Isaacs
Posted 22 June 2017 - 05:31 PM
Alt-Az is a coordinate system,  there's the horizontal component and the vertical component.  To flip the image, you are flipping the coordinate system.   The display includes more than just the chart view..
In any event,  the short cut cut makes it easy.  I just do it all in my mind..  Too many views to work with to be flipping the orientation.  There's the Telrad,  then there's the RACI finder whose eyepiece is at an angle so up is not up, and then there's the scope's eyepiece.
  • JHollJr and NMBob like this
#12 ascii
ascii
  • Loc: Orlando, FL, USA
Posted 22 June 2017 - 05:32 PM
Imagine viewing the sky in Sky Safari where the person is in the northern hemisphere and looking toward the southern horizon.  If you flip vertically, declination will no longer increase as you move from the bottom of the scene to the top.  It will decrease.  Likewise, if you flip horizontally, R.A. will no longer increase going right to left.  It will decrease instead.  It makes sense in that regard, but frankly, I wouldn't have thought to look under Coordinates myself.
#13 NMBob
NMBob
  • Loc: New Mexico
Posted 23 June 2017 - 12:21 PM
Now if I could just keep straight which drive button to push when on the hand paddle while looking through each of those. :)
#14 Jon Isaacs
Posted 23 June 2017 - 12:25 PM
Now if I could just keep straight which drive button to push when on the hand paddle while looking through each of those. smile.gif
 That's one reason I prefer tracking by hand.. I just need to know which way I want to go..
jon
  • NMBob likes this
