I have confirmed that the log formats have changed through different TheSkyX versions, so I made changes to the software to account for different autoguider log formats. However, some header parameters may not be displayed correctly at this time and a message will let you know which parameters could not be read. I would have to modify the user interface at run time based on the TheSkyX version that was used to generate the autoguider log file, and i don't know how to do this at this time.
In addition, the software will not read newer guiding parameters such as PEC and Guide Star data. I will try to add this capability shortly.
Version 1.2 of the software is available here;
https://www.bisque.c...alyzer.zip.aspx
Tom,
I confirmed I could read the log file you sent me with version 1.2, so it should work.
