$ .98 solar finder available at Home Depot, Lowes, ...
13 replies to this topic
#1 Bob LaFleur
Bob LaFleur
Posted 17 July 2017 - 08:26 AM
An aluminum downspout hanger makes a pretty good solar alignment tool.  Can't beat the price and they are available at any decent hardware store.  Not even really a DYI project - the holes are already drilled.
Bob
Edited by Bob LaFleur, 17 July 2017 - 08:42 AM.
  • DoctorNoodle, CCD-Freak, John O'Grady and 7 others like this
#2 burb scope
burb scope
  • Loc: Holland, MI
Posted 17 July 2017 - 08:35 AM
Please elaborate.  Sketch?  Picture?
#3 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 17 July 2017 - 08:45 AM
Excellent !
#4 Bob LaFleur
Bob LaFleur
Posted 17 July 2017 - 08:46 AM
Picture added - just align the light from the hole on one side onto the hole on the other side until it looks like a mini total eclipse.
  • Steve Cox likes this
#5 oakman72
oakman72
  • Loc: Columbia, SC
Posted 17 July 2017 - 09:43 AM
#6 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 17 July 2017 - 10:00 AM
Yesterday at Lowes they had solar glasses for sale at the register for the eclipse.
#7 gfeulner
gfeulner
  • Loc: Bergen county, New Jersey
Posted 01 August 2017 - 03:19 PM
Bob
That's sheer genius! I went to Home Depot today and picked up two of them. Mounted it on my scope with velcro. Works like a charm! Thanks for the great idea!
 Gerry
#8 CCD-Freak
CCD-Freak
  • Loc: Whitesboro,Texas
Posted 09 August 2017 - 07:47 PM
I got a couple of those too and I drilled out the holes on the bottom and mounted it to the top screws on my OTA mounting ring.  I de-burred the sighting holes to clean up the image.  Easy to adjust and very firmly mounted.  Thanks for posting the idea.  This is classic "thinking outside the box" there Bob.
 "I LIKE IT !!!!!"
John
CCD-Freak
WD5IKX
Edited by CCD-Freak, 09 August 2017 - 08:14 PM.
#9 CCD-Freak
CCD-Freak
Posted 09 August 2017 - 08:04 PM
Up close.....
John
CCD-Freak
WD5IKX
  • gfeulner likes this
#10 JoseMenudo
JoseMenudo
Posted 10 August 2017 - 11:25 AM
when u get long time use in solar, you can use the mounting ring shadow as your solar finder.
$0.98 is hard to beat!
#11 REC
REC
  • Loc: NC
Posted 14 August 2017 - 08:27 AM
I guess I'm a little thick, don't get it? How does it work?
#12 cytan299
cytan299
Posted 14 August 2017 - 07:58 PM
My steps:
  1. Not looking at the Sun, align the body of the hanger by looking through the two holes.
  2. Use the goto to get approximately where the Sun is.
  3. Look at the shadow that is cast on the "back" side of the hanger. You should see a bright spot from the hole in front and the shadow that is cast by the front.
  4. Move the telescope so that the bright spot to gets to the backside hole.
  5. If you see the Sun in your eyepiece, there there!
  6. If not, you will have to scan the bright spot around the hole.
  7. Once you find where the bright spot is and where the Sun can be seen in the eyepiece, now move the hanger so that the bright spot and the backside hole are at the same location. Done!
cytan
Edited by cytan299, 14 August 2017 - 07:59 PM.
  • barbie likes this
#13 CCD-Freak
CCD-Freak
Posted 25 August 2017 - 08:42 PM
The .98 solar finder worked perfectly for the eclipse.  The sun was in the telescope the first time and it required very little adjustment.  The sun showing on the shade was a plus.   Thanks for the idea.  (^8
BTW...We had almost perfect weather in Huntington, Oregon.  What a show !!!!!!
John Love
CCD-Freak
WD5IKX
Edited by CCD-Freak, 25 August 2017 - 10:19 PM.
  • NMBob likes this
#14 lphilpot
lphilpot
  • Loc: Central Lousiana, USA
Posted 26 August 2017 - 04:19 PM
Mine worked great, too. No more solar observing than I do normally, it's more than good enough. I put a plastic disc 'target' cut from Sintra board on the back, little rubber feet under it and used a Velcro strap to anchor it around the dew shield of my 80mm refractor.
  • CCD-Freak likes this
