M27 The Dumbbell Nebula in 90 seconds
7 replies to this topic
#1 cometcatcher
cometcatcher
  • Loc: Mackay Australia
Posted 17 July 2017 - 08:45 AM
M27 The Dumbbell Nebula, single 90 sec sub, taken between clouds. GSO 10" F4 Newtonian, Full spectrum Canon 1100D, Baader UV/IR cut filter, HEQ5 Pro unguided. Processed in Photoshop. Bigger but not really better at Astrobin ---> http://astrob.in/303653/0/
"The Dumbbell Nebula (also known as Apple Core Nebula, Messier 27, M 27, or NGC 6853) is a planetary nebula in the constellation Vulpecula, at a distance of about 1,360 light-years.
This object was the first planetary nebula to be discovered; by Charles Messier in 1764. At its brightness of visual magnitude 7.5 and its diameter of about 8 arcminutes, it is easily visible in binoculars, and a popular observing target in amateur telescopes.
The Dumbbell Nebula appears to be shaped like an prolate spheroid and is viewed from our perspective along the plane of its equator. In 1992, Moreno-Corral et al. computed that its rate of expansion in the plane of the sky was no more than 2.3" per century. From this, an upper limit to the age of 14,600 yr may be determined. In 1970, Bohuski, Smith, and Weedman found an expansion velocity of 31 km/s. Given its semi-minor axis radius of 1.01 ly, this implies that the kinematic age of the nebula is some 9,800 years."
  • jgraham, torn8o, Ron359 and 15 others like this
#2 Allanbarth1
Allanbarth1
  • Loc: Central New Jersey
Posted 17 July 2017 - 10:48 AM
Great photo, the color is amazing.
#3 cometcatcher
cometcatcher
Posted 17 July 2017 - 09:05 PM
Thanks Allan!
#4 nickcodybarrett
nickcodybarrett
  • Loc: Pattison, Ms (a.k.a dark sky heaven)
Posted 18 July 2017 - 10:28 PM
Simplicity at it's finest.
#5 cometcatcher
cometcatcher
Posted 19 July 2017 - 07:39 AM
If only it worked with everything...
  • nickcodybarrett likes this
#6 jgraham
jgraham
Posted 19 July 2017 - 07:51 AM
Fantastic! Nicely done. This is a good example of why cameras make such good eyepieces. :)
#7 Ron359
Ron359
  • Loc: -105 +39
Posted 19 July 2017 - 09:54 AM
Fantastic! Nicely done. This is a good example of why cameras make such good eyepieces. smile.gif
+1 on John's comment.  You should post your image in the EAA forum.  It will drive them nuts! wink.gif
#8 cometcatcher
cometcatcher
Posted 19 July 2017 - 11:08 AM
I was actually thinking to myself this short time integration isn't far from EAA, (which I used to do 20 years ago).
