A question about Carl Zeiss JENA Deltrintem 8X30
equipment binoculars
10 replies to this topic
#1 Redgrave
Redgrave
Posted 17 July 2017 - 09:31 AM
Hello guys,
I have a Carl Zeiss JENA Deltrintem 8X30 binoculars. It's serial number is 1169204. According to this form http://www.europa.co...pe/zeissbin.txt it should be made between 1921~1922. But it also has a mark "Germany"on it. As I know only post war made had "Germany" mark. Is it genuine or a copy?
Can anyone tell me anything about it? Any information would be appreciated.
Edited by Redgrave, 18 July 2017 - 07:00 AM.
#2 jtsenghas
jtsenghas
  • Loc: The flatlands of Northwest Ohio --Bloomdale
Posted 17 July 2017 - 11:55 AM
The only info I can help you with on this one is instructions on posting photos:
Your image must be less than 500 kB. In fact the total of all attachments must be less than 500kB, so you may have to reduce a high resolution photo even if you simply open it in Microsoft's Paint and resize it to 10-30% and resave it. (That program will show the file size after you resize it ONLY after you resave it).
Choose the "More Reply options" button on the bottom of the post you are composing, click the "Browse..." button under attach files, select your file, and choose "Attach this file". It will then appear with your post.
If you want it to appear in a specific place within the text of your post, insert your cursor there, and click the "Add to post" button to the right of the file thumbnail.
You can always see how the post will apper by by clicking "Preview Post" at the bottom of your screen before actually posting to verify.
#3 Mad Matt
Mad Matt
  • Loc: Frankfurt, Germany
Posted 17 July 2017 - 01:25 PM
Is the focusing knob plastic or metal? Here is a little info on the official Japanese Zeiss 8x30 had 6https://www.flickr.c.../in/photostream
#4 Foss
Foss
Posted 17 July 2017 - 04:37 PM
For reference, here's a pair (circa 1922) I once owned with "Germany" stamped on the IPD scale. Yours look genuine to me.
Edited by Foss, 18 July 2017 - 08:17 AM.
#5 Redgrave
Redgrave
Posted 18 July 2017 - 07:03 AM
Ok, photos upload
Focusing knob? I'm not sure, I need to check it. What's different between plastic and metal?
#6 FrankL
FrankL
  • Loc: Winnipeg, Manitoba Canada
Posted 19 July 2017 - 08:28 AM
It's genuine.
Some 1920's - 1930's Zeiss are marked "Germany" and some are not. My Delactis made in 1926 is marked Germany while my Deltrintem made in 1936 is not.
The focus knob on my Deltrintem and most if not all others from this period is plastic (or possibly Bakelite) with an inset metal disc with focus settings which is retained by 3 screws along the edge of the focus knob.
The Deltrintem/Deltrentis eyelenses underwent several modifications. The first ones had a 5 element Erfle type eyelens; during the later 1920's a 6 element Erfle type was used; in 1932 a non-Erfle 4 element aspheric lens was introduced; and circa 1946 they reverted to a 5 element Erfle type.
Edited by FrankL, 19 July 2017 - 08:33 AM.
#7 Redgrave
Redgrave
Posted 25 July 2017 - 10:27 AM
Hi,guys
I've checked .The outside ring of focusing knob is looks like plastic, but inside marked with numbers it seems to be metal.
So, is it made by Japan?
Edited by Redgrave, 25 July 2017 - 10:27 AM.
#8 trener
trener
  • Loc: European Union
Posted 25 July 2017 - 02:05 PM
Do they have any AR coatings?
#9 lylver
lylver
  • Loc: near Geneva but in France
Posted 26 November 2017 - 04:15 PM
It's genuine.
I think the Erfle were later than that (they are WWII eyepiece)
The first 3 lens EP was a Konig 2+1 55° then a 3+1 60-70° (1920-1947), it was enhanced later with an Erfle (post WWII)
Source : https://www.allbinos...intem_8x30.html
A strange, uncommon erfle design. (field convex)
AR coating began around 1939 for those binocular (T single layer) : increasing from 50-60% transmission to 70-80%
Starting in 1978, T3M coating increases to 90-92%, with a centered color range @550nm : it brings some yellow touch to the image
Just bought one from 1989, as a small light survey bino. (operating range 80-200m), field 12m-30m wide
Edited by lylver, 26 November 2017 - 04:17 PM.
  • Mad Matt likes this
#10 FrankL
FrankL
Posted 27 November 2017 - 12:19 PM
"The Deltrintem/Deltrentis eyelenses underwent several modifications. The first ones had a 5 element Erfle type eyelens; during the later 1920's a 6 element Erfle type was used; in 1932 a non-Erfle 4 element aspheric lens was introduced; and circa 1946 they reverted to a 5 element Erfle type."
This information is from the book, "Zeiss Handferngläser 1919-1946. Modelle - Merkmale - Mythos" , Dr. Hans T. Seeger, Hamburg 2015, pages 150-151.
I am confident Dr. Seeger is correct.
See: https://www.cloudyni...lars-1919-1946/
Edited by FrankL, 27 November 2017 - 12:20 PM.
#11 lylver
lylver
Posted 27 November 2017 - 04:23 PM
It is a great information, I always believed the Deltrintem were only civilian binoculars.
But what you report, the fact Erfle worked early on this device is a mystery.
He was at the head of the telescope department in 1918 and worked for submarines optics.
Another fact to consider : Germany was very poor after 1918 till 1930, pressed they were due to the Versailles treaty. They were costly products for common people.
Perhaps at start, the fact that Erfle equiped them with his lenses probably means they were used as military devices on submarines U35 during ww1 as an officer light spotting/survey bino.
The 5 lens is the classic wide field EP, not center sharp. The 6 lens may be sharp in center. (not a Kaspereit I believe)
Then why such a model could'nt go to the public market after war as a surplus ?
It is interesting to search in this book about an initial a waterproof military version, could be a nice historic discovery.
Also tagged with one or more of these keywords: equipment, binoculars
