New Skywatcher AZ GTi goto wifi mount
3857 replies to this topic
#3826 Ronn
Ronn
Posted 12 August 2024 - 09:49 AM
Hello, my apologies if this has already been answered. Tried searching the topic but could not find an answer
1. The AZ-GTi mount comes with a pier and steel tripod. Is it possible to remove the central pier and add it to a different tripod (RT90C) without any adapters?
2. Does AZ-GTe allow the mount to be moved manually as well? The only downside being the scope needs to be aligned again to use GoTo. Is this correct?
Thanks for your time.
You can move the mount manually and maintain alignment if you enable the auxiliary encoders. From the manual:
The AZGTi mount is equipped with auxiliary encoders on both the azimuth axis and altitude
axis. Therefore, the mount can keep track of its current position even when a user unlocks the
clutches and rotates the mount in azimuth axis and altitude axis manually.
With this feature, a user can manually operate the mount anytime without worrying about los-
ing the mount’s alignment status. When the user wants to operate the mount with the SynScan
hand control again, no alignment is required and all that is needed to be done is to re-lock the
clutches.
This feature can be disabled with the SynScan hand controller or the SynScan App. If an
user does not need to rotate the mount manually after alignment, it is recommended to dis-
able this feature to obtain the best pointing accuracy.
  • astrogta likes this
#3827 RobertJ
RobertJ
  • Loc: Israel
Posted 12 August 2024 - 09:55 AM
axis.
That's only with the AZGTi - @astrogta was asking about the AZGTe - which does not have the auxiliary encoders.
-- Robert
  • Ronn and astrogta like this
#3828 Ronn
Ronn
Posted 12 August 2024 - 10:05 AM
-- Robert
Sorry! I missed that.
#3829 astrogta
astrogta
Posted 12 August 2024 - 03:05 PM
Thanks for the response. The skywatcher website states the tripod minimum length is 31 inches. Does the 31" include the central pier length as well? Just trying to see if I can carry it in my hard case bag (~27 inches) for air travel
Thanks again for the help
#3830 archer1960
archer1960
  • Loc: Southern New England
Posted 12 August 2024 - 04:57 PM
The pier is removable so it shouldn't matter. However, I just measured mine, and it's 27" on the nose from the tip of the foot to the top of the flat platform at the top of the tripod, not including the pier extension, However, this does NOT included the attachment bolt, which extends almost another half inch above the platform. So if your carry on is 27" inside length, you're going to need to put the tripod in slightly diagonally, which wastes quite a bit of space. You can put the extension pretty much anywhere in your luggage...
#3831 astrogta
astrogta
Posted 12 August 2024 - 06:57 PM
Thank you very much for taking time to check the length.
  • archer1960 likes this
#3832 archer1960
archer1960
Posted 12 August 2024 - 07:00 PM
You're welcome; I just hope they haven't changed the tripod from what mine came with...
#3833 jeffry7
jeffry7
Posted 12 August 2024 - 08:27 PM
You can mount the azgti head on a photography tripod.
I have a geared head I mount mine to. I use the head to align for equatorial mode instead of using a wedge.
  • archer1960 and astrogta like this
#3834 TareqPhoto
TareqPhoto
  • Loc: Ajman - UAE
Posted 15 August 2024 - 01:07 AM
Is this a good tripod for the mount?
https://www.aliexpre...7703883562418_6
I saw another one that is more cost, so i wanted to check out this first.
#3835 GTom
GTom
  • Loc: Scottish Highlands, UK
Posted 09 September 2024 - 07:04 PM
I am considering photography mount options for my 2.8/300 nikon telephoto + 1.7 teleconverter setup (got various cameras, all weighing around 700g. Any chance an eq mounted AZ GTi could carry this kit (probably right on the payload limit) safe and sound for ~3 minutes subs?
I won't use the stock tripod and wedge, got a 40mm carbon tripod and a fornax FMW-200 wedge.
Edited by GTom, 09 September 2024 - 07:05 PM.
#3836 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 10 September 2024 - 12:42 AM
For that kind of focal length and 3 minute subs - have you calculated also the needed guider setup?
#3837 GTom
GTom
Posted 10 September 2024 - 05:15 AM
That would be an approx 500mm FL, total useful payload 5kg/11lbs.
Edited by GTom, 10 September 2024 - 05:15 AM.
#3838 GTom
GTom
Posted 10 September 2024 - 06:41 AM
One more: does the mount have to be well balanced in EQ mode, or does it have a relatively strong motor, like a "poor man's harmonic drive"?
As above, my useful payload would be around 11-12lbs (5-5.5kg), centered approx 3" above the saddle. May I get away e.g with the basic 1kg counterbalance kit, knowing that it will be around 3-4kg out of balance?
#3839 Tapio
Tapio
Posted 10 September 2024 - 07:06 AM
It's normal equatorial mount which requires good balancing, especially if you are at the upper limit of load capacity.
  • GTom likes this
#3840 GTom
GTom
Posted 10 September 2024 - 10:01 AM
Thank you! No advantage then compared to e.g an SA GTi.
#3841 Wolfwatcher
Wolfwatcher
  • Loc: Denver Colorado
Posted 29 September 2024 - 12:07 PM
Just a comment or two using the AZ GTi for visual and in alt/az mode only. Having the dual encoders instead of the single one with the GTE is a great improvement IMO (I've owned both). Getting clumsy in my old age, so if I happen to kick the tripod leg in the dark or something, I can easily readjust the mount head and it keeps on keeping on with tracking as if nothing happened. Great!
Also, I've discovered that for simple tracking of moon, planets or solar, it works best to manually slew the scope to the target first, then tap "point and track" on the app screen, rather than trying to use the go-to feature and/or keys on app screen to find and center the target first. For my backyard viewing, with considerable light pollution, if I can't see the target visually through a finder scope, I don't bother trying to find it using the go-to feature. (I don't have the hand control.)
Finally, I really like using a tablet rather than my phone with SynScan Pro. Larger screen and I can simply whip out the phone to look up something separately if I need, instead of scrolling all through the features on the iPad trying to find what I want while it's busy tracking the object. More than once I've managed somehow to lose tracking when doing the latter, and have to readjust.
For me, with the mount level and the target centered, I can keep it visually in the scope's eyepiece for more than an hour, even using moderate high power. And when mounted on a heavier tripod (in my case a SW AZ5), I find I can use my C6" SCT set up with a 2" diagonal and RACI finder just fine with no balance issues or need for a counterweight.
Jett
  • GTom likes this
#3842 GTom
GTom
Posted 07 October 2024 - 09:05 PM
One more question: is dithering working all right in both axes with Nina/Ekos?
#3843 avescio
avescio
  • Loc: Bonney Lake, WA
Posted 18 October 2024 - 11:57 AM
Hi, I just bought an AZ-GTi mount to use with my Asi Air Plus in Alt/Az mode for EAA. Does anyone have this setup?
#3844 Joey44
Joey44
Posted 19 October 2024 - 08:26 AM
Asiair does not support this mount in alt/az.
Edited by Joey44, 19 October 2024 - 08:26 AM.
#3845 Hikescdnrckys
Hikescdnrckys
  • Loc: Mississauga and Northern Bruce Peninsula
Posted 19 October 2024 - 08:45 AM
On the contrary, I have used the ASIAIR with the AZ-GTi mount in Alt-az mode many times, no problems whatsoever.
#3846 Soundboy121
Soundboy121
  • Loc: Rockland County
Posted 19 October 2024 - 04:04 PM
can you please describe your work flow to do this?
#3847 Astrodave
Astrodave
  • Loc: Centreville, Va. USA
Posted 19 October 2024 - 08:21 PM
How so? I tried every setting and either gotos are totally wrong because it thinks the mount is in EQ mode or it won’t track. Period.
Edited by Astrodave, 19 October 2024 - 08:22 PM.
#3848 Hikescdnrckys
Hikescdnrckys
Posted 20 October 2024 - 08:45 AM
It's been a long time, I have since converted to EQ Mode. I will check through my notes, it's possible I was confusing it with my Evo. Sorry.
#3849 avescio
avescio
Posted 24 October 2024 - 09:41 PM
Hi Everyone, it looks like I will be converting to EQ mode for my AZ-GTi mount but I have a counterweight bar question.  I read that the AZ-GTi needs a counter weight bar with a 12M Male Thread.  I have a Celestron Astromaster 130eq counter weight bar that is to smaller and I'm unable to find the correct thread info for this bar.  Does anyone know what the male thread size is?  Is it a standard 8M?  Would this M8 to M12 adapter work?
Fitting Reducer Metric M12 X 1.75 M12X1.75 Male to M8 X 1.25 M8X1.25 Female Thread Adapter Gauge Meter Bushing
Edited by avescio, 24 October 2024 - 09:45 PM.
#3850 Astrodave
Astrodave
Posted 25 October 2024 - 08:10 AM
Assuming that bar is 8mm, which it probably is then yes it will work. That is the exact same adapter I bought for my counterweight bar but I am not familiar with the specs of your bar.
