Focuser for a SkyQuest XT10
10 replies to this topic
#1 GeorgiaSky
GeorgiaSky
  • Loc: Georgia
Posted 13 August 2017 - 10:05 AM
I'm looking to upgrade the focuser on my Orion SkyQuest XT10 DOB. It current has a Orion 2" Crayford-Style Telescope Single Speed Focuser and I want to change it to a dual speed. The issues is all the focusers, that I have searched for the base won't fit the hole pattern and cover the hole for the focuser tube of my OTA. Do anyone know of a way to upgrade it or modify the current focuser on it. I have attached a link to the current focuser on my OTA. Thanks in advance for you help.
http://www.telescope.../51/p/13039.uts
#2 gene 4181
gene 4181
  • Loc: n.e. ohio
Posted 13 August 2017 - 10:36 AM
    Whats  "wrong " with it ?    If its not working correctly, smoothly   , then take the  back part off  with the 4 small phillips screws   and remove the focuser  tube and  re-file the flat with a  small flat mill file . When they're milled from the factory  they're not quite flat .   Don't go hog wild on it   , then wipe it off and reassemble, little white lithium grease at the plastic piece that  "pushes " against the  focuser axle and re-assemble  .  WHATEVER  you do though , make sure the tube is horizontal  , don't want anything falling into the tube  and hitting the primary or secondary mirror.   My last xt 8 needed  this done  , worked  a lot better  after this  .
#3 Allanbarth1
Allanbarth1
  • Loc: Central New Jersey
Posted 13 August 2017 - 10:42 AM
It looks to me that the Orion 2 speed low profile crayford should be a simple swap.
http://www.orion-xt1...-focuser-1.html
Here is a link to the mod plus a bunch of other mod's on the XT10
  • gene 4181 and GeorgiaSky like this
#4 Cames
Cames
Posted 13 August 2017 - 11:00 AM
ScopeStuff® sells focuser upgrade parts for XT dobs.   ScopeStuff catalog
Read through all the info carefully.  You can call for help with specific questions you  may have.
The company has a good reputation on CN.
C
  • Jon Isaacs, tomykay12, kfiscus and 2 others like this
#5 GeorgiaSky
GeorgiaSky
  • Loc: Georgia
Posted 13 August 2017 - 11:40 AM
There's nothing wrong with it, I just want to be able to fine tune the focuser.
#6 tomykay12
tomykay12
  • Loc: San Diego
Posted 13 August 2017 - 11:45 AM
A two speed focuser is a slippery slope; once you have one you don't want to go back, and you will desire one on every scope you touch...
  • GeorgiaSky likes this
#7 havasman
havasman
  • Loc: Dallas, Texas
Posted 13 August 2017 - 11:48 AM
I put a Scopestuff focuser on my XT10i because the focus shift of the Orion was unacceptable to me. Problem cured. The oversized knob for the fine focus knob is also recommended.
#8 GeorgiaSky
GeorgiaSky
  • Loc: Georgia
Posted 13 August 2017 - 11:50 AM
That's why I want to upgrade it. I have one on my Sky Watcher ED80 Pro and wouldn't have it any other way.
#9 gene 4181
gene 4181
  • Loc: n.e. ohio
Posted 13 August 2017 - 12:20 PM
smile.gif   , That's Ok  , I was just asking .    A 2  speed   is nice to have at 5 ,  smile.gif .
  • Jon Isaacs and GeorgiaSky like this
#10 GeorgiaSky
GeorgiaSky
  • Loc: Georgia
Posted 13 August 2017 - 12:48 PM
I do like the idea behind this link.
#11 gwlee
gwlee
  • Loc: 38N 120W
Posted 13 August 2017 - 10:59 PM
I believe that Moonlite has the hole-pattern adapters to make their focusers a drop-in replacement for the stock focuser.
