Need help with Stellarium telescope control setup
accessories Celestron astrophotography
8 replies to this topic
#1 hovlandbound
hovlandbound
  • Loc: Oakdale Mn
Posted 13 August 2017 - 10:25 AM
HI everyone!  I am looking for some advice on setting up the program Stellarium telescope control with my Celestron 8SE.  Under configuration, plugins, telescope control the configure tab is greyed out.  I just got done downloading the latest version of Stellarium 0.16.0 and it is still greyed out.  I’m trying to send “slew” commands to my scope but I have run into a roadblock.  Anyone out there that has some thought on this that would be great.  Thanks everyone!!!
Pete
#2 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 13 August 2017 - 10:29 AM
You need to install Stellarium Scope in order to control the ASCOM telescope from Stellarium. It's also free. :)
http://welshdragonco...stellariumscope
#3 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 13 August 2017 - 10:44 AM
You don't need a third party tool. Instructions are here: http://www.stellariu...Control_plug-in
You need to set the telescope control plug in to "Load at Startup", quit Stellarium and start it again. The control will then be available.
#4 rmollise
Posted 13 August 2017 - 11:01 AM
You need to install Stellarium Scope in order to control the ASCOM telescope from Stellarium. It's also free. smile.gif
That's incorrect. The program contains onboard drivers for Celestron.
OP:  you need to go in and configure the telescope plugin. You will likely have to check "load at startup," save settings, and exit and restart the program to do that.
This may be of assistance:  http://uncle-rods.bl...stellarium.html
  • hovlandbound likes this
#5 rockstarbill
rockstarbill
Posted 13 August 2017 - 11:16 AM
Nice, is this a recent change in Stellarium? I dont use that program often, but back when I did you had to use the add on program.
#6 hovlandbound
hovlandbound
  • Loc: Oakdale Mn
Posted 13 August 2017 - 12:01 PM
Thanks everyone!!!  Let me check things out and see if I can get it working.
#7 hovlandbound
hovlandbound
  • Loc: Oakdale Mn
Posted 13 August 2017 - 12:10 PM
Thanks!!  That worked.  :)
#8 hovlandbound
hovlandbound
  • Loc: Oakdale Mn
Posted 13 August 2017 - 01:40 PM
Hi.  One more question I have for you.  It shows connected on com3 but telescope won’t slew by ctrl1.  Or alt 1 which I believe should go to whatever is in the middle of the screen.  I have the device model Celestron compatible selected and it shows it’s connected.  Any Ideas on that.  Thanks again!  Pete
#9 hovlandbound
hovlandbound
  • Loc: Oakdale Mn
Posted 13 August 2017 - 01:41 PM
Also tagged with one or more of these keywords: accessories, Celestron, astrophotography
