Pentax Telescopes & Mounts
#51
Posted 31 August 2017 - 07:19 PM
#52
Posted 31 August 2017 - 08:53 PM
My initial impressions:
Upon inspection I soon realized this was a a high quality telescope just from the packaging. Build quality of the Pentax 75 EDHF exceeded my expectations. The tube is much heavier than I thought. The tube is very solid and is of high quality.
The beautifully painted and hammered green finish is really attractive and appealing to me. The precision of the machining and fit of all the components is obviously much better than most of the Chinese made telescopes out there.
The front objective lens is pristine and the 7 layer multi-coating has struck me as high transmission with very little reflectivity using a bright white LED light. The rear field flattener is of equally nice quality.
The Pentax MS-2 Equatorial mount is beautifully crafted and exudes quality. The spring loaded altitude adjustment was a unique feature and I was surprised to see it flip to the maximum altitude when releasing the altitude clamp. The tripod legs installed easily and each leg was solid. There was no slop in the construction of the tripod legs. The stability of the mount was further improved with the addition of the metal tripod spreader.
The equatorial CW shaft is chrome plated steel and is machined beautifully. The whole thing assembled in a couple of minutes and then I proceeded to mount the OTA. With the OTA mounted I installed the RA shaft knob and checked the slow motion knobs. It was a little stiffer than expected but I realized there was also NO slop in the mount. Just accurate movements. The RA/DEC axis felt the same and slow motion movements were precise and had a great feedback feel to them. The azimuth adjustment was equally as smooth.
The focuser is very smooth for a rack and pinion and I feel that locking clamp works very well. The 2.5" focuser is quite large on the telescope and it reminds me a lot of Takahashi R&P focusers. The variety of adapters is unique and I feel that I am going to have an interesting time getting my DSLR to adapt to the scope.
Outside Observations:
I took the assembled scope outside from my basement to the driveway and was surprised how portable the scope is. It is neither light nor heavy, but it definitely is compact. The solid feel of the mount made me confident I could transport it safely outside in one go, without disassembly.
I polar aligned the mount to Polaris. It is a bit tricky to view the polar scope because of the awkward position being low to the ground. The optics in the little polar scope is very clear and focused nicely on Polaris. With the scope/CW attached, the spring loaded altitude adjustment was well balanced with the mount and adjustment was quite easy. Azimuth adjustment was even easier for accurate polar alignment.
The 6x30 finder is a thing of beauty. The optical and build quality is very impressive and maybe equally good as some Takahashi finder scopes I have used.
I pointed the scope towards Saturn and was greeted with a nice large round disc. After focusing, a small oval appeared with the Pentax Kellner 20mm eyepiece. With the 6mm Pentax Orthoscopic inserted, Saturn revealed its rings and showed quite a bit of detail. I was looking for any Chromatic abberation and couldnt not detect any. I was very suprised how much detail I could pull out with such a small scope.
Next was the moon. With the 6mm still in the moon was very bright and impressive. I detected a small amount of green/yellow CA on the limbs of the moon, but nothing to complain about. Next was Vega. The 75 showed a very small blue halo around the star in focus and I proceeded to rack the focus in and out to do a star test. The outside focus was sharp and rings clearly defined. It had some green/yellow tinge to it. Inside of focus the round disc was less defined and also had some color to it. Going back to focus the star "snapped" into place and the airy disc was clearly seen. There was no elongation of the star inside/outside of focus- indication no astigmatism in the system. I would say the star test revealed a small bit of overcorrection but I would rate this as one of my better star tests I have performed on many telescopes.
Overall Impressions:
The Pentax 75EDHF seems to have the same amount of CA as an AT102ED I once owned (from memory). The optics are superb and I suspect the ED element is an FPL-51 or similar. I believe Pentax made the SDHF using FPL-53 ED glass for even better CA correction.
The build quality is nearly the quality as Takahashi refractors I have used. I would say nearly because Takahashi uses metal knobs for the focuser instead of plastic knobs. The hardware used and the machining tolerances is definetly up there with Takahashi.
With a 30mm image circle, I can't wait to try out Pentax 75EDHF flat field astrograph with my DSLR . I will have to mount the OTA on my tracking mount, since the MS-2 mount has no RA drive motor. I am very lucky to find a pristine Pentax 75EDHF and this kit feels about as new as it comes!
- Deven Matlick, dyslexic nam, R Botero and 2 others like this
#56
Posted 01 September 2017 - 09:29 AM
What a wonderful scope! Congratulations!!
- rolo and coinboy1 like this
#57
Posted 01 September 2017 - 02:56 PM
Wow !,
the 75 looks like new in a box, what a great find, congrats !
I would have to agree on the build quality, they were very well engineered,
and optics excellent,
- coinboy1 likes this
#58
Posted 01 September 2017 - 09:44 PM
I have had my Pentax MS-5 GEM for nearly thirty years. When I first looked at the Mount forum on CN people were talking about "slop", "backlash" and even the need to "mesh the geers" on an AP 1100. I had no idea what those things were and what these people were talking about. None of these problems existed on my perfectly machined Pentax GEM. There is no slop, no backlash and I do not even know what it means to mesh the geers.
- Steve_M_M, coinboy1 and Bomber Bob like this
#59
Posted 02 September 2017 - 01:10 PM
Guys, What is a 100, F12 (achromat, not ED) with complete with mount and a eyepieces and a couple of diagonals worh in todays market?
Regrds, Vinay
#60
Posted 05 September 2017 - 09:09 AM
Regrds, Vinay
Hard to say - they don't come up for sale very often. I searched Amart and couldn't find anything (there is an ED version that went for $1800 back in 2009, but this would be a less expensive scope since it is an achromat).
#61
Posted 05 September 2017 - 02:28 PM
If you look at that AD, seller states it is an ED, but photos show it is an Achromat,
#62
Posted 05 September 2017 - 03:15 PM
Owning one with mount and pier and aluminum tripod and complete set of eyepieces and .965 and 1.25 diagonals and two Pentax barlows and RA drive, and knowing the images mine provides, and comparing with Unitrons and Gotos as far as kit and fit and finish and $10k Nikon 10cm out there, I would suggest about $3500. Mine is not for sale, but I had and sold the Uniton 4" and I would sell the Goto for quite a bit more, but again it's not for sale either.
#63
Posted 05 September 2017 - 08:31 PM
I'm happy and sad to see this topic.....happy that it's a Pentax thread, but sad to see that it's been categorised as "Classic"!!
Here's my contribution to this thread...my 125SDP but sadly on a non-Pentax mount. I'll stop looking for the 125SDPs in the Refractor section going forward
- Deven Matlick, Richard Whalen, coinboy1 and 3 others like this
#64
Posted 05 September 2017 - 08:48 PM
Looks pretty darn 'Classic' to me. Very nice scope. Thanks for posting.
#65
Posted 05 September 2017 - 09:26 PM
Well this SDP is certainly much newer than the EDHF series. Since Pentax no longer makes telescopes and approaching 10 year since production, its safe to say Pentax telescopes are classics!
- Bomber Bob likes this
#66
Posted 06 September 2017 - 11:17 AM
I have a Pentax 75 SDHF that I bought as a package with a full set of Pentax SMC Orthos. It's nice and sharp, with just a little false color. For years I kept a white light solar filter on it for quick looks at the sun, with the scope mounted on an altazimuth head and tripod. When I finally put it on an equatorial mount, I found it had an essentially perfect star test. Another nice feature is that it has a flat field without the need for a reducer or flattener. At 500mm, it could be ideal for solar eclipses, either for photography or visual use. I'd like to find a proper Pentax mount and tripod for it some day, maybe the model one up from what it normally uses.
#67
Posted 08 September 2017 - 04:54 PM
I have owned 2 Pentax telescopes in the past. I owned a Pentax 85 achro and mount in the 80's. In fact the late Bruce of Company 7 and I had ours both at the same time. I used it to see the impacts in the cloud surface of Jupiter when Shoemaker-Levy hit. In the 90's I acquired a Pentax 75EDHF OTA and used it to make a travel rig using a Nihon Seiko portable EQ mount. Views of Omega Centauri from the Bahamas will last a lifetime. I have used and collected Pentax cameras off and on for 45+ years. I still have the complete set of Pentax XL eyepieces I acquired while working for Gary Hand.
- Deven Matlick and coinboy1 like this
#68
Posted 09 December 2017 - 11:17 PM
WOW GUYS!
Those museum pics were amazing!! All those fresh Pentax tubes laying there! And the large Pentax GEM mounts!!! I'd have to say, I would absolutely trade my left noot for one of those! I dont imagine they are available anywhere, as I belive only a handfull were ever made. But, It gives me something to dream about. Maybe, just maybe Ill find one someday.... They look so robust. Sturdy..... wow...
ginnz.
Edited by ginnz, 09 December 2017 - 11:17 PM.
#69
Posted 08 June 2018 - 11:12 PM
I got to own Pentax-65 (D65mm F700) comes with MS-2 manual EQ mount. Since it is non ED scope, I expected some amount of CA but didn't notice CA when viewed Moon & Jupiter. Both scope and mount built quality is superb, solid and smooth with vintage charms. Only flaw I noticed is plastic capped knobs for RA & DEC tension adjustment easily crack due to age. But it is not an issue since it can be easily replaced with machined metal knobs.
I am sure every owner will love it and won't regret to spend money to own Pentax.
(Sadly, it has just been sold and now it is on the way to new home in Colorado. I am sure new owner will love it)
- Bomber Bob, BillShakes, DMala and 1 other like this
#70
Posted 08 June 2018 - 11:59 PM
Yes, I think I will love it! I look forward to making it an exhibit in my Classic Telescope Video Museum so a lot of other vintage scope fans will get to see it as well.
Thanks Chris!
- Dave
- AaronM, Bomber Bob and BillShakes like this
#71
Posted 09 June 2018 - 12:26 AM
By the way, here's a picture of my superb Pentax 85 (thanks Stew!)
- deSitter, rolo, Bomber Bob and 2 others like this
#72
Posted 09 June 2018 - 05:24 PM
Nice video Dave,
Looks like you have picked up the Pentax bug !, now adding the 65 to your collection,
I think you can date these scopes from the serial number, I think your 85 going by all the chrome is late 70's or very early 80's
my 100 Achro is serial no: 79313, and I know that original buyer bought this either 1979 or 1980, it also has all the lovely
chrome like your 85, so I think the first two digits are the year of manufacture,
my 100 ED Apo is serial number 86019 and is a later production scope with the SMC coatings, sadly all the chrome
has been replaced by black anodising, so my guess is it dates from 1986, let me know what serial numbers are on yours,
Steve
#73
Posted 09 June 2018 - 08:17 PM
Oh I saw that video long ago and was wondering where you did you get 85mm Pentax scope! I didn't realize proud owner is you. Congrats Dave, you own two beautiful scopes with superb mounts.
#74
Posted 09 June 2018 - 09:50 PM
Nice video Dave,
Steve
My Pentax 85 is from 1978 and the 65 is from 1982... according to an expert who would know. I think you are right, the first two digits are the year.
- Dave
- Stew44 likes this
#75
Posted 09 June 2018 - 09:51 PM
Yes, the 85 is from a friend who lives near me and used to be a Pentax rep. Apparently these scopes are pretty rare in the US.
- Stew44 likes this
