Making a wooden tripod for my classic telescopes.
87 replies to this topic
#76 roscoe
roscoe
    curmudgeon
  • Loc: NW Mass, inches from VT
Posted 30 June 2018 - 02:09 PM
I'm happy, too, they look great!  The little mini-hub spacers are a good idea, too!
  • terraclarke and Garyth64 like this
#77 terraclarke
terraclarke
  • Loc: Third from the Sun
Posted 30 June 2018 - 06:35 PM
Russ makes the most amazing trays and tripods! Believe me, I have seen them! The one Red Molly is riding on is gorgeous! His trays? Wow! And I’m not a fan of dobs but Russ’s 10” Cave Dob rebuild is wonderful, and you should see the Dob Dolly! :love:
  • roscoe, rcwolpert and shooze like this
#78 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 09 August 2018 - 03:48 PM
As a final note on this tripod, I have done two things.
To hold the control pad, I made a little holder that fits into the tripod legs.  Velcro hold the pad to the holder.  I don't  have to worry about the wires knocking anything off of the tray.
When I first made this tripod, I couldn't locate a CG5 hub, so I made this from a piece of aluminum and some oak.  It turned out to be a very good and solid fix.
Today, I received a CG5 original hub for tripods, and within an hour I had it in place.  It doesn't look special, but it looks like it's suppose to.  I like this better than what I made. I just looks neat and simple.  (and I can repurpose the other hub on another mount.)
You can see the little square holder with Velcro to hold the control pad.
Edited by Garyth64, 09 August 2018 - 03:49 PM.
  • memento, roscoe, Exnihilo and 6 others like this
#79 tim53
tim53
  • Loc: Highland Park, CA
Posted 10 August 2018 - 09:25 AM
These are beautiful!
One thing I have to deal with at some point:  The tripod legs for my Tak NJP have cracks at the top where the bolts go through to hold it to the tripod head.  They're wonderfully solid mahogany legs.
I got an idea from an old surveyor's tripod that used to belong to Caltech.  The legs are pretty thin at the top where they attach to the head, so what the makers did to prevent splitting along the grain was to cut a saw kerf right through the middle of the end of each leg, and glue a sliver of wood of the same thickness into the kerf with the grain running 90 degrees to the leg grain.  No splits, and the tripod has to be at least 50 years old.
-Tim.
  • Garyth64 likes this
#80 Exnihilo
Exnihilo
  • Loc: Tempe, AZ
Posted 10 August 2018 - 09:34 AM
Very nice!
#81 Tenacious
Tenacious
  • Loc: Northern KY
Posted 10 August 2018 - 12:15 PM
Another great idea, Gary.  I was actually thinking of something similar for my drive controller and battery pack, but I was going to leave the through-block bolted to the controller, which would make it bulkier and oddly shaped.  Your removable Velcro attachment point is much more flexible and can be left on the tripod.  Nice job!
#82 Tenacious
Tenacious
  • Loc: Northern KY
Posted 10 August 2018 - 12:19 PM
-Tim.
Pics?
#83 Couder
Couder
  • Loc: Missouri Ozarks
Posted 15 August 2018 - 09:39 AM
I have made several tripods, from small to some for 6" F15 refractors. The following pictures show the tapered brass pieces I made for the missing one on the bottom of the tripod feet, along with the steel piece to dig in the dirt and keep the tripod stable. I also made the brass bolts to hold the legs to the top. Of course I kept the originals, labeled and tagged, along with the rest of the Clark equipment. I did not alter the original in any way to add these. The other pictures show a dovetail system I designed and made to hold both the 4" and the 6" F15 Clark refractors on the Astro-Physics 1200 mount.
Both Clarks on Astro-Physics 1200 mount
Dovetail system to hold both Clarks on Astro-Physics 1200 mount - back
Dovetail system to hold both Clarks on Astro-Physics 1200 mount - front
Part of dovetail system to mount both Clarks on Astro-Physics 1200 mount
Tapered feet for Clark tripod legs - new and original
New brass tripod bolts I made for the Clark tripods.
  • roscoe, walter a, Garyth64 and 4 others like this
#84 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 01 October 2018 - 07:47 PM
After using this tripod and it's twin, I have found an obvious flaw.  I have no way of leveling them!
From it's design, I can't make the leg itself adjustable because the tray rests on top of the lower part of the leg.
So, I made up some little oak extensions that are adjustable.  Just add some bolts and wing nuts.
I just need these on two legs.  It give 2½" of adjustment.
I'll see how this works before I do this to the other tripod, but so far so good.
Edited by Garyth64, 01 October 2018 - 07:48 PM.
  • Kasmos and Defenderslideguitar like this
#85 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 01 October 2018 - 07:59 PM
Also, in another post, I mentioned the use of "glow in the dark tape".  This stuff is great!
I put it on all the legs of my tripods. (but it was removed in the above post to attach the levelers.)  It helps people see where the legs are at star parties so they don't trip or bump into them.
They will glow all night.  (but not as bright as seen in the photo, because I "charged" them up)   The other night I went out into the garage, and I could see where the 3 tripod legs were.
I even put some of this tape at the top of my stairs on the steps where the landing makes to 90s.  No more guessing where the steps are in the dark!
Edited by Garyth64, 01 October 2018 - 08:04 PM.
  • Marc-Andre, walter a, Kasmos and 2 others like this
#86 jcruse64
jcruse64
  • Loc: Paducah, KY USA
Posted 02 October 2018 - 08:36 AM
The glow tape is awesome. I bought a Vixen SP tripod with an EQ-3 mount from a great member here, and it had glow tape on the bottom of the legs. It's been great for keeping me from destroying the whole package during my observing time.
#87 bremms
bremms
  • Loc: SC
Posted 02 October 2018 - 10:39 AM
I had some warped legs as well so I went with some black ash that I cut down over twenty five years ago.
Love the bicycle QR skewers!!
  • nowhere likes this
#88 nowhere
nowhere
  • Loc: Vancouver
Posted 02 October 2018 - 06:47 PM
The bicycle quick releases are a brilliant idea!
This thread has me considering making new tripod legs myself. I have an older HEQ-5 (just a dual axis drive, pre-goto) which has nice looking but willowy wooden legs homemade by a previous owner. I have a 4" f15 refractor on it and the mount is pretty wobbly. As far as I can tell the vast majority of the shakes come from the tripod. My plan was to just work with it and when I have saved up the money to replace the legs with a Berlebach tripod, and in the more distant future to replace the HEQ-5 with a G11 or comparable mount. A set of new wooden legs and a spreader-tray along the lines shown here might be a good solution to the wobbles that I could do right away. I'm OK with non-extendable legs too as I haven't had any trouble transporting the tall single piece legs that I have - they're about the same length as the OTA so I need to have that much space in a vehicle when I transport the scope anyway. Adjustable feet would be good though. Getting the current tripod level is a bit of a chore. I only observe visually so I can get away with very approximate leveling and polar alignment but an inch or so of adjustment on the ends of the legs would make it much easier.
  • Garyth64 and Defenderslideguitar like this
